Question about Maytag MSD2656G Side by Side Refrigerator
How do I clean my drain pan on my side by side refrigerator it smells
My refrigerator smells its coming from the drain pan HELP!!!
  • 943 Answers
Hi. Thanks For The Question. Pull Fridge Away From THe Wall. Remove Back Panel Clean All Coils. Remove Drip Pan. Clean. Thanks The Appliance Doc
Posted on Oct 03, 2008
SOURCE:
My Frigidaire refrigerator has a drain pan that is un remove able and has a bad smell how can I clean.
I appreciate your inquiry, friend!
If you would like to clean any dirt or debris from the drain pain you can use a vacuum attachment to get inside and clean any residue within the drain pan. You can also use warm water and bleach to help disinfect the drain pan prior to vacuuming it out. If that does not help you may want to consult with a professional technician for additional cleaning to be completed within your Frigidaire refrigerator. Best of luck! -Matt
Oct 19, 2014 | Frigidaire Refrigerators
How do I fix the smell coming out of engine area. everytime it turns on it smells.
Hello friend, thank you for your inquiry!
I understand that you are receiving a smell from the engine area of your Frigidaire refrigerator. I would recommend cleaning your drain pan area, you can do that by using water and bleach in a spray bottle then spraying it into the drain pan. Also, get a vacuum attachment to help suck out any debris located in the drain pan. You can also seek consultation with a professional technician for additional assistance if needed. I hope this helps. -Matt
Refrigerator smells horrible , but there is NOTHING spoiled in it.
You might have something smelly in the defrost drain pan. The easiest thing to do would be to take the back off the fridge and see if the defrost drain pan smells bad...if so just clean it out with soap and hot water. don't use anything too strong smelling to clean it though, you don't want your fridge to smell like bleach or pine sol.
Good Luck!
Sep 29, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Funky smell coming from bottom of frig when running
Is it a musty smell or that of something / (rodent) decomposing? If you only smell it when it is running then look for BLACK gunk that will probably appear almost like a paste. Even things like cat or dog hair will collect in damp areas. There should be a white plastic drip pan under your unit. Look for the freezer white plastic drain hose on the rear bottom of your unit on the freezer side and follow that hose to the drip pan. It catches water every time the unit defrosts which is 3 - 4 times a day depending on which defrost timer your unit has.
Usually there is a build up in the drip pan that gets mucky and then stinks like mold. It will of course need cleaned.
Also look at the fan area for the coils. Sometimes there are unwanterd home critters that attempt to get through the running fan blades and end dead up inside the cooling coil metal radiator area.
Feb 03, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Bad smell from underneath side-by-side Jenn Air fridge - how to access and clean out drain pan?
drain pans are no longer removable. to clean. can remove back panel or btm frt kickplate and look for pan. spray lysol down their and clean out the coils.the only reason it should smell is if anything spoiled in ref. and got into drain system. you can try and vacumm up whats in the pan but you will have little room. unplug ref from wall before you go poking around.
Sep 19, 2009 | Jenn-Air JCD2389G Side by Side...
Smell fish odor when fan comes on.
Tim, Clean the refrigerator completely with clorox and water. Unplug and remove the rear panel in the back of refrigerator and wash the evaporator coil with this solution. Check the amount of flow to the condensate pan below. The drain line has the gel and this contaminated smell from top to bottom and you will need to insure that all the smell remaining in the drain is draining freely and decontaminated with the clorox. Do these things and wash the remaining pan below the best you can and you will be set to go.
Jun 20, 2009 | Whirlpool GD2SHGX Refrigerator
I have a very bad smell coming from the back of my refrigerator. The fridge itself is clean and there isn't any turned food inside. I can't figure out what's causing this awful smell.
there is a pan built in under the unit that the water drains into when the defrost timer activates. the heat from the coils usually evaporates this water, but if the coils are filled with dust the air circulation is blocked and the pan will have stale water remain in the pan.the coils should be cleaned and the pan also. this can be done with a little help from an air compressor and paper towels
Jun 14, 2009 | Jenn-Air JCB2280HES Side by Side...
BAD SMELL COMING FROM UNDER MY WHIRLPOOL SIDE BY SIDE FRIDGE. I SMELL IT WHEN THE FAN BLOWS. IT SMELLS LIKE URINE.
check its not the drained ice water which collects on a pan over the compressor. the compressor heat is supposed to evaporate it .that foul smell might be due to that.
if that is the case ,switch off fridge , clean , dry , the pan & see .
May 31, 2008 | Whirlpool Refrigerators
BAD SMELL COMING FROM THE UNDERNEATH OF MY SIDE BY SIDE WHIRLPOOL FRIDGE. SMELLS LIKE URINE....
There is a drain collection pan under the left side behind the toe plate. Remove the drain tray and clean it.
Smell from under the side by side.
mix a solution of baking soda and water, open freezer section and right at bottom fofreezer back wall you seee vents cut in plate, they lead to draintube and eventually to drain pan(which in most new models is not removable) pour the solution down the drain(maybe a cup or so), the waterwill evaporate and the baking soda will remain absorbing odors
Feb 21, 2008 | Jenn-Air JCB2388G Side by Side...
Maytag MSD2656G Side by Side Refrigerator Logo
502 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Marvin
Marvin
Carlos Alvarez
Level 1 Expert
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
