Question about Panasonic SC-HT930 System
Error Message DVD H01
When I turn my receiver on I get an error message DVD H01 on the receiver diplay then shuts itself off. The disc drawer will not open. How can I fix this?
  • 1 more comment
  • bethsrequest Sep 18, 2008
    I have the same problem with my SA-HT740.  I was removing the discs and one slipped our of place.  An suggestions?
  • j33lap Jan 10, 2009
    dvd ho1 problem
  • Jessica Humann
    Jessica Humann Jan 26, 2009
    I get on error message DVD H01, then my system shuts off. what do i do....
SOURCE: Panasonic SC-HT650
from what i heard this is a common problem with this unit (mine included). apparently it cost more to fix than buying a new one.
Posted on Mar 08, 2007
SOURCE: Error code H01
I opened up by Panasonic dvd-cv52, which I purchased in Dec 2002 for H07.
The H07, based on research, indicated that the spindle motor had an issue, a post I found suggested trying some 3-in-1 oil.
I tried this and it worked (note, pop the top off firstm then power up the unit, then press the open button, then unplug the power, this will make it easier to lubricate).
Once I had done this and powere back up, I got h01.
Turns out I neglected to put back the elastic that is used to spin the carosel for the dvd's (I have a multi dvd player).
I would check to see if there is an elastic in place to spin the carosel, maybe your broke (assuming you have a multi carosel also)
Good Luck
Louie Whote
Posted on Dec 28, 2007
  • 4234 Answers
This indicates protect mode. One of the output amp pacs needs to be replaced. It is either part number: STK470-050 ($16) or RSN311W64D ($95)
Dan
Posted on Apr 09, 2008
robotek
  • 1512 Answers
SOURCE: NO DISC message
Hi there
I would suggest cleaning the laser lens with a lens cleaner disc first
Posted on May 06, 2008
  • 4234 Answers
Open up the unit and clean the lens using a cotton swab and alcohol. If that does not resolve the problem, try a music CD and report the results here. I suspect that the optics have begun to fail. If that is the case, the music CD will play but a DVD will not. The optics assembly is available (part # RAF3023A-1) for about $60.
Dan
FL 8350 CD Player. Disc drawer will not open. Getting error message
Most likely a belt has stretched and will not now move the tray. This happens of units more than 2 years old usually.
Dec 26, 2012 | Harman Kardon FL8350 5-Disc CD Changer
Tip
When you try to play a DVD game on Xbox 360 it tries to play as a movie?
c on your Xbox 360 console, you may receive an error message. This article presents step-by-step guidance to help you determine whether your disc is playable.
SYMPTOMS When you try to play a disc, you may receive the following error message: Can’t read this DVD.
CAUSE The DVD or game disc may be dirty or damaged. Because the console cannot read the disc well, it may even mistake a game disc for a DVD and report this error. If this problem occurs with multiple discs, even clean and undamaged discs, there may be a problem with your Xbox 360 console.
Note If you receive a different error message, such as one of the following messages, the problem is a different problem:
Error message 1 Can't play DVD. Wrong region code. Error message 2 Can’t play DVD. Family settings restrict playback of this DVD. If you receive one of these error messages, see the corresponding Knowledge Base article: 907620 While attempting to play a standard DVD movie using your Xbox 360 console, you receive the error message: "Can't play DVD. Wrong region code" 908645 While attempting to play a DVD movie using your Xbox 360 console, you receive the error message: "Can’t play DVD. Family settings restrict playback of this DVD"
THINGS TO TRY Here are some things that you can do to try to fix the problem or to determine what caused it.
Determine whether the disc is dirty or damaged Discs that are smudged, scratched, or otherwise damaged cannot be read by the Xbox 360 console. You will want to examine the disc to see whether it has smudges, scratches, or other damage. To do this, follow these steps: 1. Examine the disc for dirt or damage: a. Pick up the disc by its edges. Do not touch the top or bottom surface. b. Examine the shiny side of the disc to make sure that the disc is clean and has no damage.
