Question about HP OfficeJet 6110 All-In-One InkJet Printer
How do I override the alignment that keeps failing
I read on here once how to override the Failed Alignment It had something to do with hold down menu and hit cancel or something like that but I cant remember. PLEASE HELP.
    Master:
  • 521 Answers
Just press the cancel button once or twice after you on the printer wait a moment till the cartridges adjust inside properly.
Posted on Aug 08, 2008
My Hp c309 all in one printer keeps saying alignment failed. I recently changed all the ink cartridges and it shows that all are full but alignment STILL keeps failing... if I start to print something, it...
Regarding your recent inquiry about the HP 564 cartridge error ("Alignment Failed") which is preventing printing to your HP printer, please perform the following steps to see if the issue can be corrected....
NOTE: For "incorrect cartridge / "missing or damaged" error messages, please attempt to bypass the error message by selecting \'Ok\' on the printer several times. NOTE: You may also need to load the FULL printer driver versions from HP\'s website; once installed you should be able to bypass error messages via the various alert / windows prompts. Additional corrective action suggestions are provided below.
DIAGNOSTIC TESTS / RECOVERY SUGGESTIONS:
1) If you received an "Unauthorized ink", "non-HP ink", "counterfeit ink" or similar message, you can simply ignore/dismiss these messages by pressing \'OK\' once for each cartridge, so that the printer resumes its normal operation. If you do not have the full printer driver version installed it is possible that you may not be able to see the cartridge error bypass option - you may need to install the complete printer driver version for your computer\'s operating system. Receiving these kinds of ongoing alert messages is COMPLETELY NORMAL when using refilled ink cartridges. Refer to NOTE 2 below for more information. Refilling the ink cartridges does not include reprogramming of the ink cartridges, so this will not be a factor: http://inkjet411.com/?page_id=1407
2) Remove ink cartridge and inspect cartridge\'s smart chip surface (i.e. gold contacts) - check for scratches or ink residue. See pictures of cartridge chips at following link for reference (see \'Abnormal Cartridge Errors\'): http://inkjet411.com/?page_id=1925
- Replace cartridge if suspected damaged.
3) Perform Tap 41 PRINTHEAD Health Diagnostics Test (menu access varies by printer model, refer to HP printer diagnostics document, page 45, to view normal display messages, http://inkjet411.com/?page_id=1813 )
1. Turn ON the printer.
2. Press and Hold the "Print Photos" & "Red Eye Removal" buttons.
3. Release both buttons - screen should display "Enter Special Key Combo"
4. Press and release in sequence the "Red Eye Removal", "Print Photos", and then "Red Eye Removal"
5. Scroll through the menu by pressing the right arrow button until the display says \'Special Reports\'.
6. Select Ok, then press the arrow button until the \'print-mech button tap\' menu is displayed.
7. Select Ok (Code = 0 will be displayed); click and hold Right Arrow until \'code = 41\' is displayed.
8. Select Ok. The test page prints. If not, repeat steps 2-7 and enter \'code = 43\', select Ok.
9. Check the 4th line at the top of the printed report; an electrically good/stable PRINTHEAD \'Pen Status\' will state "Pen Status: Pen OK".........if any other message is displayed then the PRINTHEAD may have failed and may need to be replaced (as available). It is suggested to perform the \'Printer Reset\' procedure below to rule out printer firmware related problem.
a. If Step 2. does not allow service menu access, then press the \'Return\' and \'Home\' keys simultaneously so the Engineering Menu is displayed [or depress the \'Return\' button four (4) times]
b. Select Service Menu. Use arrow keys to advance to the Special Reports Menu. Select OK. Perform steps 6-9.
NOTE: The Tap 10 extended self-test print may also be initiated via \'code = 10\' (use to verify ink nozzle/jetting performance for each color).
premature of the PRINTHEAD has nothing to do with refilled ink cartridges; the PRINTHEAD assembly is a separate electronic unit in which the cartridges plug into and feed ink into. Refer to NOTE below.
4) Replace ink cartridge with a new HP ink cartridge to completely rule out the ink cartridge as the cause of failure.
