Question about Maytag Microwave Ovens
Maytay micro hood model MMV5165BAS stops while cooking popcorm with error message E-63. What does this mean?
  • Maytag Master
  • 9,098 Answers
Food not cooking in center
What make and model?? Sounds like it is not a carousel model. Have you tried a "Micro Go Round" ?? Otherwise, try rotating the 'plate' each quarter cycle...ie; every 30 seconds on a 2 minute cook time. Be sure to push the stop button first before you open the door to save wear and tear on the door switches......
Nov 04, 2013 | Microwave Ovens
E3 error message on prestinge induction Cook. Not able to do any operation, as soon as we power on the cook, it goes to E 3, It is only 3 hours old. Please help me.
E3 generally means a control board error.
If it didn't get damp with steam from cooking, take it back and exchange it.
Hope that helps.
Jan 24, 2011 | Microwave Ovens
Maytag Microwave model MMV5165BAS. Doesn't heat
HI. in most cases, this will lead to a failed Heating device(magnetron tube).It would be wise to check the Magnetron cutoff fuse to be sure of its integrity. if the fuse is blown, simply replace it. if the fuse continues to show continuity, replace the magnetron.
(((The fuse is located inside the unit along side the magnetron)))
Sep 10, 2009 | Microwave Ovens
Recirculating over the range micro does not take care of steam
Mayny reason. Does it vent outside? If not you are not getting a great amount of air flow. Are you filters clean? Dirty filters will stop max air movement. These are not the best machines for moving air but they sure are great spacemakers. Not sure if this can be fixed by any means other than a true vent hood.
Jan 26, 2009 | Maytag MMV4205 Microwave Oven
Micro Wave shuts down
If it stops after 22 seconds, that means the controller has detected a problem, usually a problem with the inverter or a bad magnetron.
Due to the lethal voltages used and produced, I do not recommend that an inexperienced person work on these.
You can find an authorized Panasonic servicer here.
Nov 19, 2008 | Panasonic NN-S443WF / NN-S443BF 1200 Watts...
We have a brand new Maytag mmv5165BAS over range microwave oven. When we tried to make microwave popcorn using the 'Popcorn' control, the microwave stopped early and the display read E-63. What does...
E63 is a "T1 Max Time" error. It indicates a problem on the control board.
The first thing to try is a "hard reset". Unplug it from the power line for a few minutes, plug it back in, set the clock, then try again.
Keep a close eye on it, and if it fails again, you want to contact Maytag for free warranty repair.
We're happy to help and we appreciate your thoughtful rating of our answer.
May 24, 2008 | Maytag Microwave Ovens
ERROR CODE E 63 COMES ON AFTER 2 MINUTES ON SAMSUNG MICROWAVE
I'm not finding that error code.
Does it come on 2 minutes after you plug it in?
If so, it may be a failing keypad or door switch / mount.
Of two minutes after you have been cooking?
That may indicate a bad humidity or other sensor.
Please give more detials so we can help further.
Oct 21, 2007 | Microwave Ovens
Microwave Ovens Logo
152 people viewed this question
Top Maytag Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Maytag Microwave Oven Expert? Answer questions, earn points and help others
