Question about GE GSS22JFMWW Side by Side Refrigerator
Compressor doesnt run
No power to compressor
  • steve burgunder Aug 08, 2008
    The defrost is not on. Does the mother board control everything? Are there any other temp. sensors that would stop the compressor from comming on?
  • 481 Answers
Could be the the defrost timer/control board stuck in defrost.
Posted on Aug 08, 2008
  • Mike Durland
    Mike Durland Aug 08, 2008
    the start switch on the side of the compressor is usually the problem, but since you said there is no power going to the compressor then it could only be the defrost timer/control board or the thermostat.
    • if the fans are running, then I would double check the lines going to the compressor for power, I know you checked them already but just in case.
    • if there is power going to the compressor and it wont start then it is the start switch on the side of the compressor.
Turn ac on doesnt seem like the compressor and outside fan that blows air up ward want to work is the diode or compressor no good
If this is a conventional split system, check for power at the contactor, and secure the power and check the run capacitor
Sep 02, 2013 | Siemens Heating & Cooling
Amana drs2662aw has power going to compressor but the compressor doesnt start up
It can be the problem with compressor itself or problem with start up capacitor beside compressor. Click this link below for more details:---
http://technoanswers.blogspot.com/2011/10/compressor-not-running-on-refrigerator.html
This should help.Thanks.Helpmech.
Oct 26, 2011 | Refrigerators
Light comes on when you open door but wine cooler does not come one (does not cool). Checked all circuit breakers.
check thermostat set it to the coldest setting if doesnt come on test stat for power if power jump stat see if starts if still doesnt test for power at compressor if power than check thermo safety for compressor if good than compressor has an internal problem which will probably require a replacement
May 15, 2010 | KitchenAid Architect KUWA244PSS Stainless...
After power loss, freezer doesnt work, is there a reset button?
Check the compressor to see if it is coming on. If not but the condensor fan is running then it is likely that the start/run device on the compressor is not working. A 3N1 start kit is a cheap fix for this. Most times the compressor is not bad.
Mar 27, 2010 | Kenmore 57029 Side by Side Refrigerator
My model ACD2234HRQ is approx 90 days out of
you need to replace the rtc overload contactor located on the compressor body,there is also a run capacitor on the contactor,replace this along with the rtc contactor,this is your problem,the contactor and overload give the compressor starting power and run power to the windings,if the capacitor is bad it doesnt have enough torque to overcome the power to turn the compressor initially
Mar 13, 2010 | Amana 22.6 cu. ft. Side-By-Side...
Lennox Diplomat 10AC48-1P, outdoor fan runs compressor will not kick on. Replaced contactor, still no compressor. Could there be an issue with dual capacitor or start capacitor that would prohibit the...
There could be the compressor capacitor is damaged.Sometimes on the duel capacitiors they will still run the motor,but doesnt have enough power to turn on the compressor.Or the compressor could be bad.
Aug 18, 2009 | Heating & Cooling
Frigidaire refrigerator
check the overload, take it loose and inspect it for a burnt spot shake it if it rattles replace the relay
you either have a relay bad or a stuck compressor
the compressor has a 5 year warranty on the part, the relay 1
so if you relpace the relay and it still doesnt run the compressor, call for serviece under warranty
Apr 27, 2008 | Frigidaire FRS26R4A Side by Side...
GE GSS22JFMWW Side by Side Refrigerator Logo
148 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
RepairNinja
RepairNinja