5) To rule out printer/cartridge connectivity (assembly interface/connection) issues please ensure you have followed all steps on the Inkjet411 support page - this includes PRINTHEAD removal and thorough cleaning of the electrical surfaces on the PRINTHEAD and on the CARRIAGE ASSEMBLY: http://inkjet411.com/?page_id=1451
a. Remove all 4/5 ink cartridges, then remove the internal PRINTHEAD and thoroughly clean rear electrical contacts and carriage electrical contacts. Inspect ink foam ports to see if they are \'wet with ink\'...this will confirm whether ink is being pulled into the PRINTHEAD or not. If the ink foam ports are completely dry (no significant amount of ink present when blotted with a paper towel, etc.), then the PRINTHEAD is likely considered too dry to support proper ink flow and subsequent printing operations. Refer to PRINTHEAD removal process at HP.com (link down below) or at the following Inkjet411 link to provide general guidance: http://inkjet411.com/?page_id=1451
6) If after thorough electrical contact cleaning the problem persists, you may need to replace the PRINTHEAD ASSEMBLY (i.e. get from HP or Amazon), however, as a last ditch effort, you might want to perform a hot water flush on the PRINTHEAD: http://inkjet411.com/?page_id=2412
a. Remove all ink cartridges from the printer.
b. Remove the printhead - in most cases you will need to pull up on the lever at right side of carriage assembly to unlock the printhead. Lift printhead straight up to remove.
c. Over a sink, run warm tap water directly into the 4 (or 5) ink ports for approximately 2 minutes - this will effectively saturate the foam ports and blow ink out/thru the nozzle plate bottom.
d. Using a lint-free towel, remove water from rear/bottom electrical contacts. Ensure printhead electrical contacts and exposed surfaces are fully dry.
e. Install the printhead into the printer. You may observe a "Replace Printhead message" so you will need to cycle printer power by turning printer off and then on to clear the error.
f. Install ink cartridges and retest printer. You should observe a New PRINTHEAD alert message followed by an approx. 4-minute preparation countdown prompt.
g. If permissible, activate the \'Clean Printhead\'. This can be done from the printer\'s control panel or software printer driver (for example, by selecting \'Tools\' - \'Clean Printhead\', or similar).
h. If you have reached this point of the troubleshooting and all the previous troubleshooting steps did not work, then the printhead is likely damaged or at end of life* and may need to be replaced.
NOTE: On some HP printer models it may be difficult to remove the PRINTHEAD assembly, consult your User\'s Guide for specific instructions.
7) If this does not remedy the problem, then you may have a defective PRINTHEAD in the printer (worst case scenario), unrelated to the refilled cartridges.**
ADDITIONAL NOTES:
However, if you observe missing colors or poor image quality then air may have been accidentally ingested into the ink lines between the cartridge(s) and PRINTHEAD. To recover from this problem, you will have to run the "Clean Printhead" procedure 1-2 times to recover the ink system. Watch the video on the HP support page which describes some of the common issues you may encounter with refilled ink cartridges. This type of problem is common and completely recoverable.
NOTE 1: The HP 564 printer models have an electronic PRINTHEAD within the base of the carriage assembly (responsible for pulling ink from the 4 (or 5) ink cartridges and then firing the ink droplets onto the paper) - these will eventually fail depending on print usage type and printer duty cycle (i.e. rated for ~8,000 printed pages over life, but the consumer average is typically closer ~5,000 pages). The printhead is replaceable and can be ordered directly from HP.com. For information on how the PRINTHEAD functions, please watch the following video: http://inkjet411.com/?page_id=2054
**Typically the printhead should not reach it\'s end-of-life until after a minimum of 8 or more complete sets of cartridge changes; officejet models typically have a higher print page throughput average, but this is not always the case. While some printheads may last 15,000+ pages others may only last 3000 pages, actual results will vary. The printhead will eventually fail in time due to an internal micro-electronics failure, due to the following leading factors: general customer print usage and printer care, printer duty cycle (i.e. # pages printed per month), printing frequency (i.e. time between each print job), print mode (i.e. draft vs. normal) and content printed (i.e. photos vs plain pages) and color mode (black and white only vs. color/greyscale printing).
Paper types used (i.e. plain paper, photo papers & matte/heavy bond papers) and paper edge curl (i.e. duration in printer and/or exposure to low relative humidity) can also quickly lead to ********* printhead failures due to physical \'head strikes\' of the paper edges making repeated contact with the printhead nozzle plate surfaces.
