Question about Kenmore Elite 45986 Front Load Washer
Kenmore HE3 front loading automatic washer
My washer is blinking F DU and when i try to cancel it twice and unlock the controls it does not unlock. Sears is sending someone on the 12th and it has been stuck for 4 days!!!
  • 5,911 Answers
The problem you are experiencing is a defective door latch. This is an easy repair you can perform yourself if you wish to save a service call. The following link explains the error, how to unlock to door if jammed, and provides the steps necessary to replace:
http://www.fixya.com/support/r622155-kenmore_elite_whirlpool_duet_door_jammed
Searpartsdirect.com carries your door latch. Just type in your model number and look under the various links on the next page. If you run into difficulty finding the part, let me know. I hope this helps you.
PS If your washer is under a service plan or warranty do not attempt this repair or it will void any service agreement you have.
Posted on Aug 07, 2008
Lights keep flashing and door locks without finishing cycle
Kenmore HE2 Plus Front Load Washer Keeps unlocking ...
www.fixya.com > ... > HE2 > Kenmore HE2 Plus Front Load Washer
flashing prewash and add garment lights My HE2 Plus will fill with water, but when ...Kenmore HE3 2plus wont finish cycle Washer wont finish the last1 minute of cycle. ...We ran a load twice and it still did not unlock. du is the code for cannot ... Why does the door keep unlocking and locking in between the drum rotating?
Admiral, Whirlpool, Maytag - Washer Repair - Not ... - YouTube
? 5:51
https://www.youtube.com/watch?v=oBihToN6dxs
Sep 6, 2013 - Uploaded by ApplianceVideo.com
Troubleshoot your Admiral Top Load Washer that has these following symptoms: Not Completing all Cycles ...
Washing machines - Ariston
Jan 05, 2016 | Washing Machines
Kenmore Elite HE3 Error FH I forgot to turn the water hoses on when I started a load. The FH error sounded at 33 minutes of a 45 minute cycle. I can't reset the machine now. It is stuck. It is unplugged....
according to kenmore, you should press the "pause/cancel" button twice and it should release it.  it may also have locked up the CCU, central control module and might need to be replaced.
Aug 02, 2010 | Kenmore Elite 45986 Front Load Washer
Kenmore h2 error code
April 8 2002 DIV 26 SOURCE 110 KENMORE ELITE HE3 & HET WASHERS "ADD-A-GARMENT" INDICATOR LIGHT ON DOOR WON'T UNLOCK WHEN PAUSE/CANCEL BUTTON IS DEPRESSED.
MODELS: See additional page for Kenmore model numbers
COMPLAINT: Due to a Microcomputer Machine Control software error , the ADD-A-GARMENT feature becomes inoperative.
CORRECTION: The Microcomputer Machine Control must be replaced with a service part that has been reprogrammed to prevent ADD-A-GARMENT feature loss.
PARTS: Order electronic control listed on this service flash by model from Division 26 , Source 110 following normal ordering procedure.
MERCHANDISE CODES: WASHER Service Flash - Model Nurnbers for: Kenmore Elite HE3 & HE3t Washers: "ADD-A-GARMENT" indicator light on door won't unlock when Pause/Cancel button is depressed. Kenmore models with serial Numbers beginning with CSL23 through CSM04 11042822200 11042824200 11042826200 11042832200 11042834200 11042836200 11042922200 11042924200 11042926200 11042932200 11042934200 11042936200 Electronic conrrol p/n 8181900 Electronic control p/n 8181899
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jan 11, 2010 | Kenmore 46462 Front Load Washer
I have a whirlpool ghw9100lw the light is flashing but it will not start
Aug 26, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore HE3 stuck in delay cycle and won't unlock or cancel
YOu more than likely have suds in your washer, or an extremely unbalanced load. push the pause cancel button twice, that should unlock the washer. open the washer, and look inside. Is there a lot of suds, or towels that are tangled up? If so, add some fabric softener to the wash tub and do a rinse drain spin (for suds) for the extremely unbalanced load, take the towels (or what ever load you are doing) and put about 1/2 of them in. I have the same washer and have experienced this "problem" once or twice in 7 years. And those were the two culprits. Hope that helps
Jul 30, 2009 | Kenmore Elite 45986 Front Load Washer
WHAT IS DU?
DU is door unlock error - A Door Unlock Error occurs if the door cannot be unlocked. It will try to unlock the door 6 times before displaying the error.
Solutions -
  • Door Lock Mechanism broken.
  • Check Door Lock/Switch Assembly for foreign objects
  • Check Wire Harness connections to the Door Lock/Switch Assembly and Central Control Unit (CCU)
  • Door Lock/Switch Assembly Failure
  • May 19, 2009 | Kenmore Elite 45986 Front Load Washer
    Washer stuck
    Hard Reset - In some cases the control can be non-functioning or may not accept activation from the control panel. To clear and restart the control follow the these steps:
    * Unplug or turn the circuit breaker off for 30 seconds.
    * Reconnect the unit to the power source by turning the breaker back on or plugging the unit back into the wall outlet.
    * Press the Pause/Cancel/Stop button twice to clear the "PF" in the display.
    * Start a short cycle to check the operation of the machine by selecting a cycle and pressing and holding the start button until the machine starts.
    May 01, 2009 | Kenmore 42822 Front Load Washer
    Kenmore front load He3 washer: door wont unlock
    happened to me once - I just unplugged the machine - waited a minute and plugged it back - it - then used cancel button
    Feb 27, 2009 | Kenmore Elite 45986 Front Load Washer
    Kenmore Elite HE3 has power but not starting wash.
    Select PAUSE/CANCEL twice to cancel the cycle. Select
    DRAIN & SPIN if there is excessive water in the washer.
    Re-select cycle and press START. If the problem remains, call
    for service.
    Dec 16, 2008 | Kenmore Elite 45986 Front Load Washer
    Error Code for Kenmore HE3
    The "F" variables (F4-F16) are for electrical problems. You should select Pause/Cancel twice then select Drain/Spin if there is excessive water in the washer. Re-select cycle and press start. According to the manual, if the problem remains, call for service.
    Dec 27, 2006 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
    Kenmore Elite 45986 Front Load Washer Logo
    195 people viewed this question
    Ron Lankford
    Archaeology
    Archaeology
    reliableservice