NoteScratches that follow the curve of the disc are very damaging and prevent a disc from being read. If your disc has even one of these kinds of scratches, the disc is damaged, and you will no longer be able to play it. If this is the case, see step 4. 2. If the disc is dirty, clean the disc by hand: • Use a soft, clean, dry, chemical-free cloth to clean the disc. • Lightly wipe from the center of the disc outward. 3. After you clean the disc, try to load it in the Xbox 360 console. If the disc still will not load or you receive the same error message, the disc is damaged, and you will no longer be able to play it. If this is the case, see step 4. 4. If the disc is damaged, do one of the following: • Because DVD discs are not game discs and the disc was damaged because of misuse of some type, such as not storing the disc in its case, the only thing that you can do is buy a new one. • If you feel that the disc was damaged by the Xbox 360 console in some way, please contact Xbox Customer Support. To do this, please visit the following Microsoft Web site: http://www.xbox.com/support/contact
on Feb 18, 2010 | Video Game Consoles & Games
Yamaha dvd s-80 showing error code H01 when trying to play disc. What does this mean ?
The manual isn't much help, is it?
http://www.retrevo.com/support/Yamaha-DVD-S80-DVD-Players-manual/id/320ag210/t/2/
It seems the "H01" is some kind of common and fatal error code in many disc players and I have yet to find anyone who has paid the ransom, er cost, to get one fixed as it is cheaper and makes more economical sense to just buy a new unit...
http://www.electronicspoint.com/panasonic-sc-ht75-dvd-player-broken-t55762.html
Feb 11, 2011 | Yamaha DVX-S80 System
Error code 2881
Found error in image file, Error Occurred, error 0901, 572, 2881
The camera says found error in image file, repair data now. When you press yes it says "Error occurred. Please replace disc." or use ac adapter/charger, turn off power. It won't let you go to Disc Navigation to finalize it. While recording video on DVD-R media the battery power may have failed and camera shut off. When turned on the message shown on the lcd is Found error in image file, Error Occurred, error 0901.
Regards.
Jan 12, 2011 | Hitachi DZ-MV580E DVD Camcorder
Error Message: Condition 1
Error condition 1 is a faulty Fan. On these units if one fan is faulty then the sensor will shut the screen down as a protection.
a repair of this unit is possible.
Regards
May 12, 2010 | Fujitsu Plasmavision PDS-4214 42 in....
When i put an Xbox 360 game in it tries to play it as a DVD movie. please help!!!
When you try to play a DVD movie or an Xbox 360 game disc on your Xbox 360 console, you may receive an error message. This article presents step-by-step guidance to help you determine whether your disc is playable.
Feb 18, 2010 | Microsoft Xbox 360 Console
Dvd does not show what was recorded from my sony camcorder error message C13:02 flashing
This is Disc Access Error, Disk Access Error, Check disc error, Check disk, C error unreadable, disc error code 13, disk error code c1302, c:13:O2 DISC ERROR, Disc Error C:13:02 message Sony mini dvd finalize error code C1302 DVD not finalised, Rec Disabled Record Disable after dropping the camera, DVD not finalized, DVD Disc not finalized, DVD Disk not finalized, DVD Disc not finalised, DVD Disk not finalised, Disc won't finalize, Disk won't finalise DVD Disc Error, DVD Disk Error, DVD Disc Format Error, DVD Disk Format Error, Rec. Disable, not correct disk, the disk in drive is not formatted do you want to format it now.
Nov 15, 2009 | Motorcycles
Supported media list
try using a CD-R or a CD+R they are diffrent formatts its the same for dvds i had that problem with mine
Mar 24, 2009 | iLO DVDR05 DVD Recorder
Cdr20 drawer is jammed ERROR message
Try taking the unit apart it mostlikly jamed or jumped track try re ajusting it that would prob work, another thing is to try messing with the gears that could aslo work
Oct 18, 2008 | Harman Kardon CDR20 CD Player
"No Disc" error message
remove the cover of the unit and try to clean the lens with a soft clean dry cotton swab or if you have a compress air cleaner, just blow it. most of the time cleaning can solved this kind of problem. good luck!
Feb 21, 2008 | Panasonic DVD-S29 DVD Player
Panasonic SC-HT930 System Logo
345 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