CAUTION: the use of compatible/clone cartridges (i.e. sold thru the internet from overseas) are known to be problematic and may cause printer errors and permanent PRINTHEAD damage (due to incompatible ink formulations). We do NOT suggest refilling these types of ink cartridges.....refilling of HP 564 original/genuine ink cartridges is only suggested!
HP 564 Ink Refilling Services & Additional Cautions:http://www.youtube.com/watch?v=YlcY9jKXTvs
If you need to purchase a new ink cartridge(s) and are trying to cut costs, we suggest you try a remanufactured ink cartridge from http://www.inkplicity.com/ as their ink cartridges typically have the lowest cost in the USA, have a high reliability rating, come with a 1-year warranty and provide free shipping for all orders above $20.
Please let us know if the error condition persists. For any additional questions please contact us directly: Inkjet411help@gmail.com
-Thank you
Aug 18, 2014 | Office Equipment & Supplies
Alignment failed when run
If Printer heads health condition is not good, alignment wont completes..
Four individual cartridges & Two print heads, each print head prints two colors.. Black& Yellow, Cyan & Magenta.. Verify which color is not printing properly(Color missing Or white bands)..
Perform 2 or 3 times print head cleaning through printer menu..Try for alignment.. If success end.. if no, replace the print head which is not printing properly.. Before replacing the printer head ensure that cartridge ink should be above 30%...
Oct 07, 2012 | HP Officejet Pro L7680 All-In-One Printer
I am aligning paper after inserting an ink cartridge. However after printing the alignment sheet and putting it under scanner glass it says "Alignment failed or no alignment paper present" help?
Hi
In order to have a succesfull alignment You need to have
good quility of printing
Replace and the other cartridge or try cleaning it frmo maintance menu
on your printers menu
But you have alwaeys the choice to cancel allingment by pressing cancel button
Pls Vote us to keep us alive
Nov 16, 2010 | HP Officejet 5610 All-In-One InkJet...
I just changed my black ink cartridge and I keep getting a message that reads: pree enter to align catridges. Each time that I press enter the test runs and the screen reads alignment failed. HELP
Hi
in order to get alignment you need to have ink
in both cartridges
You need to replace and color cartridge or refill it
like this
If I help you pls vote me
Sep 06, 2010 | HP OfficeJet 6110 All-In-One InkJet...
Printer cartridges wont align says alignment failed and then paper too narrow
I request you to perform the steps below to align the cartridge:
1. Load letter or A4 unused plain white paper into the input tray.
2. Press Setup.
3. Press 6, then press 2.
This selects Tools and then selects Align Print Cartridge. The HP all-in-one prints a print cartridge alignment sheet and aligns the print cartridges. Recycle or discard the page.
Bypass the alignment :
Press and hold the Enter button, and then press Menu
Mar 14, 2010 | HP OfficeJet 6110 All-In-One InkJet...
HP 7140xi comes up with alignment failed after replacing black pr
you could try by passing the alignment
Press and hold Setup and then press OK simultaneously when align message is prompted on the All-in-One.
Jan 27, 2010 | HP OfficeJet 7410 All-In-One InkJet...
Hp 2210 all in one printer/scanner
after replacing the ink cartridge align the printer. Press alignment cartridge located in the printer properties. After printing the alignment get the paper and put it in the scanner. The computer reads it
May 04, 2009 | HP PSC 2210 All-In-One InkJet Printer
Printer keeps showing : Press enter to align cartridges. After doing this it then prints out an alignment page and shows: Alignment failed please: Press enter Alignment failed. This goes on and on. I have...
I have found that if I put in an old aligned page the printer reads it as and the alignment is accepted. As for the cancelled message being in the window, I have had this problem too. I've ignored it and selected the copy button and it took the command. The only problem with hitting cancel is that you cannot turn off your printer. Every time you do you have to repeat the aligning and cancellation process.
May 02, 2009 | HP Officejet 5610 All-In-One InkJet...
Alignment test keeps failing How di I override?
press the cancel button after you on the printer and wait a movement till the cartridges adjust and settle inside.
Aug 08, 2008 | HP OfficeJet 6110 All-In-One InkJet...
HP OfficeJet 6110 All-In-One InkJet Printer Logo
276 people viewed this question
Ben Johnson
