Question about Mitsubishi WS-73909 73" Rear Projection Television
I have a convergence issue problem?% - Mitsubishi WS-73909 73" Rear Projection Television
  • 1 more comment
  • rfoy Nov 28, 2008
    Convergence procedure no longer works. The red adjustment will move up and down but not adjust side to side.
  • bfg65sr Nov 28, 2008
    I have basically the same problem, only my red convergence doesn't move up or down, it does move left and right.
    Mitsubishi vs-60707
  • taggart63 May 11, 2010
    Mitsubishi WS-73905 73 in. Diamond Series
  • Mitsubishi Master
  • 8,617 Answers
Post your model number and I will help you with the problem. Please reply to this same post.
Posted on Aug 08, 2008
How to change chips rca
I think youre refereing to convergence Issues?? If so your model doesnt have IC chips like most other brands. If your model has a convergence issue its fairy easy to fix. let me know if the issue is convergence or not and I will assist you with the issue.
Oct 24, 2011 | RCA R61WH76 61" HDTV
52" rca hdtv has a shadow ghost when it plays. It
convergence issue. Press menu and then scroll down to the setup option enter setup and scroll to Autoconvergence and activate the auto convergence feature that will realign the convergence . If that doesnt correct the issue you will need a Convergence power board, If the auto convergence feature is missing from the setup menu then you need the convergence option missing repair kit. Both the board and the repair kit are available from www.tvrepairworld.com
Jun 18, 2011 | RCA D52W23 52" HDTV CRT TV
My magnavox 51mp392h has a convergence issue. the
Convergence is dead.Know how to solders? Must replaced the 2 convergence ICS and all it resistors.Tries Tv repair World.com,Tvrepairkit.com to buy a convergence kit to repair it ur self.The shop will $300 for the parts and labors.
Feb 03, 2010 | Philips Magnavox 51MP392H Rear Projection...
Red color convergence issue; Red lines are curved
This sounds like convergence output IC problem. convergence board would have to be removed - remove and replace 2 STK IC's and check the surrounding resistors. Shops usually $200-$400 Be sure to vote/rate me if this helped Thanks!
See link for more detail
http://www.ehow.com/how_4575598_yourself-projection-tv-repair-convergence.html
Nov 24, 2009 | Televison & Video
I just repaired my convergence issues. The set worked for a couple weeks and I unplugged. Yesterday i plugged it back in to use and now I have sound but no picture. I checked for voltage at the projecters...
You didn't repair your Convergence issues...TV's that shut off or have NO PICTURE have full blown convergence amps....
Get a new pair of Convergence amps and replace them...
Mar 16, 2009 | Toshiba 50HDX82 50" Rear Projection...
Convergence issues
Is the symptom the same on ac format? If so you may have to do an alignment. Also when the convergnce seems off if you go back to the convergence adjustmen is it off there aswell? If so you may just need to reflow thesolder on the convergence Ics.
Jan 02, 2009 | Mitsubishi WT-46805 46" Rear Projection...
Double image looks like a convergence issue
This is a Convergence issue, bad solder connections on the convergence IC's.
Nov 20, 2008 | Mitsubishi WS-55313 55" Rear Projection...
Convergence
Have you checked your convergence board to see if any of the ICs or resistors need replacing?
There's a fairly lengthy thread over at the Digital Home Forum regarding convergence issues w/the Hitachi RPTVs that I've been using for some issues I've encountered.
Take a look at it, may be similar issues encountered there and hopefully w/a solution...  -TD
Apr 30, 2008 | Hitachi 53UWX10B 53" Rear Projection...
Sony KP-51HW40 Convergence issue
Can you adjust the convergence by the convergence menu without going through the service menu? The settings through the convergence menu should save automatically. Have you replaced the convergence ICs? If so the settings should save, if not the D board will need to be replaced or at the very least rebuilt. Let me know if you need further assistance with this issue.
Apr 10, 2008 | Sony KP-51HW40 51" Rear Projection...
Bad convergence issue and moving TV
yes the bumps you go over have a chance in making any connection loose.
Feb 22, 2008 | Philips 43PP9202 43" Rear Projection...
Mitsubishi WS-73909 73" Rear Projection Television Logo
95 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
