Question about Radio Shack Pro-82 Scanner
How to program a pro 82 scanner
It turns on but u press any buttons and nothing happens
  • budkarr Nov 09, 2008
    I just bought it. It turns, it seems to be scanning,but I get no voice sound.I think I've done everything the instructions advise , but still no sound.
Make sure you are using the right battery pack, it comes with a blue one for rechargable batteries, and a black for regulae batteries, if you get these mixed up it won't scan
Posted on May 26, 2009
    Problem Solver:
  • 12 Answers
Try using frequencies you knw the police inyour area are using. you can get them from cityfreq.com
Posted on Feb 06, 2009
HAVE A RADIO SHACK PRO-82 SCANNER, READS L/O IN UPPER RIGHT HAND CORNER HOW DO I UNLOCK?
That means that you have on programs in your scanner...you have program loss hit your program button and you can start programming your frequencies......
Jun 13, 2011 | Radio Shack Pro-82 Scanner
I have as pro-82 scanner reciever but no instructions. Iwant to use the scanner to monitor air traffic
Your PRO-82 has a key marked "AIR". Press it while the scanner is powered ON and it will search the AIR band for you, stopping each time it detects an active frequency. For more details on programming and monitoring with your scanner, you can download and print the factory manual, at no cost, here:
http://support.radioshack.com/support_electronics/doc69/69887.pdf
Bill B.
Listening in since the 60's
Apr 20, 2011 | Radio Shack Pro-82 Scanner
My radio shack pro 82 keypad not respond when I press it.Lamp button etc not work, only channel scan running up and down when i pree the arrow :( what should i do to repair it. Initializing procedure is...
Most likely have locked it. Press and hold the lock key lower left button. it will beep several time when unlocked the lock symbol if in the upper left side of the LCD screen next to BANK
Apr 19, 2011 | Radio Shack Pro-82 Scanner
My scanner was working fine until I held down the lock button. It didn't actually turn on the key lock (the key symbol didn't come up on the display) but now none of the keys respond to presses. I tried...
When you reintilize the scanner, it should lose all programming and settings. Hold down the Tune/Clear button while pushing the reset button. Do not release the Tune/Clear button until the display clears and returns.
Aug 14, 2010 | Radio Shack Pro-82 Scanner
Dont know how to program
To program a known frequency into the PRO-82:
1. Power the scanner ON
2. Press the PGM key
3. Enter a channel number between 1 and 200 (you might want to start with 01).
4. Enter the frequency, including decimal point (Ex: 146.26).
5. Press ENT
6. Press PGM to advance to the next channel
7. Restart at number 4 above.
For a comprehensive database of active frequencies in your area, and a lot of other useful scanning information, visit:
www.RadioReference.com
Bill B
Jun 13, 2010 | Radio Shack Pro-82 Scanner
I cleared my pro-82 scanner. Program button is not working to let me reprogram. Help.
As long as all frequencies have been cleared, try initializing the scanner. This will return everything to the original factory settings.
To INITIALIZE:
- Turn the scanner OFF, then switch it back ON.
- Hold down the TUNE/CLEAR button.
- While continuing to hold the TUNE/CLEAR button down, insert a pointed object such as a paperclip or the tip of a pen into the RESET opening on the side of the scanner, and press the RESET button inside the opening. The display should go blank.
- When the display comes back on, press the TUNE/CLEAR button again. The scanner should now be ready to accept programming.
Need the manual for your scanner? You can download/print it here:
For a comprehensive database of active frequencies in your area, visit:
Bill B
May 08, 2010 | Radio Shack Pro-82 Scanner
My scanner will not scan
You need at least 2 or more frequencies programmed, and
adjust the squelch knob until there is no more static, then press the scan button.
Here's a manual
Feb 09, 2010 | Radio Shack Pro-82 Scanner
HOPKINSVILLE KY. POLICE DEPT. CHANGED TO A
Unfortuantly the pro-82 is not a trunked scanner, it's only a vhf/uhf scanner and cannot pickup trunked systems. You need to replace it with atleast a pro-95 to pick up trunked systems. If you need your manual for the pro-82 follow this link.
http://www.radioshack.com/graphics/uc/rsk/Support/ProductManuals/2000315_PM_EN.pdf
Feb 19, 2009 | Radio Shack Pro-82 Scanner
Scanner will not move from the programmed Police channel
you may need to play with the squelch. and/also hold down the light/key button until the key goes away but mess with the squelch after you get rid of the lock. you want the squelch as far left without it stopping and making static noise
Jan 18, 2009 | Radio Shack Pro-82 Scanner
Wtf
hold down the light key/ lock key on the bottom left hand coner and it will unlock the unit
Jan 04, 2009 | Radio Shack Pro-82 Scanner
Radio Shack Pro-82 Scanner Logo
195 people viewed this question
Top Radio Shack Radio Communications Experts
John
John
Greg Cann
Greg Cann
Jason
Are you a Radio Shack Radio Communication Expert? Answer questions, earn points and help others
