Question about Kodak EASYSHARE 5300 All-In-One InkJet Printer
Color prints are wet - Kodak EASYSHARE 5300 All-In-One InkJet Printer
  • Tim Babcock
    Tim Babcock May 11, 2010
    What brand of paper are you using?
    Master:
  • 521 Answers
Set the print quality to normal from best. if on normal then set it on draft.and click-- apply--- after you set without fail.
Posted on Aug 08, 2008
Pro 8500 printer. Just installed new color ink cartridges. Why isn't color printing on printed material?
Hello, Take the ink cartridge out and dab on a wet paper towel until the ink start flowing or the ink cartridge is bad or the print head needs to be cleaned on the printer.
Nov 21, 2015 | HP OfficeJet Office Equipment & Supplies
I have a canon MP600 I put a new #5 black ink cartridge in it, now it wo'nt print black. it shows full but only prints colors
Try wetting the bottom of the cartridge to see if ink will come out, it may just be dry, you can do this by placing the bottom into a little water or onto a wet kleenex, let me know how this works.
Jun 06, 2008 | Canon PIXMA MP600 all-In-One InkJet...
Ink levels show emptry.
Need one plastic plate that you don't care much about, or a plastic disposable plate.
Tear off one section from a paper towel roll and roll it up into about a 1-inch diameter roll.
Flatten the roll
Soak the flattened roll in warm water
Lay the flattened roll down on the plate
Place the nozzle area of the ink cartridge directly against the wet paper towel
Fold the flattened roll as needed to support the ink cartridge so it stands upright.
The trick here is to make sure the cartridge is supported upright so the nozzles come in full contact with the wet towel surface.
The wet towel acts as a wick to soften and draw out the ink.
After awhile, you shoudl see a kaleidoscope of colors on the paper towel. This indicates the nozzles have been opened up and the ink is flowing. Try to print and see what happens.
Repeat as needed.
May 21, 2010 | Dell 926 All-In-One InkJet Printer
Hp officejet v40. new cartridge but missing blue when printing
Sounds like your cyan print head is clogged. You can try to get it flowing yourself by rubbing the print head with a wet paper towel. If you press the print head on a dry paper towel you should see three distinct lines of color. If you still don't see the cyan, try letting the print head rest on the wet paper towel on a surface that ink can be cleaned up from or one you don't care about staining. If the cyan still won't flow, you should go back to where you purchased it and return it for a new one.
Jan 12, 2010 | HP OfficeJet V40 All-In-One InkJet Printer
I replaced both cartriges (Black and Color) and when I print, the yellow color does not print. Even on the test page, the color setion at the bottom is blank where the yellow color block should be printed....
You can dab the bottom of the color cartridge on a damp paper towel, check the streaks left behind, if there is no yellow either there is no yellow in the cartridge or it's just plugged. Dab it a few times on a wet towel, if still no yellow, you need another cartridge.
Dec 22, 2009 | HP DeskJet 932c InkJet Printer
No color from the ink cartridge
hi this is kamal...
pls purchase a color cartridge new... coz ur color catridge is not working properly...
so pls go through this advice... n let me know...
best regards
kamal singh
Oct 08, 2009 | Canon i860 InkJet Photo Printer
Canon MP210 Won't print Color - Color Ink Light blinking
try to run a maintenance page or to clean the printhead go to your printer panel and select maintenance..and print maintenance page ..or to wipe it on a wet cloth in order to avoid clogs..
May 18, 2009 | Canon PIXMA MP210 Photo All-In-One Printer
Color won't print! Test shows continuity.
I stand corrected, but this sounds strange. The black cartrige on a 650c is a no40, the colors are No50. It is impossible to place a color cartrige in the black posotion. You must remove all your cartriges and wipe them off at the bottom with a very hot wet cloth (not boiling) Let them stand on the wet cloth for quite some time and then give them a good shake (dont be shy). Be VERY careful not to get ink on your clothes or nearby objects. Once you have done this wipe them down again with a dry lint free cloth or tissue paper and try again.
Dave
May 18, 2009 | HP DesignJet 750c plus InkJet Printer
HP Deskjet 9800
push the printhead in a wet towel
until you can see a clear print Imprint
on the wet towel
Mar 23, 2009 | HP DeskJet 9800 InkJet Printer
I80 black cartidge not printing
get a q-tip and wet one end in water.  run wet q-tip along head a few times.  then take dry end and run along head again to dry it.  then run wet end again on the absorber side of head.  then dry with dry end.  replace parts, do a deep cleaning, and try a test print.
Apr 27, 2008 | Canon i80 InkJet Printer
Kodak EASYSHARE 5300 All-In-One InkJet Printer Logo
18 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
