Question about Maytag Atlantis MDE7400AY Electric Dryer
Dryer will heat but not all the time.
Takes a very long time to dry. glow plug lites but does not come on offen enough
  • 481 Answers
It sounds like an airflow problem. clean everywhere the air flows. dryer will heat but not all the time. - 5bd3f51.jpg
Posted on Aug 08, 2008
  • Mike Durland
    Mike Durland Aug 31, 2008
    if this was'nt the problem then what was it?
I don't hear the electronic ignighters
Igniter and Gas Valve Coils
TEST with a multi meter: The igniter is an electric conductor that works like the element in an electric heater, glowing hot enough to ignite gas when you turn on the dryer. This conductor can burn out, and when it does, it may glow, but it won't get hot enough to ignite the gas. At times it may give a reading of continuity yet fail mechanically and not get hot enough to ignite flame though it gets hot and glows and even may show Ohms or continuity ( close circuit) ?
Occasionally, the Gas safety valve and the electric coils that control the gas valve are defective -- they can wear out when the dryer gets old. When this happens, the igniter glows, but gas never enters the heating chamber or does not stay consistant.
Performing a continuity test on either part will help you determine whether or not you need to replace it. But the coils should also be tested for amount of resistance as well as Ohms. As they may be showing ohms yet not putting out enough resistance to keep proper gas pressure flowing. Most coils should show at least 1300 ohms ( GIVE OR TAKE 150 OHMS). Anything significantly less Thus u get an ignition but then it soon goes back out. The flame does not stay lit.
Air Flow and Heat
The motor that drives the tumbler also drives a fan that circulates air through the heating chamber and the tumbler and expels it through the vent. If the air can't circulate, perhaps because of lint blockage, the heating chamber overheats, which prompts the cycling thermostat to turn off the gas. The thermostat resets when the chamber cools, but the chamber heats up quickly and the thermostat again shuts off the gas. The result is that the temperature in the tumbler doesn't stay hot, and your clothes take longer to dry, if they get dry at all.
Warning
There's a big difference between a dryer that doesn't heat up at all and one that just doesn't get hot enough to dry your clothes. In the first instance, the problem is usually a defective part, and things should be back to normal after you replace it. In the second instance, the problem is caused by restricted air flow, and you need to clear the lint filter and vents and take steps to prevent lint build-up. If you don't, you'll use more energy for drying than you need and the dryer may continue to malfunction. Worse, you may have a dryer fire.
GOD IS GOOD !!!! AND THAT IS WHY MY ADVICE IS FREE
replacing whirlpool gas dryer ignitor not heating www goodappliancesupersto... How to Fix YOUR gas Dryer that is not heating up Part 1 rear panel
Jan 04, 2017 | Dryers
How to fix a whirlpool gas dryer that tumbles but no heat ?
Air Flow and Heat
Warning
Apr 12, 2015 | Whirlpool Dryers
Gas dryer throws reset after a few minutes
Air Flow and Heat
Warning
Apr 07, 2015 | Dryers
Ge gas dryer. All of a sudden! No power
Gas Dryer no heat: or shuts down soon after heating CHECK:
Thermal Fuse
If the air flow in the dryer is restricted, the temperature in the heating chamber can get hot enough to blow the thermal fuse. If the fuse blows, it cuts power to the coils that control the gas valve. The fuse is usually mounted to the exhaust duct just inside the back panel. You can check its continuity with an ohmmeter. If, after disconnecting the fuse, you get any reading other than 0 when you touch the leads of the meter to its terminals, it has blown. There's no way to restore it -- you'll have to install a replacement.
Air Flow and Heat
Warning
Oct 06, 2014 | Dryers
Speed queen gas dryer will not lite. Has been in storage
Thermal Fuse
Air Flow and Heat
Warning
Oct 04, 2014 | Dryers
Hotpoint model dll3680s will not heat. thermostats test ok but no power to ignitor. could it possibly by the timer?
Thermal Fuse
Air Flow and Heat
Warning
GOD IS GOOD !!!!
Sep 17, 2014 | Dryers
Why is my Kenmore 500 series gas dryer won't heat up, no flame.
Thermal Fuse
Air Flow and Heat
Warning
Aug 21, 2014 | Kenmore Dryers
Does the gas dryer need to be plugged in to check the vac on the ignitor on a roper
no unless ur doing a live test?
Thermal Fuse
Air Flow and Heat
Warning
Aug 13, 2014 | Dryers
No heat
SOUNDS LIKE BAD GAS SAFETY VALVE
Thermal Fuse
Air Flow and Heat
Warning
Jul 05, 2014 | Whirlpool LGQ7030KQ Gas Dryer
I have a gas Kenmore Dryer 74202200 and it heats sometimes, moreso when it first comes on. The glow plug works and it clicks and it fires up, but then the fire shuts off and the glow plug comes back on a...
if it runs for the first 15 to 30 minutes and then no heat you have bad gas coils,located on top of the gas valve,when the coils heat up they fail,if you try to start it again after it sits for a long time it will lite again,also you could have a bad gas valve,try tapping the valve to see if it lites,if it does lite while you're tapping on it most likely it will be the valve,let me know what you find and send the model number.good luck
Jul 26, 2010 | Kenmore 63942 Dryer
Maytag Atlantis MDE7400AY Electric Dryer Logo
49 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
