Question about Dryers
GE dryer. It does not get hot. How do you klnow if it is the thermostat or the heating element?
  • 5,911 Answers
I'm assuming this is an electric dryer. The following link will hopefully assist you in narrowing down which component may be defective in your dryer:
http://www.fixya.com/support/r630242-dryer_runs_but_not_heat
Now...before you go tearing your dryer apart, take a voltage reading at the wall receptacle first. A reading across the two hot leads (the long narrow slots) should read 220-240 VAC. If its only reading 1/2 the voltage (110-120 VAC) one leg of your primary voltage is missing. This means you may require an electrician to check your outlet for burned or broken wires. The reaosn the dryer will still run is because the dryer motor only requires 110 VAC to run. The heating circuits, however, require 220 VAC. This will give the symptom of a dryer that runs, but does not heat.
Typically, there is a thermal fuse and/or thermal cut-out located near the heating circuits. This component acts as a fuse and will blow when the heating ciruits overheat. The information in the link I provided will give you all resistance check reading for the components.
If you require additional assistance, please let me know. I hope this helps you.
PS If this is a GAS dryer, please post back and let me know. Your possible bad components will be different from an electric dryer.
Posted on Aug 07, 2008
  • 706 Answers
If your electric dryer doe not heat up, it could be the heating element opened ( meaning no current flow thru it, and no heat), thermostat or an over-temp sense switch tripped. These over temp 'snap type" switches are used as a failsafe to protect against unsafe temperatures as well as to prevent fires. Some of these switches have a reset button on them ( similar to those found on garbage disposers) and you may have to reset it manually to enable power to the heating element. These switches are situated in such a manner that if your vent system is clogged, temperature inside the dryer will exceed the safe limit and trip that switch. If you are reasonably handy and feel confident that you can safely troubleshoot and/or repair one of these components, it should be relatively simple to rule out the heater element as the problem by measuring its resistance with an ohm meter ( Obviously, all testing of this nature should be done wiith power disabled). Heating elements vary in resistance so any value that isn't an open ( meaning no continuity thru it) implies it is probably OK. If it does measure as an open, that is your problem and it needs replacement. Hope that helps...
Troubleshooting heating element on samsung steam dryer
DRYER OVERHEATING:
Heating Element
A defective heating element can make a dryer too hot or not heat at all. . If the element partially shorts out, it can produce heat all the time, regardless of whether the dryer is calling for heat. Remove the heating element to inspect it. The coils should not be touching each other or anything else.
Other Causes and Conditions
Air Flow Problem
Dryers need good ventilation to work properly. If the vent is clogged it can make the dryer too hot. Clean all of the vent tubing thoroughly.
Cycling Thermostat
Although not common, a defective cycling thermostat can make the dryer too hot. The cycling thermostat is supposed to turn on and off the heat to maintain the proper temperature. If the thermostat is defective it may keep the heat on too long. The thermostat is not adjustable or repairable, it must be replaced.
Dec 10, 2016 | Samsung Dryers
Hoover dryer lights up element heats but machine wont run keeps saying clean filter ?
DRYER OVERHEATING:
Heating Element
Air Flow Problem
Cycling Thermostat
Felt Seal
Most dryers have a felt seal at the front and rear of the drum to keep the heat inside the drum. If the felt seal is worn away or missing, the dryer may keep heating and make the dryer too hot. This is not common.
Blower Wheel
A defective blower wheel will not spin properly and will not vent the hot air, making the dryer too hot. Check to see if there is adequate airflow out of the dryer.
https://www.youtube.com/watch?v=3m5NZvY9V5Q
GOD IS still GOOD !!!! SO MY ADIVE IS FREE
Dryer Overheats and or Dryer Gets too Hot
Nov 22, 2016 | Hoover Dryers
I have samsung dv220aew/xaa dryer, that gets too hot and kicks code HE. New element, thermistor and cleaned thoroughly. Gets hot, codes on all heat settings. Any ideas?
DRYER OVERHEATING:
Heating Element
A defective heating element can make a dryer too hot. If the element partially shorts out, it can produce heat all the time, regardless of whether the dryer is calling for heat. Remove the heating element to inspect it. The coils should not be touching each other or anything else.
Air Flow Problem
Cycling Thermostat
Felt Seal
Blower Wheel
Apr 21, 2015 | Samsung Dryers
Ge dblr333etoww dryer
If your dryer isn't heating up, it's probably down to either the heating element or the thermostats. Most dryers have two thermostats and these correspond to the two temperatures that you can set your dryer to, typically "Low" and "High" on most dryers. The other cause of a cold dryer is a faulty element.
Because the element and the thermostats are closely linked, and it can be very difficult to troubleshoot if either the 'stats or the element is the cause of the problem. Therefore we recommend that you replace both the 'stats and the element at the same time.
Jan 21, 2014 | Dryers
Changed out rear bearing and heating coil now something smells like its burning
see this causes and fix it. God bless you
Heating Element A defective heating element can make a dryer too hot. If the element partially shorts out, it can produce heat all the time, regardless of whether the dryer is calling for heat. Remove the heating element to inspect it. The coils should not be touching each other or anything else.
Heating Element Assembly A defective heating element assembly can make a dryer too hot. If the element partially shorts out, it can produce heat all the time, regardless of whether the dryer is calling for heat. Remove the heating element assembly to inspect it. The coils should not be touching each other or anything else.
Air Flow Problem Dryers need good ventilation to work properly. If the vent is clogged it can make the dryer too hot. Clean all of the vent tubing thoroughly.
Cycling Thermostat Although not common, a defective cycling thermostat can make the dryer too hot. The cycling thermostat is supposed to turn on and off the heat to maintain the proper temperature. If the thermostat is defective it may keep the heat on too long. The thermostat is not adjustable or repairable, it must be replaced.
Felt Seal Most dryers have a felt seal at the front and rear of the drum to keep the heat inside the drum. If the felt seal is worn away or missing, the dryer may keep heating and make the dryer too hot. This is not common.
Blower Wheel A defective blower wheel will not spin properly and will not vent the hot air, making the dryer too hot. Check to see if there is adequate airflow out of the dryer.
Oct 02, 2012 | Frigidaire Electric Dryer
What could be causing inside of the drum of my AD55 F&P dryer to very hot?
Sep 28, 2012 | Fisher and Paykel Dryers
GE DCXR463EA1WW that has stopped heating.
Probably a bad heating element. Sometimes one side will burn out before the other, so it takes a lot longer to dry. Then the other side burns out and it won't dry at all. Usually thermostats last longer than elements.
Jul 25, 2017 | Whirlpool GEW9200L Electric Dryer
Excess heat from element
Yes I recommend you change all of the thermostats, many people would say o thats **** but its safety and i would clean the whole dryer when waiting for your part. Whirlpool Parts Surplus Can Help you if you call their 800 number.
Apr 26, 2009 | GE Dryers
How do I test for bad thermastat or heating element on GE dryer
well the fact that hte heating elemnt is glowing tells me that all the thermstats are working, i would check for a blockage/restriction in the venting. looking at te diag, its possible that only 1 of the 2 coils for the heate are actually going on, check the coils for continuity( may be a small break that separates when gets hot)
Dec 07, 2008 | GE DCSR483EA Electric Dryer
Electric dryer does not get hot enough
If it does not heath at all check the heating element, circuit breakers, thermal fuse, and also the thermostat.
If heat is scarce check thermostat and faulty heat relay.
Nov 07, 2008 | GE Dryers
Dryers Logo
78 people viewed this question
Top Dryers Experts
