Question about LG LRSC26940ST 36" Side-by-Side Refrigerator w/ 26 Cu. Ft. Capacity, OptiChill Crisper & Jet Freezin...
LG LRSC26940ST Defrost Heater Problem
My LG LRSC26940ST Refrigerator displayed error code Er dh. Problem with the defrost heater. Need to replace but need some help with making sure I order the right part. I looked at Repair Clinic and found the defrost heater part but I don't see it anywhere in the Frige. Looked in the inner back of the freezer where the exploded view showed, but can't locate where the part would be. What part do I need and where is it located? Please help!
  • ourdesert
    ourdesert Aug 07, 2008
    Really need help!
  • 27 Answers
SOURCE: where is this fuse located on the LG refrigerator is displaying a ER DH code error
Hi. You have an Error Defrost Heater. Its taking too long for the heater sensor to open the circuit during defrost. You normally replace the heater, heater sensor and circuit board(motherboard) located on the back of the refrigerator in this situation. Check your mollex plugs and make sure they are connected tightly at the evaporator coil area. Sometimes they come loose. I reccommend replacing the heater and heater sensor located top right on the evaporator coil. This should take care of the problem. Need parts see me on ebay as user, themackshack. Good luck, Mack
Posted on Jan 06, 2008
  • 1122 Answers
GO TO SEARS .COM ,CLICK ON PARTS,PUT YOUR MODEL NUMBER IN AND YOU WILL FIND WHERE THE PART IS,LET ME KNOW-MIKE
Posted on Jul 07, 2008
thaurfen
  • 623 Answers
SOURCE: LG LRSC26940ST Defrost Heater Problem
call 411 for nearest lg lab
Posted on Aug 10, 2008
  • 864 Answers
SOURCE: LG code ER DH, Defrost Heater or Thermistor?
Check for current flow through the defrost heater. If no current then replace the heater. If heater is OK check thermistor for correct operation. From service manual chart (their words not mine): ER DH is Poor defrosting. Indicates: Even though it is passed 1 hour since then
Defrosting , if Defrosting
sensor is not over 8°
Remarks: Temperature fuse Disconnection,Heater
disconnection, DRAIN Jam,
Poor Relay for Heater
Posted on Aug 11, 2009
omaharox
  • 166 Answers
SOURCE: I a LG 22860sw refrigerator ERROR CODE DH
The main Pcb as well as the defrost thermistor are in the circuit as well.
The thermister is attached to the evaporator with wire ties and connects to the roof of the freezer behind the fan assy.
I have seen the thermister connector pull out of the connector at the top of the freezer beacuse the wires were to tight. Remove some of the wire ties and reinstall the connector.
Posted on Jan 17, 2010
Problems for Refrig. Kenmore Elite
The Er DH error code indicates the temperature sensor on the evaporator coil did not reach 50 degrees within one hour.
This would indicate the control board did put the refrigerator through a defrost cycle.
This problem could be caused by a defective relay on the control board, a defective defrost heater, a broken wire to the heater, or a stopped up drain on the defrost pan causing ice to form on the evaporator coil.
Before replacing the control board, someone should remove the food from the freezer, remove the freezer drawer, and remove the evaporator cover to expose the evaporator coil, heater, and defrost sensor.
The voltage to the defrost heater should be 120 volts ac.
The defrost heater is part of the evaporator coil and is not replaceable as a separate part.
You can test the operation of the defrost system by pressing "Ultra Ice" and "colder freezer temp" for 3 seconds.
The first time you press and hold the buttons the board will test the compressor, fan, and open the damper.
All displays should be on.
The second time you press and hold the buttons the board will test the compressor, fan, and close the damper.
The third time you press and hold the buttons, the board will turn the compressor and fan off and turn the defrost heater on for around 25 minutes. This would let you know if the defrost system is working.
http://knol.google.com/k/fixing-the-er-dh-code-on-kenmore-elite-trio#
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
May 03, 2010 | Kenmore 73502 / 73504 / 73509 Bottom...
I HAVE AN ERROR CODE dH on my Kenmore Elite bottom
Apr 14, 2010 | Kenmore 77554 / 77543 Bottom Freezer...
Refrigerator warm, display blank but freezer still works
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.*#$^
Feb 21, 2010 | Kenmore 24.8 cu. ft. TRIO Bottom Freezer...
Aug 11, 2009 | LG LFX25960ST Stainless Steel French Door...
Door display shows ER WITH A UPSIDE DOWN HP. I turn the power off and back on and the display goes back to normal but after several hours it goes back to where the only thing on the display is the ER PH...
That stands for "error defrost heater"
Even though the refrigerator has gone through a defrost cycle, if a temp sensor does not reach a set temp within an hour, that error will display. You may have a bad defrost heater, defrost relay, thermal fuse, blocked defrost drain,..... something wrong with the defrost system anyway.
Aug 03, 2009 | LG LFX25960ST Stainless Steel French Door...
Er dh code error on Kenmore elite trio
Jul 11, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Kenmore Elite Refrigerator error er dh
Sep 21, 2008 | Kenmore 24.8 cu. ft. TRIO Bottom Freezer...
LG Refrigerator Defrost Error ER DH
it the def t-stat, def. thermistor, or def. fuse whatever lg decides to call it this week that is causing your issue
Jun 13, 2008 | Refrigerators
Where is this fuse located on the LG refrigerator is displaying a ER DH code error
Jan 02, 2008 | LG LRBC22544 Bottom Freezer Refrigerator
LG Refrigerator
That stands for a defrost heater problem. Usually it's the defrost detect circuit that has a blown thermal fuse.
Dec 16, 2007 | LG LRBC22544 Bottom Freezer Refrigerator
LG LRSC26940ST 36" Side-by-Side Refrigerator w/ 26 Cu. Ft. Capacity, OptiChill Crisper & Jet Freezin... Logo
135 people viewed this question
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
