Question about Panasonic NV-HD680 VCR
Error code H01
Anyone have a definitive answer as to what exactly the error code H01 means when reported by my Panasonic VCR?
It's been a great machine but has recently died with this report.
Would like some help because the machine features a memory of what's on my entire tape collection!
Thanks
  • Anonymous Feb 10, 2009
    I am the same problem.
    If you win this problem, please contact me
    [email protected]
    thanks
It means no head motor rotation...The full meaning is given as: After Cylinder lock is detected the cylinder does not start rotating again even after tape unloading.
The remedy/ check is given as: Check the cylinder motor drive circuit... sorry no solution but at least you know whats wrong..
Posted on Aug 21, 2009
SOURCE:
The error code H 01 in Shows my washing machine(panasonic na-f70gs)
http://www.ukwhitegoods.co.uk/help/fix-it-yourself/fault-codes/laundry-fault-codes/3328-panasonic-na-series-washing-machine-fault-codes.html
H01
Pressure sensor or level switch detected as out of range
  • Check wiring to level sensor
  • Check pressure switch is not defective
  • Replace pressure sensor
  • Replace main power PCB
Apr 06, 2015 | Washing Machines
What is Error Code H44 on Panasonic Washing Machine?
sad to say there is no H 44 listed o the 4 places I looked
Jun 17, 2014 | Washing Machines
Hoover washer dryer error code h01
Its not an error it means its in delay start mode. Hold down the delay start button (looks like a clock) for 5 seconds and it should clear
Sep 12, 2012 | Hoover Washing Machines
Yamaha dvd s-80 showing error code H01 when trying to play disc. What does this mean ?
The manual isn't much help, is it?
http://www.retrevo.com/support/Yamaha-DVD-S80-DVD-Players-manual/id/320ag210/t/2/
It seems the "H01" is some kind of common and fatal error code in many disc players and I have yet to find anyone who has paid the ransom, er cost, to get one fixed as it is cheaper and makes more economical sense to just buy a new unit...
http://www.electronicspoint.com/panasonic-sc-ht75-dvd-player-broken-t55762.html
Feb 11, 2011 | Yamaha DVX-S80 System
Panasonic VCR model number NV-HD640B comes up with fault code H01 - what is this and how do I fix it?
You have a Panasonic K Deck Mechanism, you can search for more free info on it via Google. Meanwhile H01 means no drum motor or drive, it's to do with the main VCR head not going around.
Dec 04, 2010 | Panasonic NV-HD680 VCR
How to operate the answering machine
hi friend,
Step 1Call your telephone number and wait for the answering machine to answer. If you have left the answering machine in the off state then you should let it continue ringing until the machine finally answers, this may be as many as ten rings or more. When the machine finally answers, you may hear a series of beeping sounds.
  • Step 2Press "0" during the playback of the greeting message or during the series of beeps. Enter your PIN code within the next 2 seconds. You must know your PIN code to operate the answering machine remotely.
  • Step 3Wait for the prompt to enter a command code for remote operation. You will hear the machine report the current time and how many messages are in memory. The machine will then play a beep and wait for your command. To turn on the answering machine you must enter the corresponding code. You must enter the remote command within 15 seconds.
  • Step 4Hang up after the machine finishes the command and beeps. Call back to your number and make sure that the machine is now in the on state and will answer incoming calls.
  • jQuery('.article ol .image').each(function(i,e){ var $this = jQuery(this); $this.find('img').error(function(){ jQuery(this).remove(); $this.remove(); }); }); Tips & Warnings
    • Each brand and manufacturer of answering machines have different commands and PIN codes for the answering machines. Refer to your user manual for the exact codes and instructions on how to pick your PIN number for your phone.
    hope this helps u
    please rate me.......................
    thank u for using fixya
    regards
    sivaranjini
    Dec 01, 2009 | Panasonic KX-TG2343 Cordless Phone
    I am trying to use a Panasonic AJ-D650, which hasn't been used for about 5 years. Initially the DVCpro tapes wouldn't load but they are now loading correctly. However if I press play or any other command...
    most likely problem with the AJ-D650 is deteriorated electrolytic capacitors on the mechanism drive board. when these caps fail, the mechanism will not load completely, if at all. also check for bad capacitors in the signal path from the head drum. first and easiest step is to clean the heads; often a good cleaning will restore operation to a non-playing machine.
    Oct 22, 2009 | Panasonic Televison & Video
    H01 Error
    H01 means that there is an alignment problem or there's a faulty lens mechanism. Align it would cost about $50 . If there is a faulty part , then cost would start from about $80 labour plus part.
    Aug 08, 2009 | Panasonic DVD-RV32 DVD Player
    Panasonic deck ag dv2000 gives error code f09
    Your vcr seems to use the K Mech. F04 Means that the mechanism locks unloading.
    The cause of which might be the loading motor timing.
    F09 means No serial clock linking IC2004, IC7005 and IC7701.
    Apr 29, 2009 | Panasonic AG-DV2000 Mini DV VCR
    How do I solve Panasonic SA-HT800V error code F61?
    unplugged a Panasonic HDTV plasma for four minutes, plugged back in and Now the DVD does not work.
    How to reset?
    Aug 28, 2007 | Panasonic sa-ht800V Home Theater Audio...
    Panasonic NV-HD680 VCR Logo
    1,565 people viewed this question
    Top Panasonic Televison & Video Experts
     Grubhead
    Grubhead
    Demonic-2011
    Demonic-2011
    Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
