Question about Whirlpool Ultimate Care II LSQ9549L Top Load Washer
Agitator Dogs How to replace dogs
How does the fabric softener dispenser come off the top of the agitator?
Posted on Jan 11, 2009
  • 481 Answers
Take the cap or fabric softener dispenser off the top of the agitator. under it should be a clear plastic cap with a little handle on it. take it out. under it should be a bolt (7/16) with a rubber seal under it, take it out and this will release the agitator and you will see the plastic dogs inside the agitator.
Posted on Aug 12, 2008
The agitation does not work like it should!
I suspect u have bad agitator dogs
check THE CAM DOGS INSIDE THE AGITATOR, AS THEY WILL HINDER THE AGITATION PROCESS. However in G.E models the cam dogs are replaced with what is called an agitator coupler. (located at bottom of tub)
Remember to check the agitator spline as well. for worn broken teeth
By the way my advice is free cuz God is good!
25712554-jkb5ybrklduaa4afh4xyzipe-4-9.jpg however if u have a G.E U HAVE A AGITATOR COUPLER INSTEAD OF CAM DOGS SEE FOLLOWING PICS
May 25, 2015 | Washing Machines
Whirlpool washer agitator not working
You most likely need to replace the dogs in the agitator, two piece agitator design. It should spin one way and catch the other on the teeth of the dogs. It will spin freely either way when the dogs are wore out. This is for the top half of the agitator, bottom is fitted to transmission shaft. You pop the top cover, remove the 7/16 bolt and both halves together to change dogs of agitator. Pull halves apart to change dogs. Fairly simple.
Jul 31, 2011 | Whirlpool Washing Machines
Need to replace the agitator dogs and can't remove the mover from the bottom section
Direct drive Whirlpool washing machines use a two piece agitator. In-between the two pieces there are cogs, sometimes referred to as "dogs," which will wear out. When the dogs start to wear, you will notice a clicking sound and the top agitator will not move as it should. When you learn how to replace the agitator dogs on a Whirlpool washing machine, you can have your Whirlpool working correctly again. Agitator dogs are available at appliance repair facilities.
* 1
Disconnect the Whirlpool washer from the wall outlet. Open the washer lid to access the agitator.
* 2
Insert a flathead screwdriver in the notch in the agitator cap. Twist the screwdriver to pop the agitator cap off of the agitator. If your model has an inner cap, remove the inner cap by pulling up on the handle and removing it from the agitator.
* 3
Use a socket wrench to remove the bolt in the center of the agitator. Most Whirlpool washers use a 7/16-inch bolt to secure the agitator.
* 4
Grab the bottom of the agitator with both hands and pull it straight up out of the wash tub. Do not have your face directly over the agitator. If it is stuck or pops up too quickly you could injure yourself.
* 5
Set the agitator on the floor and carefully place your feet on each side of the agitator. Grasp the top of the agitator and pull the top half of the agitator off of the bottom half. Turn the top half over to access the dogs.
* 6
Use needle nose pliers to pull the dogs out of the agitator. Install the replacement dogs into the agitator according to the specifications given the manufacturer.
* 7
Set the top half of the agitator back on to the bottom half. Make sure to align the two tabs together between the halves so that they will friction fit. Grab the bottom of the agitator and apply a thin coat of dishwashing detergent on the rubber gasket on the bottom using your finger.
* 8
Set the agitator back into the wash tub and secure it using the retaining bolt. If your model had an inner cap, set the inner cap back into the agitator until it snaps into place.
* 9
Place the top of the agitator into place and press down until it locks into place.
Mar 21, 2011 | Whirlpool Washing Machines
The agitator is not moving as well as it should. It turns very little. Should it not be agitating aggressively?
You have (agitating dogs) in the bottom of your washing machine. These little plastic pieces tend to wear out over time or from overloading. These can be replaced, cost about $5 for for 4 of these (dogs). Take the very top piece of the agitator off, it spins off. There's a bolt in the bottom of the agitator that will have to be removed. After it's removed, you can pull the agitator out. You will see the little (dogs). It's a very simple task, and takes about 10 min to do this. Look up (picture of agitator dogs) this will give you a better view at what you are looking at.
Mar 04, 2010 | Roper RAX4232KQ Top Load Washer
The top part of the aggatator does not turn
Washer has trouble agitating... Check the agitator dogs inside the top of the agitator, they are bad for wearing out, sometimes the agitator may only agitate one way when the dogs are worn out. This is an instruction sheet that came with the last parts I ordered for a Whirlpool/Inglis style direct drive washer agitator. If you need to replace your agitator dogs, please see this link for some repair aid.
Replace the dogs its a easy fix for you
Dec 28, 2009 | Whirlpool Washing Machines
Top agitator of a dual agitator systems just free wheel. Looks like the dogs of the main agitator do not engage on the other agitator any more.
Your problem may just be attributed to just a loose agitator bolt, or the agitator dogs require replacement.
Whirlpool uses a split agitator design. The upper portion is called the auger, while the bottom is called the agitator. Between these components is a agitator cam assembly. This problem is commonly caused by worn agitator dogs or the agitator cam assembly. The following link explains what the dogs are and how to replace them:
http://www.fixya.com/support/r823955-replacing_agitator_dogs
The part number is included in the link provided. You can purchase replacements at pcappliancerepair.com for about $5. For a little more you can purchase the entire cam replacement kit, which includes the cam, the thrust bearing, and the dogs.
NOTE: You can refer to the excellent exploded view parts diagrams the web site has to offer for assistance. Whirlpool also recommends the application of a little grease on the thrust washer. The part number for their recommended grease is AP3098553.
If you have any questions about this repair, please post back with your complete model number and let me know. I hope this helps you.
NOTE: DO NOT overtighten the agitator bolt. This can cause damage to the plastic, or restrict the agitator movement. Tighten until snug only.
Dec 09, 2009 | Dishwashers
Agitator not working
Hi, This agitator is a 2 piece agitator. Can you see if the lower half on the agitator is working properly? If the lower part is working and the top is not, you will need to change the agitator dogs. If neither half are working, you might be having transmission issues.
To change the dog kit, re,ove the top cap on the agitator and locate a 7/16" bolt. Remove the bolt and the agitator will lift out. Pull the agitator apart and the dogs are 4 small plastic pieces inside the top half of the agitator.
Please let me know if this helps you or if I can assist you further.
Thanks
Vic
Sep 13, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Not agitating
does it have the dual agitator
Aug 06, 2009 | Amana NTW5205TQ Top Load Washer
Top agitator not working properly
Check the agitator by turning it back and forth. It should work like a ratchet (turns one way, locks the other way).If you're able to turn it in both directions, the agitator dogs are worn and need to be replaced. To do this remove the agitator cap and the bolt that holds down the agitator. With the bolt out you can remove the top section of the agitator (auger) where you should see 4 small white or beige plastic gears (dogs). Replace those and it should be ok.
Agitator dogs part number is 80040
Mar 03, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool Ultimate Care II LSQ9549L Top Load Washer Logo
281 people viewed this question
Dan Webster
Dan Webster
Sal De GO PATS
