Question about Lands Phones
Cannot get phone to ring
Some how the ringer got switched to "off", how do i turn it back on? can't get phone to ring
  • bopre53 Oct 29, 2008
    Hi...The base ringer ......rings...but somehow the other 2 handsets have "ringer volume off" in the display.....Please Help...
Have you tried going into your menu to see if the ringer is shut off. Depends on your phone, but some of them you can push the # and it will take you to your ringer volume, maybe you have the phone shut off for the ringer.
Posted on Aug 07, 2008
SOURCE:
CORDLESSGURU
  • 106 Answers
SOURCE: Ringer off, need to re-install ringer. volume control does not put ringer back on
To turn your ringer back on, you do the following. For your handset, you push Menu, scroll to ringer settings, then push select, Press select again for ringer volume, then scroll up to turn on and increase the ringer volume. Then press Save once its at the desired volume. To change your base ringer, while it is not in use, push the ringer up button until you hear the desired setting. That should fix your problems.
Posted on Mar 23, 2008
  • 124 Answers
SOURCE: ringer off displayed on base
Thanks for giving me the opportunity to help with your problem.
The "ringer off' message on the base display is referring to the ringer on the "base" unit not the phone ringers. Your phone handset(s) will still ring even when the base ringer turned off.
To turn the ringer on the base back on press and hold push the ^ symbol on the base until it beeps two times, To turn the base ringer off, press and hold the v symbol until the unit beeps.
If my information has proven to be of help, please give me good rating. Thanks for using FixYa!
Posted on Jan 28, 2009
  • 121 Answers
SOURCE: my vtech cordless phone will not ring. message is ringer off. how to turn ringer on.
I believe you can navigate through the menu and when you get to the ringer part push up on the navigation arrow. That should work. Thanks for using Fixya.Com.........Enjoy your evening!
Posted on May 30, 2009
SOURCE: Please tell me how to turn the phone ringer back
Pick up the handset.
Use the volume up and down key to pick the ringer volume level.
Your ring will come back
Posted on Aug 31, 2009
  • 19 Answers
SOURCE: How do you turn the ringer back on a T7316E Nortel
MANY TIME A PERSON DIALS WITHOUT REALIZING THAT THE ACCEPTANCE CODE NEEDS TO BE INSERTED FIRST THE Nortel T7316E?...If you want to temporarily turn them off use do not disturb (feature 85, feature #85 to turn Do Not Distrub off) Turning off the ringing permanently will require you to program the set. Programming is done on M7310, ...regards John
Posted on Mar 14, 2011
Testimonial: "Thank you for your quick response, and help! Its most appreciated. So, for my next question How do I program the M7310 :)"
I need to turn the ringer OFF on my AT&T 210/Lucent TrimLine.....sounds like a fire alarm...!!!
Search Results
FAQs - AT&T® Telephone Store
https://telephones.att.com/product-support/faqs/symptom/1591/89 Tip 1 of 8. If the phone does not ring at all, you may have the ringer turned off. The handset and base have independent ringer programming. To adjust the handset ringer volume: Step 1: Press MENU/SELECT on the handset when it is not in use. Step 2: Press ?DIR or ?CID to display Ringers, then press MENU/SELECT. Missing: lucent
[PDF]TRIMLINE® Memory Telephone 210 - Amazon S3
s3.amazonaws.com/szmanuals/62619bc8d4792f47b6654ed48c3548a3 AT&T and the globe symbol are registered trademarks of AT&T Corp. licensed to Advanced American .... Ringer Volume. The RINGER volume switch allows you to turn the telephone ringer OFF, or set it to ring at LO or HI volume. You can dial or answer calls normally when the ringer is off. Other telephones in your home will.
