Question about Brother MFC 210C All-In-One InkJet Printer
How do I turn off ecm on Brother MFC 4800 and change baud rate. There is no options in the normal menu. I expect there is an option in a hidden maintenance but I can't figure out how to access the menu.
Mix-it-up
  • 832 Answers
SOURCE: Brother MFC-410CN Ink Jet Problem
Please push menu button then start mono then 4x arrow up. Display should be ||maintenance|| and printer should beep. What error code does the display show up?
Posted on Sep 17, 2007
  • 24 Answers
SOURCE: change baud rate
Baud Rate is to lower the transmission speed of the fax, however these are the temp settings and once the power is off you have to reconfigure that. Follow the following steps :
From the front panel:
  1. Press and hold the * key for 3 to 5 seconds until the display screen reads Test -001+ .
  2. Enter in 620 on the key board, and press the Check Mark and the screen will read Cfg param id:
    1. Enter the parameter ____ on the key board and press the Check Mark.
    1. 159 - Receiving Fax baud rate
    • 153 - Transmitting Fax baud rate
    1. The screen will read Cfg param val: 26
    1. Enter in the value ____ and then press the Check Mark .
    1. 0 = V.17 14400
    • 2 = V.17 9600
    • 6 = V.29 9600
    • 10 = V.27 2400
    1. Screen will read Test -001+
    2. Press the Reset button until you get back to Ready
    Posted on Jan 22, 2008
    CarlGehrke
    • 169 Answers
    SOURCE: Not able to scan to pdf file with Brother MFC-240C
    What you seem to want to do is not possible. Let me explain:
    A file that has its data in the Adobe company Portable Document Format (or a pdf file) contains various objects that are described to the computer using a superset of the PostScript language, some of them can be images.
    A file that comes from the scanner is first a very organized set of pixels and gets put into a more compact form by using a well known process as defined by the Joint Motion Picture Experts group. This is a roundabout way of saying that it has a format that isn't PDF.
    What you CAN do:
    a) open the jpeg file with a Macintosh, using the Print command from the file menu make a pdf file that has the image in it.
    b) buy and install a PDF printer driver on a Windows machine, and then follow the same process as A above.
    c) Use your favorite PDF creation program to make a file with the image embedded.
    Carl
    Posted on Dec 10, 2008
    faxman789
    • 297 Answers
    SOURCE: Brother MFC-210C All-In-One InkJet Printer ERROR 4F
    Access the internal maintenance mode by pressing the Menu/Set button, then press * 2 8 6 4 within 2 seconds.
    This should put you in the maintenance mode menu.
    Enter 80, then scroll down with the arrow down (round) key.
    You'll find an entry listed as purge count.
    If number is over 6000, enter 2 7 8 3.
    This will reset the purge count value. Then restart you printer.
    Posted on Jan 22, 2009
    SOURCE: Brother MFC-7820N Toner Problem
    Open the cover, press Options and then *00.
    Posted on May 22, 2009
    Change baud rate on brother fax machine
    Lowering the Baud rate on Brother fax machines.
    • Press the Menu or Menu/Set key. Then Fax, Miscellaneous and Compatibility.
    • Press the Up or Down key until you can select Basic. Basic reduces the modem speed to 9600 bps.
    • Press OK or Menu/Set or Set key.
    • Press Stop/Exit.
    Note these instructions should work for the following models: Fax-1835C, Fax-1840C, Fax-1940CN, Fax-2440C, Fax-2820, Fax-2825, Fax-2920, MFC-210C, MFC-215C, MFC-240C, MFC-3240C, MFC-3340c, and most other MFC models.
    http://www.voipmechanic.com/voip-fax-settings-9600-baud.htm
    Mar 06, 2012 | Brother FAX-8360P Plain Paper Laser
    Change baud rate for brother fax
    • Press Stop/Exit.
    I'd like to turn off ECM on my intellifax 2820
    There is no option to turn off the ECM on Brother Intellifax 2820 , just set the compatibility to Basic so that the ECM feature will not be available. Just press Menu 201. Press down or up arrow key to select Basic.Press Menu/set and then Stop/exit.
    Hope this helps. Rate if it works. Thanks
    Apr 13, 2011 | Brother IntelliFax-2820 Laser Fax
    How do I turn off ECM in my Brother MFC 8220?
