Question about Jenn-Air JED8230 Electric Cooktop
Jenn Air model A121
Trying to locate a replacement ceramic cooktop cartridge
5 Suggested Answers
SOURCE:
SOURCE: Jenn-Air Gas Cooktop Model CVGX2423
Just had this problem today on our seven or eight year old Jenn-Air cooktop. When using the front right burner all ignitors would continue to fire until I turned off the burner. The three other burners worked correctly. After trying all the obvious soulutions w/o success I pulled off that burners control knob and the rubber seal which exposed the valve. Their was a bunch of crud in there. I put a small (one inch) paint brush in there and vigorusly loosened all the crud. I then inserted the nozzle of our central vac - which just happened to fit perfectly - and sucked all the stuff out. I repeated the proceedure a couple more times, reassembled the knob and started the burner. Worked just perfectly!!! YMMV. Good luck.
Posted on Feb 08, 2008
  • 1314 Answers
SOURCE: jenn-air cooktop
no i wouldnt long as its working
Posted on Mar 03, 2008
  • 59 Answers
SOURCE: replace glass top
Hello Bob
I have attached the link for you to request the manual for that stove....just go there and fill out the form and they will email you the manual in a few hours....I did the same thing and I got it the same day.
http://shared.whirlpoolcorp.com/product_literature/search.jsp?siteCd=JA_EN_US
Eddie Rentas
Tupper Lake NY
Posted on Jul 19, 2008
SOURCE: Jenn-Air JGC8536 Gas Cooktop ignitor replacement
One burner doesn't consistently light. Igniter sparks but not the same as the other - "good" burners spark at top of igniter and moves around to light, "bad" burner sparks toward the bottom and doesn't move much. I can use the burner by lighting with a match and it works fine. Have tried cleaning with a toothbrush without much success
Posted on Feb 15, 2011
WHAT DO I USE TO CLEAN AN ELECTRIC JENN-AIR CERAMIC COOKTOP; THE BURNT FOOD BUILDUP.
a good product is CERAMABRYTE. it is designed for ceramic cooktops and is a white lotion type cleaner. if there is a lot of burned buildup you may also need to purchase a special scraper with a blade in it. but make sure you smear the cleanser on FIRST or you will scratch the surface.
Oct 24, 2009 | Jenn-Air JED8230 Electric Cooktop
How do i replace my burner on my jenn air ceramic cook top . it has the down draft feature in the centre
1) turn off power at the breaker. 2) remove hold down screws 3) pop up cooktop out of counter top 4) remove knobs and downdraft grille 5) remove ceramic top (screws around outside and also in side grille opening) 6) unplug burners replace with new burner
Sep 17, 2009 | Jenn-Air JED8430 Electric Cooktop
How to repair cracked corner of black ceramic cooktop
Epoxy would not work. If it is a very small chip and is NOT STRUCTURAL or in the heated are you could TRY the adhesive used for rear view mirror to glass attachment.
Sep 13, 2009 | Jenn-Air 30 in.JGD8430ADS Gas Cooktop
Ookware should I buy for a Jenn Air
i would avoid cast iron or nickle pans as they are heavy and coarse. i would recomend a nice stainless set with aluminum bottoms
Jul 05, 2009 | Jenn-Air JED8430 Electric Cooktop
Jenn-Air JED8345 one burner does not come on
The switch for the burner is bad and needs to be replaced.
If you need further help, reach me via phone at https://www.6ya.com/expert/steven_a67ead41eb5fc62a
Jun 25, 2017 | Jenn-Air JED8345 Electric Cooktop
Front double burner not working on Jenn Air ceramic cooktop model # JES8750AAB
mostly the problem is the sensor inside the unit but so very expensive to replace,wait to damage the other then buy an new one compare to repair.
tnx gerbee
Jun 29, 2009 | Jenn-Air JED8430 Electric Cooktop
I cannot REPLACEMENT KNOBS fOR model # 5D02
http://www.repairclinic.com/Appliance-Parts?s=t-jed8430-%3d%3dc251
This company has your knobs.
May 23, 2009 | Jenn-Air JED8430 Electric Cooktop
What's best tu glue my cooktop on my granite countertop?
I don't think I'd glue it down permenantly. I just had to replace the ceramic glass on mine (a JED 8430 ABD) after it cracked. Thankfully, it wasn't glued down so I could replace it pretty easily (ordered part directly from Jenn Air). But some sort of seal to keep food out from under the cooktop would be nice. I just wouldn't go permenant. The fact that you have to tape the down draft to the external vent should keep the cooktop in one place (plus its own weight).
Feb 28, 2009 | Jenn-Air JED8430 Electric Cooktop
Jenn-Air JGD8130 Gas Cooktop
grab hold of the installed burner cartridge at he top of unit and pry up slightly, should lift up without much effort, if not try lifting front side. they jsut lift up and slide back in no screws hold them in place
Feb 21, 2008 | Jenn-Air JGD8130 Gas Cooktop
Jenn-Air JED8230 Electric Cooktop Logo
275 people viewed this question
Top Jenn-Air Cooktops Experts
Marvin
Marvin
Paul Carew
MARLON KELLER
Are you a Jenn-Air Cooktop Expert? Answer questions, earn points and help others