How to change the ringer tone on the AT&T Trimline 210 - YouTube
? 2:58
https://www.youtube.com/watch?v=xZxexCm7xtk
Apr 30, 2016 - Uploaded by kmbfanofpacman
I just figured out how that works after the day I got the phone and its pretty cool to be honest.Missing: my ‎lucent
[PDF]AT&T 210 User manual - Multi-Link Inc.
https://multi-link.net/wp-content/uploads/ATT-ATT210-Manual.pdf Make sure the ringer volume switch is not set to OFF. You may have inadvertently turned off the ringer. Press. ,. , , . If there are several other phones on the same ... 11. 12. For Customer Service Or Product. Information, Visit Our Website At www.telephones.att.com. User's manual. Part 2. TRIMLINE. Memory telephone 210. Missing: my ‎lucent
Lucent AT&T Trimline 210 Corded Phone Ring tone - Questions (with ...
www.fixya.com > ... > Lucent > Lucent AT&T Trimline 210 Corded Phone
Lucent AT&T Trimline 210 Corded Phone, ring tone related issues. ... If the ringer volume has been turned off, the handset will not ring ? ... ...ring tone im receieveing the voice ring tone but prefer the volume how can i change my ringtone When the phone is sitting in its normal mode hitting the "flash" button toggles through ...
Apr 07, 2018 | AT&T Lands Phones
My iphone 5c will not ring how do I turn the ring ton me back on?
on the left side on the phone, theres a switch, turn it on
Oct 11, 2014 | Cell Phones
Phone ringer off
It a little bit older cordless phone, I CAN'T find the model number, there's a menu/elect button on the face but I can't turn the ringer off. The base has a ringer that I turned off but the phone still rings. There are no switches on the phone or base for turning it off.
Nov 14, 2013 | Northwestern Bell 36028-2 2.4 GHz Twin...
I think the ringer is off on my NEC Dterm 80 phone. when a call comes in, I hear it ring at my bosses desk but not mine and my line is the main line. How do I turn the ringer back on. Thank you
Ringing is assigned in system programming, so if your phone doesn't ring you can't change that unless you have person on site who works on the system at that level. Some places use the night mode feature to make certain phones ring in day mode, and others to ring in night mode. Not very likely but sometimes the mode gets switched at places who don't realize they have another mode, suddenly only 2 phones ring instead of ...5. Feature,80,Feature, is the code to switch back and forth on a Pro II, an Elite, and an IPK system. This would be done at the reception phone. These phones also work on several other systems so don't know if this works for you. Or maybe you set Do Not Disturb, which would keep your ringer off.
Oct 04, 2013 | NEC Dterm DTP 32D-1 Corded Phone
Ringer is turned off and need to know how to turn it back on?
Look for a "night mode" setting. Won't ring when in night mode
Mar 15, 2012 | Uniden Cordless Phone
My phone is ringing but cannot hear the sound only blinging the light. So how can i return back the ring sound?
Only 3 things make it not ring, there's a switch for the ringer on the left side of the phone, it needs to be programmed to ring in the 40x's, or the ringer is defective. If it rings on the intercom (with the AUTO ANS) turned off, it must be programming.
Carl
Jan 24, 2011 | Panasonic KX-T7730 Corded Phone
The phone does not ring. How do you turn the ringer back on? The phone model is a hybrid system kx77020.
There's a ringer adjustment on the side of the phone. Does it ring in another jack? Does another phone ring in this jack? Panasonic system ringing is controlled by system programming, usually 408-410 or somewhere near there. If the phone works in another jack or another phone works in this jack, then you need to either turn on the ringer or turn on ringing at that port.
You may have to find the programming in the manual, or call your service tech.
Carl
Sep 03, 2010 | Panasonic KX-T7730 Corded Phone
The iPhone does not ring, only vibrates
There's a switch on the left side at the top of the iphone that turns the ringer on and off. Make sure this is towards the front of the phone to enable the ringer
Jul 26, 2009 | Apple iPhone 3GS Black (16 GB)
How do you turn the ringer back on a V-Teech 5.8 phone
yeah!! i kept playing with my phone that did not have a switch...and i finally got the ringer to come on! the volume up and down arrows are what finally got it to work, i just kept holding it down and it finally responded, try more than once if it doesn't work the first time
Jan 28, 2008 | Uniden Cordless Phone
Phone Doesn't Ring
If the phone has a dial tone, adjust the ringer loudness (this adjustment is on the bottom of some phones). Also check to see if there is a switch for turning off the ringer--and turn it on. In some cases, you can't connect more than five phones to a given line or they won't ring properly. If this is your situation, you may have to disconnect one or more phones, or at least turn their ringers off.
Jan 18, 2006 | AT&T 146 Corded Design Line Telephone
Lands Phones Logo
304 people viewed this question
Top Lands Phones Experts
Ekse
Marvin
Marvin
Are you a Lands Phone Expert? Answer questions, earn points and help others