    From the Brother website:
    If you are using Voice Over Internet Protocol (VoIP), (a technology that allows you to make telephone calls using a broadband Internet connection instead of a regular (or analog) phone line, review the information listed below. If you are not using VoIP continue to Step 8.
    Voice Over Internet Protocol (VoIP) is not a marketed feature of your Brother machine, however there is a compatibility setting available with this machine that may assist with sending and receiving faxes when using VoIP. Adjusting this setting lowers the baud rate (modem speed) and turns ECM (Error Correction Mode) Off. To adjust this setting follow the steps listed below:
    1. Press Menu or Menu/Set => Fax => Miscellaneous => Compatibility.
    2. Select Basic.
    3. Press OK or Menu/Set. (For touchscreen models, skip this step.)
    4. Press Stop/Exit.
    Jan 07, 2011 | Brother MFC-8220 Fax
    I cant figure out how to lower the baud rate on a brother intellifax 3800
    On Brother machines the baud rate is set automatically during the handshake with the other machines, turning off the ECM usually helps when you are getting a lot of communication errors.
    Sep 01, 2009 | Brother IntelliFAX 3800 Plain Paper Laser...
    I need to change a baud rate to9600 for telephone line. can you direct me please.
    How to change the baud rate....
    Press Menu/Set, 2, 0, 1.
    Press ▲ or ▼ to select Basic or
    Normal (or High*).
    Press Menu/Set.
    Press Stop/Exit.
    * High is available for FAX-2910, FAX-2920
    and MFC-7225 only.
    Note
    bps. Unless interference is a recurring
    problem on your phone line, you may
    prefer to use it only when needed.
    Normal sets the modem speed at
    14400 bps.
    High sets the modem speed at
    33600 bps..
    Jul 29, 2009 | Brother Office Equipment & Supplies
    4800 baud rate communication in vb
    You have to change it on both side!
    If you are communicating your PC with a serial device, BOTH must have the same speed (serial device: 4800, pc: 4800)
    Have you done it?
    Most devices DEFAULT settings are 9600 baud rate, N, stopbit1.
    But you can change it depending on the device...
    Jan 03, 2009 | Computers & Internet
    Change LCD language to English on Brother MFC-3240C
    Gud Day!
    Power on your printer. Press the menu of your printer then sect the arrow down or up to select the language menu. press ok if u have seen language then go to option select from german to english.
    Please rate the solution after you have tried it so that I can assess you more on this problem.
    Jonags
    Dec 11, 2008 | Brother MFC-3240C All-In-One InkJet...
    Baud rate
    # Lower the fax transmission speed to 14400 or even 9600 bps, as some older fax machines are not capable of receiving a fax at a high speed. To do so:
    1. Press the Fax button, then press Options untill it gets to ADVANCED FAX.
    2. Press Select.
    3. Press Options untill it getsl MAX SEND SPEED appears on the LCD display.
    4. Change it to 9600 BPS using the - (left arrow) button.
    5. Press Select.
    # Turn off ECM (Error Correction Mode) by pressing the following keys on the operator panel:
    1. Press the Fax button, then press Option untill it gets to ADVANCED FAX.
    2. Press Select.
    3. Press Options until ERROR CORRECTION appears on the LCD display.
    4. Change the setting from On to Off using the + (right arrow) button.
    5. Press Select.
    Note: Turning off this option makes it possible to receive a fax when the receiver fax machine does not support certain error correction modes.
    Mar 15, 2008 | Lexmark X5470 All-In-One InkJet Printer
    Any way to manually LOWER the Fax Connection Baud Rate?
    Newer fax technology adjusts transmission speed automatcally, so no adjustment is necesary. therefore, there is no menu option to change it. Your problem resides either on your phone line or the one you are trying to connect to. Call the other people and ask them if thei are receiving without problem. If you are able to transmit elsewhere and the other party is receiving from everywhere, try turning off the ECM option on your unit.
    Oct 27, 2007 | Samsung SCX 4521F All-In-One Laser Printer
    Brother MFC 210C All-In-One InkJet Printer Logo
    357 people viewed this question
    James Cagle
    James Cagle
    Samyfam
    Samyfam
    Victorman
    Victorman
