Question about Optoma EP737 - DLP PROJECTOR - 1500 LUMENS *NIC* Multimedia Projector
Optoma DLP projector EP 731 bottom (approx. 25%) of image is very dark. New lamp did not help. if picture is inverted top-to-bottom, dark area remains on bottom.
  • jackt731 Aug 07, 2008
    Proposed solution referred to LCD. This is not an LCD projector. It is DLP
  • Anonymous Mar 11, 2014
    Removing baffles from 4" Vance & Hines Twin Slash mufflers
    Genius:
  • 1,689 Answers
There is a possibility that the polarized filtering sheet is damaged or is out of place, you may need to bring it to an LCD specialist or an authorized repair shop for the brand.
Posted on Aug 07, 2008
  • marlon john madrid
    marlon john madrid Aug 07, 2008
    if that is the case then have you checked the status of your mercury vapor arc lamp unit, the lighting system or the LED lamp? you mention you replaced a bulb in the unit earlier thats why i asked.
    now if the light source is okay, you may want to check on the projector chips, one that allows the projector to produce separate green blue and red colors, because the shading of the image produced controlled by the projector chips.
    Master:
  • 555 Answers
This sounds like an LCD shading problem. Optoma or an authorized service technician will need to replace the LCD filter.
Lamp comes on briefly and then goes out
Check poewer connection
Check if fan filder is dirty ( if it is just hoover it out)
If "lamp" light on top of the projector blinks or stays lit - lamp probably faulty
How old is the Projector/lamp (average lamp life is around 2000-3000 hours)
Mar 01, 2011 | Optoma EP719 DLP Projector
The image of my optoma hd803 became inverted.
Go into menu settings, look for a menu item that has to do with screen size and orientation. You'll be looking for the option to rotate the image for mounting the projector upside down on a ceiling mount.
Feb 06, 2010 | Optoma HD803 DLP Projector
High temp light on when powering up
Remove the screws and check out the fan's working state.
EP759 have one big 92mm fan for the lamp, and three small, near 40mm, fan's for the optics.
Power of the bulb is very high, so just 1 broken fan can make that situation.
Apr 25, 2009 | Optoma EP759 - HDTV Compatible DLP...
Optoma ep 706, lamp lights on,replaced lamp, still not working
moz-screenshot.jpgmoz-screenshot-1.jpghello,
This is an unfortunate incidence and i will send you the serviceable manual of your projector if you can send me your contact email address to my email.Yes ,there are instruction to follow to replace lamps in projector if not you might miss it. First you must confirm that the lamp is OK from the vendors you purchase before anything.
Bye.
anytony2004@yahoo.com
Aniekeme Anthony.
I
Jan 21, 2009 | Optoma EP706 DLP Projector
Dark or no image at all
CHECK THE LAMP IF THE LAMP LUSTER HAS GONE OUT OR THE FILAMENT AT DOWN PORTION IS BLACK THEN THIS PROBLEM HAPPEN
Dec 08, 2008 | Optoma EP716 Multimedia Projector
Optoma EP Portable Projector - No Power
if the lamp asssembly isnt screwed in tight the unit will not power on. i did have a faulty lamp once, try fitting the old one back to check first. if not the power supply is faulty on the main board or a short in the supply to the lamp can cause this fault.
Nov 01, 2008 | Optoma EP719 XGA DLP PROJECTOR 2000L...
Optoma DLP EP719
Try this: There is a stuffed 10v 3300uf capacitor on the power board. You need to replace it.
Bellow you can check in the picture where the capacitor is located.
Notice that in this picture I have already took the bad capacitor out and replaced with two small cords to reach the bottom and test the new capacitor.
To reach this place is not fast, several layers of plastic and metal must be removed, but is not a hard task to take the capacitor out and replace it for another.
It works just great! Now it is back on track with awesome image.
Jun 26, 2008 | Optoma EP719 XGA DLP PROJECTOR 2000L...
Help needed for Optoma EP 719 DLP PROJECTOR
It's a setting in the menu. A few minutes poking around will fix it.
Jun 12, 2008 | Optoma EP719 XGA DLP PROJECTOR 2000L...
EP 757 Intermittent powering down
Pls check if the lamp is not so old that is giving the same problem. If lamp is almost new, then you can have a check with the Ballast unit card and then the loose connection in the Power supply or may be overheating and tripping.
Viren
Nov 18, 2007 | Optoma EP737 - DLP PROJECTOR - 1500 LUMENS...
258 people viewed this question
Top Optoma Office Equipment & Supplies Experts
jasbo
jasbo
color wheel light...
Are you an Optoma Office Equipment and Supply Expert? Answer questions, earn points and help others
