Question about Sony KDF-E60A20 60 in. LCD HDTV
Sony 40 inch lcd television
Tv is about 1 year old. just noticed two thin vertical lines, maybe 1/2 inch long. they seem to be growing in length, when the screen is white the lines are red, and they do change color with the color on the screen. One of the lines is right in the center of the screen so its getting really annoying. I know the screen has not been damaged at all. is there anything that can be done, and should I expect these lines to continue to grow in length?
    Scholar:
  • 38 Answers
Call Sony!! It Will get worse!!! The panel has ribbons that have fine wires that are used to show each line of information on the screen. Either the panel is going or the wires are loose. Either way, the panel needs replacing. Just hope to God it's under warranty or if not, sony will help you out with a buy-out.
Posted on Dec 05, 2008
SOURCE:
I have a Sony 26 inch Bravia LCD tv model KDL-V26XBR1.It has thin vertical black and yellow lines about an inch apart across the whole display. Not noticeable from a distance but really see them up...
Well if the panel is bad it would not clear up in any situation, so its not the panel. most likely the t-con board or just poor connections inside. Julio Millenium TV in Las Vegas.
Dec 18, 2009 | Sony BRAVIA XBR KDL-V26XBR1 26 in. LCD...
My SOny Bravia 40 inch LCD TV has a vertical line
It could be 1 of 4 things:
1. One of the ribbon cables has worked itself loose (Simple Fix)
2. One of the assembly boards maybe faulty
3. The driver board which feeds the panel maybe faulty
4. The panel is faulty
The driver board in the UK costs approx £70 and approx £35-70 to fit it if this is the fault.
All other parts are between £80-160 and approx £35-70 to fit it if this is the fault.
The panel will cost approx 50-75% of what the TV was worth when you bought it - "Repair versus Replacement"
Thanks
Oct 01, 2009 | Sony BRAVIA KDL-40S2010 40 in. LCD...
Exact problem
This is an internal malfunction, deffinately use the warranty on it. If you decide to fix it yourself post again and I'll walk you through changing the LCD controller. Its not too challenging, but will require you to dismantle almost the entire tv.
Jul 28, 2009 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
My Sony KDL-32XBR4 has vertical lines for 5-15 minutes on startup
I have a 46 inch , Sony XBR 4 tv . The past week there has colored vertical lines that appear on the screen for about 10 minutes . Then they go away . What is the problem and solution?
Jul 10, 2009 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
Thin Vertical Line top to bottom about 2 inches from the right.
Probable panel is bad. contact mitsubishi maybe they will do somthing for you.
Jun 26, 2009 | Mitsubishi WD62527 62 in. LCD HDTV
Thin vertical line
You are going to find it is a LCD panel problem. I am sure that they will take care of you. But also realize that this could have happen to any brand of LCD panel and you will probably not have any other panel issues once it is fixed.
I feel your pain,
Skyassoc
Jun 21, 2009 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Vertical line on LCD TV Panel
Had this same issue on right side of 52" about 1 inch from side but had 3 vertical lines that disappeared after 40 minutes. Have Samsung LNT5265FX/XXA and about 16 months old. LCD Panel itself had to be replaced to fix it, fortunately had extended service plan
Oct 17, 2008 | LG 42LC2D 42 in. LCD HDTV
Lcd tv screen shadow
they call that line pixels and the only way to fix is a new lcd panel. if you have under 8 pixels your warrinty won!t cover with some companys
Aug 31, 2008 | Sylvania 6427TE 27" TV
Thin vertical red line
This maybe the symptom of a bad Panel. One Vertically This line is 99% bad panel. Call your warranty provider or SONY tech support if purchased under 2 years.
Best regards
CircuitCity
Nov 25, 2007 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Sony Bravia XBR 40" LCD
First, HORIZONTAL CENTER.
1) Press MENU.
2) Scroll to SETTINGS.
3) Scroll to SCREEN.
4) Go to HORIZONTAL CENTER. Move the picture to the right. Hopefully, the line will go away. Otherwise, there is a problem with the pixels or the signal processor. Call 1-800-222-SONY. Or, http://eservice.sony.com. Have a high-limit credit card handy for out of warranty repairs. Sorry about that.
Aug 27, 2007 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Sony KDF-E60A20 60 in. LCD HDTV Logo
111 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
