How can i copy photos from my pc to a sd card for a digital frame?
  • gg_alabama Aug 09, 2008
    Thanks for your input. Buying a SD card reader is the solution I hoped to avoid.
  • 3 Answers
The easiest way is to purchase an SD memory card reader. You plug it into your usb port and it will show up on your computer as a removable hard drive. You can just drag your photos to the memory card. Prices range from about $10 and up.
Posted on Aug 09, 2008
How to put photos onto SD cards
In Windows, click on Start/Computer. A window opens showing all the drives connected to the computer. Under "removable drives" locate the SD card. Hover your mouse pointer over the SD card icon and it should tell you how much free space is on the card. If necessary, delete some photos or other data to make more space available so you can add the photos you want. If there's already plenty of space, try formatting the SD card in either ex-FAT or NTFS format. Then try copying the photos again. If the SD card does NOT in appear in removeable drives then the SD card may be faulty. Try a different SD card.
Nov 04, 2014 | Philips 6.5-Inch Digital Photo Frame...
How do i download pictures to tablet
Pandigital photo frames are an ideal way to display your collection of digital photos. You can view photos with or without a computer using just a memory card, but it's always a good idea to transfer the photos you'll want to view frequently to the internal memory of your frame. This is also a handy way to back up your favorite images.
  1. Transferring Photos from a Memory Card
    • Your digital photo frame's built-in software will recognize six types of memory card: CF I/II, SD, MS Pro, MMC and XD. Locate the slot on the back of the frame (to the left of the stand) that corresponds with your type of memory card. These are labeled as follows: SD/MMC/MSPro/XD, CF I/II, USB and mini USB. Insert your memory card into the appropriate slot, power on your digital frame, and it will automatically begin a slideshow using every available image on your memory card. Note that only JPEG formats under 16 megapixels are compatible.
    Transferring Photos from a PC
    • Use the USB cable that came with your frame. Connect the mini USB end to the mini USB port on the back of your frame; connect the large USB end to your computer's USB port. Double-click the "My Computer" icon on your desktop or in your Windows "Start" menu. You'll see that your computer has automatically assigned a drive to your digital frame---look for a device called "Removable Disk" followed by a letter (Removable Disk E:, for example). This is the folder that represents the internal memory of your digital photo frame; you will be dragging your photos into this folder.
      Next, open the folder in which you store your photos ("My Pictures," for example). Select the photos you want to transfer to your frame. Drag them to the drive associated with your digital photo frame---this is the "Removable Disk" drive you located within the "My Computer" folder. Every photo you selected will then be copied onto your digital frame.
      After the files are copied, disconnect your digital frame properly. If you don't, your frame's internal memory could be damaged. Look for the system tray in your desktop's lower right-hand corner. Left-click the icon that shows a gray box with a green arrow on top of it. Select "Safely Disconnect Hardware." A dialog box will appear, asking you to select the device to disconnect. Select the digital frame and click "OK." When the dialog box appears, click "Close." You'll see a message in the lower right hand portion of your desktop telling you it's safe to disconnect your frame.
    Copying Photos to Your Frame's Internal Memory
    • You can use your frame's remote control to copy photos from your memory card or computer to the photo frame's internal memory. Connect your photo source (computer or memory card) and have your frame's remote control handy. Access the "Home" screen on your frame using the "Home" button on your remote control or by pressing the "Home" button on top of the frame. Next, choose "Photos" and press "Enter." You'll see all your photos in thumbnail form. Scroll through them with the up and down arrows. Press the "+" key to mark photos you want to copy (use "-" to de-select a photo). When you've selected all the photos you want to copy, press "Set Up," then "Copy Photo," "Enter," "Selected" and "Enter." A dialog box will ask you to confirm your selection; with the cursor on "Yes," press "Enter." The photos you selected will be copied to the frame's internal memory.
Dec 04, 2011 | PANDIGITAL 7270FW Tablet
I want to transfer photos from my imac (usb) to an sd card reader digital photo frame ...help ?
You need an SD Card, an SD Card reader and a photo frame with an SD card slot. Put the SD card into the SD card reader and plug that into your imac, transfer your photos to the card and then remove the card and put it in the photo frame
Nov 22, 2010 | Cameras
How do you add new photos to the digital picture frame?
Most digital photo frames come with an SD (memory) card that you can plug into a computer and copy the photo's you want from the computer to the memory card. Once done you pop the card back in the frame and your done.
Please be aware that the SD card maybe of limited capacity so you might not be able to get all the photo's you want on it unless you purchase a larger capacity card.
Regards.
May 26, 2010 | Coby DIGITAL FRAME COBY DP102 RTL
Video OK but no audio when use SD card on photo frame COBY DP702
Audio is probably recorded with different codecs, one of which is unsupported by your frame.
Mar 23, 2017 | Coby DP-772 Digital Picture Frame
I cant transfer pictures from my PC to a Digital Frame
either transfer to a usb pen or a standard digital card and then insert in photo frame good luck
Dec 20, 2008 | PANDIGITAL (DPF802) Digital Picture Frame
I bought a technika jp07 photo frame but when i put the sd card in it comes up no playable file. i tried the same sd card in another photo frame and it works fine. please help mrs bev bartram
It seems that it's not about the size of file or resolution of the photo!
I was given one of these yesterday. I copied my photos on to a 64mb SD card of unknown make. They display fine on my PC but on my Photo Frame I get the "no playable file" message. I tried changing file size etc but no good.
As a last resort I copied my same photos on to a 2GB SanDisk SD card and tried that. It works fine. So my guess is that these photo frames are picky on what SD card they'll accept.
A pity the manual doesn't tell you so!
Nov 13, 2008 | Cameras
Westinghouse 7" lcd picture frame internal memory not recognized
You can copy files from internal memory to sd card only. Its one way data transfer.
Sep 05, 2008 | Westinghouse 7" LCD Digital Photo Frame
Photos from pc to sd
The easiest way to do this would be to buy a card reader for you PC. You can buy an external one that plugs into the USB port.
Another way is to used a computer with a SD reader and upload it into a flash drive. Once you have the flash drive, you can upload the pictures using your flash drive into the frame.
Aug 08, 2008 | Computers & Internet
Can I get pics from computer put on memory card for digital camera?
Put your SD card into a card reader / slot in your computer. Go to "My Computer" Identify the drive letter allocated to the card slot and drag and drop or copy and paste.
May 05, 2008 | Cameras
Computers & Internet Logo
46 people viewed this question
David Payne
David Payne
