Question about Hummingbird GPS
Older HUMMINGBIRD DEPTH SOUNDER LCR-3D . WAS WORKING FINE WHEN I PUT IT AWAY, NOW WONT POWER UP. HAVE CHECKED THE INPUT POWER AND IT IS OKAY. I DO NOT SEE A FUSE IN THE UNIT. ITEM IS OLDER UNIT BUT IS BASICALLY BRAND NEW AND HAS HAD VERY LITTLE USE. ANY THOUGHTS ON HOW TO TACKLE IT? mARTIN
We have an old Hummingbird Depth Sounder (Wide 100, 94 model) and it turns on but must be on test mode or smething cause we can not get it off. Does anyone know or have a manual to solve this problem. Please help.
Posted on Oct 17, 2008
Problem solved
Posted on Aug 08, 2008
NEED A MANUAL FOR A HUMMINGBIRD LCR 400 PORTABLE
Here's the link.
http://www.humminbird.com/PDF/lcr400id.pdf
Thanks and Have a good one.
Oliver
Jul 29, 2011 | Hummingbird Exceed 10.0
I have a gps Map 498-depth sounder not working? Have new transducer from Garmin-it flashes "00"-it is not connected to boat yet (transducer)-need it be or can I put in a bucket of water (need it be in...
If the transducer is out of the water, you will not get a reading and see the flashing depth. You should hear and feel the clicking in the transducer when out of the water and working properly. Are you getting a temp reading when out of the water?
May 16, 2010 | Boating
Is there a free downloadable manual for a Humminbird LCR 4000 Fish finder?
type in hummingbird lcr 4000 fish finder manual pdf. it works for anything you want
Nov 04, 2009 | Humminbird Smartcast Rf 35 Dual Display...
Furuno 4100 depth sounder shows depth twice what it really is
check your gain setting try auto gain and try manually gaining back to see if it resolves, if yes, send unit in to furuno, if no, ducer is probably at fault.
Aug 01, 2009 | Furuno Ls4100 5" Mono Lcd Fishfinder Temp...
Hummingbird gps ns25
Hi!
here's a user manual/installation manual for your sounder:
NS25
If the depth sounder portion works, I would suspect the settings are off (check first) or the gps circuit needs repair.
Best of luck!
Mike
Sep 02, 2008 | Hummingbird Humminbird 1155C GPS Receiver
Depth Sounder does not display depth
I will see if I can get mine off the hull for testing. Still have found no procedure. Thinking about just replacing the sounder with another unit.
Jul 05, 2008 | Garmin 185 Sounder GPS Receiver
Si-tex cvs 106 mk11echosounder
To re-program the Si-tex CSV-106 depth sounder to feet/meters/fathoms: Push and hold down the MENU key while turning the unit on (POWER key) to enter a special menu. Release both keys after you hear two beeps, almost immediately. Use the LOWER ALARM key to select the desired unit for depth, then turn off the depth sounder. That's it, just turn on again to see the change.
There is also another menu (for testing sounder) available by pressing the MODE and turning on as above.
Apr 26, 2008 | Computers & Internet
Navman 4150 fishfinder
Depth: Could be for a number of reasons, too deep for the sounder - check the manual for it's max depth. Dirty water, sounder unable to penetrate through to the bottom. Weed or other debris covering the transducer. Transducer on a swing mount & being pushed out of alignment then dropping back in once stopped.
Speed: Is the speed readout controlled by a GPS or paddlewheel? If it's GPS, check the power connection of the sounder, may be loose which would also cause the depth to 'drop out'. If it's paddlewheel, you're down to bad connections or faulty unit.
Oct 16, 2007 | Navman Fish 4150sx GPS Receiver
NO DEPTH READING
Check the finder on the bottom of the boat and make sure the cable is ok?
Aug 09, 2007 | Garmin 185 Sounder GPS Receiver
GPS Logo
773 people viewed this question
Top Hummingbird GPS Experts
Mike Marcotte
Mike Marcotte
Steve
Steve
Are you a Hummingbird GPS Expert? Answer questions, earn points and help others
