Question about Canon imageRUNNER 5000 Copier
I moved the copier and have a problem with an imagerunner 5000 S
I powered up the main unit and connected the finisher and recieved a message "check the finisher"
Also I receive a note on the screen top left with a tiangle fllowed by Reset unit 1.
There's an animated picture showing the font door of the copier opening and closing.
Is there something I can do to reset he machine?
Thank you
Tony Schweiker
201-934-3324
  • Anonymous Sep 30, 2008
    We moved the machine and now we get a "chech the finisher" error.
Have you solved this problem yet? Do you have the copier in N.J.????? If not call me 973-900-2209, I may be able to help you, I'm in N.J.
Posted on Sep 12, 2008
I want to know how to clear the error of E000004-0000 in my canon imagerunner 5000
The SSR has a short circuit or the dc controller pcb is faulty. To clear press:
additional functions
2+8
copier
function
clear
err
ok
turn off main power switch on the side and turn on
Sep 16, 2011 | Canon imageRUNNER 5000 Copier
I have canon ir3750. When I switch on the machine it goes to the start screen , The screen displays wait message, for about 3 minutes and than nothing happens and then the error code message comes up...
This is an error in the communication with the scanner. Check or reseat the connectors from the scanner , check to see if the scanner even moves during initialization ( power supply for it may be bad ), check/replace reader controller, scanner board, or main controller of copier. I've not seen this error before. Good luck.
Jun 23, 2011 | Canon imageRUNNER 5000 Copier
The copier is saying: Turn the main power switch (on the main unit's right side) OFF & ON again. If the machine still does not operate normally, contact your service representative with the error...
The shutter open sensor does not go on. (The shutter does not open.)
1. Check the shutter home position sensor. Is it normal? 2. Check the wiring between the finisher controller PCB and the stack feeding motor and between the finisher controller PCB and the shutter open/close clutch. Is it normal? 3. Is there a fault in the shutter mechanism? 4. Try replacing the stack edging motor and the shutter open/close clutch.
May 11, 2011 | Canon imageRUNNER 5000 Copier
How do I access the hard drive (to replace) on a Canon imageRUNNER 5000. Where is it located/how do I remove it?
Points to Note When Replacing the HDD
1. Take care to avoid damage by static charge.
2. Keep the HDD unit from impact.
1) Remove the rear upper cover and the
reader rear cover.
2) Remove the three screws , and detach
the cover.
3) Remove the two screws , and disconnect
the two connectors ; then, remove
the HDD unit.
4) Remove the six screws, and detach
the HDD.
When mounting the HDD unit, be sure that the flat cable is under the plastic sheet of the HDDupper case.
here is a link to the location of the HDD http://i51.tinypic.com/htvitg.jpg
Obs:
1) Replace the HDD unit.
2) After assembling the machine, connect the power plug to the power outlet.
3) Connect a PC to which the Service Support Tool has been installed.
4) Turn on the PC, and turn on the main power switch while holding down both '2' and '8'
on the keypad.
5) Using the Service Support Tool, format the HDD unit and install the system software.
Nov 16, 2010 | Canon imageRUNNER 5000 Copier
Imagerunner 5000s with an error code e000014-0000
this is fixing motor fault
you need to replace main power pcb, fixing motor or dc controller board
you can not reset this error
Mar 31, 2010 | Canon imageRUNNER 5000 Copier
Canon Imagerunner 500i finisher problem
between the copier and finisher there have a atuacter to atuact the door sensor, therefor just push finisher perfect contact the machine will resolve your problem.
Dec 10, 2008 | Canon imageRUNNER 5000 Copier
The Cannon Imagepass L1 cannot connect to Imagerunner
set service mode->copier->option->int-face->img-cont = 1
Jul 25, 2008 | Canon imageRUNNER 5000 Copier
Canon Imagerunner 5000 error E000001-0000
Sort of, since both are fuser temperature related. First, the error needs to be cleared. Turning off/on won't do that.
You could go into service mode and clear the error (*28* > copier> function > clear > err > ok. Then turn the copier off, then on again and watch it heat up. I always monitor the temperature to make sure it's in the acceptable range (190 C or around that range).
If it happens often I'd have the thermistors changed. If it still happens, check the connectors in back of the fuser. They may need to be shimmed.
May 18, 2008 | Canon imageRUNNER 5000 Copier
Canon imageRUNNER 5000 Copier Logo
173 people viewed this question
old marine
old marine
