Question about HP Pavilion dv6000z Notebook
Charger is too hot
I have just changed my battery (it wasn't charging at all even though was plug in and both the battery and the charger were getting very hot) and it's charching but the charchers is still very hot!! is that normal or i need to change my charcher too??????
    Genius:
  • 2,028 Answers
Some chargers do run a bit on the hot side. Check your charger with an ohm meter to see if it's getting the proper output. If not, then the charger is struggling to run the machine, and this is causing it to heat up. Also keep in mind that if the charger isn't getting the proper output to the machine, it can damage the new battery or the machine, and will need to be replaced.
Posted on Aug 07, 2008
Battery on G-zone Commando Losing charge even though it shows it is charging
A charger can indicate it is working but if it is trying to charge a dead battery you will get the result you describe.
Mar 09, 2014 | Casio G-zone Commando
I am getting a flashing green light when I try to charge my batteries on the Pronto M51 what does this mean
why did you change the batteries, did you verify that it wasn't the charger in the first place, sometime the charger will appear to charge but actually isn't. put a meter on one battery then plug in charger if voltage goes up charger is good if not look for loose connections and or bad charger.
Sep 25, 2012 | Invacare Pronto M51 Power Wheelchair
What do u do when your phone won't charge even
charge your battery on another phone and then place your battery in your phone and switch on your phone and connect the charger to it if still it isn't charging then check your charger and if the charger is ok then you need to repair your phone manually or by taking it to authorized dealer
Apr 25, 2012 | Cell Phones
My iPhone 2g is heating up..and if i charge it its so hot and i will take me 1 day to fully charged it and if not fully charged i can used it up to 20-30 munites if fully charged 2-3 hours and the hot...
You either have a bad battery or you have a bad charger. If the phone heats up when you plug it into the USB port on a computer then you know that the battery is bad and needs to be replaced. If the phone does not heat up and you get a normal charge from the USB connection then you know that the battery is good and the charger is bad.
Mar 24, 2011 | Apple Iphone 2g 3g 3gs 8gb 16gb S
My Samsung Comeback will not charge. When I plug it in and it's turned off, the bars go up, as if it's charging. But when I charge it for a long period of time ( longer than usual for it to be fully...
Hey! My Sister has the same problem. T-Mobile said that it is the battery. There was a defect with some phone batteries. You can buy the samsung battery from T-Mobile for like 48$ of go to cellphoneshop.net to get it cheaper. works great and is cheaper to replace than 48$ samsung battery!!
Aug 20, 2010 | Samsung Comeback Cell Phone
My laptop won't charge when plugged in...I changed the charger but still won't charge
When you say it won't charge, does it charge at all?
1. It indicates that it is charging, but as soon as you unplug the charger the battery quickly or immediately indicates it is dead. If the laptop is off, the LED on the laptop shows it is charging but the battery is always dead,
Or:
2. It is as if you didn't have the charger plugged in. No light on the laptop at all when the charger is plugged in.
Possible solutions:
1. The battery has died and is no longer capable of taking a charge. An alternate explanation if you can't even get the laptop to turn on even though the laptop charge LED is on, is that the internal power supply that converts the incoming and battery voltage to all the voltages required has died.
Or:
2. The power connector inside the laptop is a common failure point. The solder joints break from various minor shocks over time. This is going to become more common with lead-free solder as it is more brittle. Less likely is that the charging circuit inside the laptop has failed.
Feb 06, 2010 | Acer Aspire 5500 5570-2609 Laptop
Discharge Battery
If it is within warranty, have them replace the unit. Are you using a wall charger or a trickle-charger such as the USB Cable? The wall charger is the only way to truly charge it to full.
If you are using a USB charger or other trickle charger, after the device says it is fully charged remove it from the charger for about 2 minutes and then reconnect it. It will then charge (most of) the rest of the way.
If you don't do this, the problems gets worse and worse. After 1 day, the trickle charger may get you up to a 90% charge. After two days, 80%, etc. After a week you'll only be holding half a charge, even though the device is reporting a full charge while on the charger.
Another tip I have found is to perform a soft-reset after removing it from the charger, particularly if it has been plugged in for a long time at full charge (more than an hour or so). It seems like the device doesn't always detect that it has been unplugged and tries to **** down juice as if it were still plugged in. If you have noticed that your device gets pretty hot when the battery drains quickly, this is probably what is happening to you.
You also haven't mentioned the programs that you are using during the day. Some programs, particularly chat clients, will drain the battery in about 5 hours, though obviously you're not using anything like this while in flight mode.
One more thing. You noted that you were told that leaving it on the charger whenever possible is the thing to do. This is incorrect. The more the battery is exercised in this way, the shorter the lifespan of the battery will be. With any mobile device we're all bound to charge it every night, but once it is charged you want to take it off the charger. A battery being fully charged is just as bad as a battery being fully drained, so you want to keep it somewhere in between as much as possible. __________________
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Jun 12, 2009 | HTC Touch P3450 Smartphone
Can't turn on and a battery sign with a red slush appears
Thee battery is fully discharged. It may take an hour on the charger before this goes away.
Mar 13, 2009 | RIM BlackBerry Pearl 8100
HP Pavilion dv6000z Notebook Logo
47 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
