Question about Mitsubishi Televison & Video
My Mother has the VS-5003R big screen television that she purchased back in 1990. the television portion works fine but the ext-1 and ext-2 inputs are locked from a code that probably died with my father a few years ago. I am trying to get a dvd and a game system hooked into these two inputs to keep her grandkids entertained. I have no code for the television what can I do??
I have the same tv and same issue. I found chain of notes indicating that you can clear the lock by pressing 9-QV (two buttons) on the original remote at the same time. This works... however if you change the input again the EXT1 and EXT2 inputs will be locked again. It would be really nice if you can remove the lock feature completely.
Posted on Sep 13, 2008
I hit a button and Ext-1 is on the screen
You are on input 1( external 1). Press input button to choose what you want.
Mar 28, 2014 | Mitsubishi Televison & Video
Remove screen on Mitsubishi VS-5003R to clean the inside
screen unit is removed from front--remove speaker grill and some screws at bottom of screen and it lifts up and off.
Jun 05, 2012 | Televison & Video
Vs-5003r, unlock, I have original remote
Since you have the original Mitsubishi remote, you can try the following.
Select the input or select the unlock from the menu
When it asks for the code press and hold the QV button on the remote, then press the number 9.
That should unlock the set.
I hope that this helps you with this issue.
Thanks for usning Fixya.
asnowman
Oct 17, 2009 | Mitsubishi Televison & Video
I need 4 digit ''input''code a 1990 VS-4501R big screen mitsubishi.
If you have the original remote or at least one with a QV button on your remote it is easy.
When prompted for the code, Just hold down the "QV" and the number 9 together for a bit.
That will unlock the set.
I would then go the the main menu and unlock the set from the menu. Use the "QV" and 9 to get in and turn off the password.
I hope this information allows you to resolve this issue.
If I have helped you, please help me, and rate this suggestion the highest FixYa rating. (Two Thumbs Up)
Please Note: If you can not rate this post with the highest rating, then please do not leave any rating. I am doing this for free and I do not think that any rating other that the best is needed.
If you need further assistance please comment to this post and I will try to help you further.
Aug 07, 2009 | Televison & Video
Mitsubishi VS-5003R close caption
That is so old I can't find specs on it.If you have a cable box, Directv or Dish Network you can turn on cc from the Receiver box or even an antenna converter box
Mar 29, 2009 | Mitsubishi WD-62725 62" Rear Projection...
Mitsubishi VS-5003R Tuner Out
the tuner is where the cable hooks up on the back of the tv.its out and needs replaced.thats what the message means
Jan 24, 2009 | Hitachi 53UWX10B 53" Rear Projection...
Mitsubishi VS-5003R TV is on but won't connect to cable.
this is the service menu , try to exit out of it , if you can't turn off power on both cable box and tv then unplug both of them and disconnect the cable from the tv , leave it unplugged for at least 10 min , then try it again , if it still does it then the crystal that is connected to the IR sensor and EEPROM IC needs to be replaced as the IR sensor should be also replaced
hope it comes out of that!, if not we can try to set the menu settings for it being like a clock and #1 on the remote to exit the menu
let me know what happens , thanks,
electech
Oct 21, 2008 | Hitachi 53UWX10B 53" Rear Projection...
Menu won't turn off
to reset the whole tv press menu 1 2 3 enter
Jul 03, 2007 | Mitsubishi VS-60803 60" Rear Projection...
Blue screen
check the agc circuit it is becomming defected.good luck.
May 16, 2007 | Mitsubishi VS-60703 60" Rear Projection...
Locked ext inputs
I'll give you the master reset, with set on, and from the remote hit Menu-1-2-7-0 this will bring up the Intilize screen and the word Initlize should be highlighted, if it is hit enter on the remote, this is the factory default settings so now if the set ask for a parental code it will be 0000
Nov 06, 2006 | Mitsubishi VS-45607 45" Rear Projection...
Televison & Video Logo
110 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
