Question about Farallon Starlet Networking Hub
Farallon Ethernet 10T Starlet/4
I have this old hub that I want to use to network some printers. I don't have a manual for this unit. I am just wondering why the LED for channel 3 is highlighted on the faceplate, while the others are not. Should I use this channel as the uplink?
  • pickledorf Aug 08, 2008
    Coss71,
    I apologize for not being clearer. The LED is not on, but there is a yellow box painted on the faceplate. You're right that the hub is old and slow, so I wouldn't bother to fix it, but I thought it would be ok for a printer.
    Genius:
  • 1,056 Answers
Hubs are just distribution points, so they are pretty simple pieces of hardware.
If port 3 is lit up, with nothing plugged into it, I would say that it is probably a bad port.
Which can bother the rest of the ports (maybe, maybe not) A lit port with nothing in it can be a sign that it is probably "jabbering".
Since this is only a 10mbps hub, I don't know if I would spend too much time troubleshooting it. If it does have problems, I would just replace it. You can get a 10/100 switch which is a much better distribution point for under $30.
As for using #3 as an up-link port, I vote no. I would just plug that port off, and not use it for anything. A solid light in the middle of a bank with nothing in it is a bad sign.
Posted on Aug 07, 2008
  • Coss Aug 08, 2008
    Yes, as a splitter for a printer it should be fine. 10mbps is plenty, same for internet.
    yellow box??..... Does it look like a little top hat? And show it in 2 different sizes? (like an indication for a button to be in or out?) and is there a push button switch close to it?
    That would be an uplink, or pass through port.
    You can either do the port switching, or you can use a cross over cable for an uplink.
The fans in my Farallon 24 port switch sound like they are about to die is there a short term solution?
Try using a can of compressed air and blow air through the vent grille/holes to clear out accumulated dust. Look for more than one vent and blow air through all of them. Do NOT shake the can of compressed air before use. You can buy a can of compressed air at any office supply or computer store.
Feb 28, 2015 | Farallon Computers & Internet
Why home hub 4 will not detect my printer via ethernet
Try this:
1) turn off all devices on your network
2) reboot/restart hub/router
3) turn on all devices on your network
Aug 06, 2014 | HP Office Equipment & Supplies
Wanna connect mulitple computers to my Printer
Yes, you can definitely share one printer to multiple computers. All you need to have is a ethernet hub or some call it network hub and Cat5 cable. Ethernet Hub is a simple, small and inexpensive gadget to connect multiple computers together.For the Cat5 cable is popularly known as LAN cable. For you to share your printer, connect it on a ethernet hub as well as your computers using a Cat5 cable. Once everything is connected to the Ethernet hub fix the network and that's it. Everyone that is on the network can use the printer.
I hope I answered your question.
Thanks a lot!
Jul 25, 2011 | Ricoh Aficio GX3050N All-In-One Printer
Set up netgear xeb1004 ethernet switch to network printer hp lj 4050n and printer will not work despite everything functioning properly otherwise...help?
double check and double check again just to make sure you have everything connected properly. go to the start menu and select my computer. it may be in my network places. if you dont see it its not connected properly.
Jan 24, 2011 | NetGear (XEB1004-100NAS) 4-Port Ethernet...
Got a hub genius GH4080SE and trying to connect computers, pls advise what is the steps?
Hardware Setup
1 Find the WAN or uplink port of the Ethernet hub. Typically, it is located on the rear of the unit, and it is often separate from the LAN ports.
2 Connect an Ethernet cable from the WAN port of the hub to either the Ethernet port of the internet modem or, if expanding a network, to an empty LAN port on the existing network’s router, switch or hub.
3 Plug an Ethernet cable into one of the LAN ports on the Ethernet hub and connect the other end of cable to the computer or device that will be added to the network. Repeat for any other devices that will need to be on the network.
4 Power up the Ethernet hub and the computers or other devices attached to it. On the front of the hub will be a series of LEDs that correspond to each LAN and WAN port on the hub. Every port that has a cable plugged into it should have one or more of the LEDs lit that represent that port. If not, check the connections and swap out the Ethernet cable if necessary.
Software Setup
1 Configure the network settings on each connected computer. If you are expanding a network and the network uses DCHP, or dynamic IP addressing, no configuration will be necessary. On networks using static IP addressing or on a new network setup using the Ethernet hub, each computer or device must be assigned a unique IP address. Local IP addresses must use the allowed “private” address pools that will not interfere with internet addresses. Acceptable addresses include 192.168.x.x, 172.16.x.x to 172.31.x.x, or 10.x.x.x. The “x” represents a number that is chosen by the user, from 0 to 254. All computers on the network should share the first three numbers in the address, with the final number representing the individual computer. In a network with three computers, for example, the first could be 192.168.1.1, the second could be 192.168.1.2 and the third could be 192.168.1.3, though the final number does not need to be sequential.
2 Click the “Start” button in Windows, select “Control Panel" and double-click the icon labeled “Network Connections.”
3 Right-click the icon for the Ethernet adapter and select “Properties.” Click on the check box marked “Internet Protocol (TCP/IP)” and press the “Properties” button.
4 Select the radio button labeled “Use the following IP address.” Enter a unique IP address for the computer and the applicable subnet mask. If a router is used on the network, enter the router’s IP address as the default gateway. Press the “OK” button and reboot if necessary.
5 Enable file and printer sharing from the “Properties” dialog for the Ethernet card if files will be transferred between the networked computers.
6 Click the “Start” button, select “Control Panel” and double-click on the “System” icon. Select the “Computer Name” tab and click on the button labeled “Change” to set the computer’s network name. In the “Computer Name” box, enter a unique name for the computer. In the “Member of” section, choose the radio button marked “Workgroup” and enter the workgroup of the network. If setting up a new network, this name can be change but all computers on the network must share the same workgroup name.
7 Verify that all computers can access the network and the Internet if connected.
Read more: How to Set up an Ethernet Hub | eHow.com http://www.ehow.com/how_4530475_set-up-ethernet-hub.html#ixzz0xnIzsGqa
see also Networking Diagram
Aug 27, 2010 | Genius GH 4080 SE 8-Port Ethernet Hub...
I can not connect to my hub from 10T-bese line
Check that your Ethernet cable is "good" (no broken wires)
and that it is not a "cross-over" cable.
Try a different cable.
Dec 08, 2009 | SMC EZ SWITCH PLUS (5018400)
Farallon nic "8970887-00-03" need XP driver
Looks like Farallon is long gone. Why don't you by a new ethernet adapter, they go for as little at $10 these days.
Aug 19, 2008 | Farallon NetLINE Network Adapter
Instruction Manual Farallon/Starlet/5 5 Port/10Mb Ethernet Hub
Here is The Instruction File In PDF
www.venturaes.com/coolstuff/ventura_catalog.pdf
Nov 27, 2007 | Farallon Starlet Networking Hub
Farallon Ether10-T Starlet/4 - What is it? How can I program it?
try using a direct connection or using a new hub if this dosent work ucan contact me
Aug 18, 2006 | Farallon Starlet Networking Hub
Farallon Starlet Networking Hub Logo
354 people viewed this question
Top Farallon Computers & Internet Experts
David Payne
David Payne
Are you a Farallon Computer and Internet Expert? Answer questions, earn points and help others
