Question about SanDisk Sansa E280 MP3 Player
Lock slider switch does not unlock player - SanDisk Sansa E280 MP3 Player
Bought a new mp3 player
Posted on Aug 08, 2008
Network lock
Hi. you can get the network unlock code for a Samsung E2550 from Mobile-Unlocker.com at affordable cost.
..........UNLOCKING INSTRUCTIONS..........
Method 1:
1 - Switch ON your Samsung E2550 Monte Slider with a NOT ACCEPTED SIM Card.
2 - Samsung E2550 Monte Slider will ask for "Password".
3 - Enter the Unlock Code.
OR (if the Samsung E2550 Monte Slider shows "Insert Correct SIM Card")
Method 2:
2 - Don't bother about what's being displayed on your Samsung E2550 Monte Slider.
3 - Compose : #0111*CODE#.
Jul 07, 2014 | Samsung GT-E2550 Cell Phone
I CANNOT UNLOCK MY TOSHIBA MP3 PLAYER
Can you be more speisific about your problem?
Jun 27, 2008 | Toshiba Audio Players & Recorders
How do I unlock sandisk mp3 player
Press the slider switch down to lock and press up and hold a few seconds to turn on (and unlock).
May 22, 2014 | SanDisk Sansa Audio Players & Recorders
How do nyou replace the key tumbler on a 1992 jeep cherokee
this is covered in the FSM. best is to ask a lock smith, (no kidding)
it is also cover at all 3 top online fsm sites (vitrual fsm)
at alldata.com
mitchells.
and chiltions online.
the tumbler just dont fall out, it has protections from thieves (weak)
most cars, you must remove the key assembly
the pull the tumble pin, hidden and blocked by the mounted assembly.
those are generic words.
the steps can vary if car has steering wheel, vert adjustment option.
here is a non Air bag quote
Without Air Bag The ignition switch is located on the lower part of the steering column.
  1. Place the ignition in the LOCK position.
86748g34.gif Ignition/dimmer switch assembly
  1. Remove any components necessary to access the switch.
  2. Remove the two switch mounting screws.
  3. Disconnect the switch from the rod.
  4. Disconnect the wiring and remove the switch.
To install:
  1. On non-tilt columns:
    1. Move the ignition switch slider to the OFF unlocked position (move the slider all the way down, then back two clicks). The remote rod hole in the ignition switch slider should now be centered.
    2. Insert the remote rod in the ignition switch slider hole and install the ignition switch on the steering column. Tighten the attaching screws to 35 inch lbs. (4 Nm).
  2. On tilt columns:
    1. Insert the ignition key in the lock cylinder and turn the cylinder to the OFF unlocked position.
    2. Move the ignition switch downward to eliminate any slack and tighten the attaching screws to 35 inch lbs. (4 Nm).
  3. Install any components removed for switch access.
Dec 12, 2013 | 1992 Jeep Cherokee Limited
Samsung YP-U2J Mp3 Player is Locked. How can i Unlock it? When i press On button, Locked screen appears.
My samsung YP-U2 has HOld on it when i turn it on,when it lights up theres a lock piture showing ,can enyone help me with this,please,cant get to play my songs,
Feb 10, 2011 | Samsung YP-U2 MP3 Player
How can i fix it when it just come up "this memory card is locked" ?
Pull the memory car out of the camera, on the left side (label side) of the card is a tiny slider switch, it says "LOCK, made sure the slider is not in the lock position which is down, if the slider is not in the lock position then the memory card is defective.
Dec 13, 2010 | Panasonic Lumix DMC-FZ18K Digital Camera
1993 Jeep GC Limited - Overhead display is too dim to be useful - especially when headlights are on. Can this be adjusted, and how?
It's the dimmer switch....follow below:
To install:
Ignition switch rod positioning
  2. On tilt columns:
Aug 13, 2010 | 1993 Jeep Grand Cherokee
How too change the ignition switch on a 88
disconnect negative battery cable.place the ignition lock in the off lock position. remove the 2 switch mounting screws.disconnect the switch from the rod.disconnect the wiring and remove the switch.TO INSTALL.ignition switch installation for non tilt columns.move the the ignition switch slider to the off unlocked position move the slider all the way down.then back 2 clicks.the remote rod hole in the ignition switch slider should now be centered.insert the remote rod in the ignition switch slider hole and install the ignition switch on the steering column.tighten the attaching screws to 35 inch lbs.ignition switch installation for tilt columns.insert the ignition key in the lock cylinder and turn the cylinder to the off unlock position.move the ignition switch downward to eliminate any slack and tighten the attaching screws to 35 inch lbs.
Nov 26, 2009 | 1988 Jeep Cherokee
My ipod touch is locked how do i get it to work
The 'Lock' slider switch is on the top across from the headphone jack. Slide it to the left. That should unlock it.
Let us know??
Crat
Oct 03, 2009 | Apple iPod touch
Sansa e260 MP3 Player cannot be unlocked
Reset the player first, then retry the lock slider.
Jun 26, 2008 | SanDisk Sansa e260 MP3 Player
SanDisk Sansa E280 MP3 Player Logo
35 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
venugopal durairajan
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
