Question about Hunter Fan Company 5/1/1 Programmable Thermostat
Installing Hunter 44155C
I have an old 1970 ITT general control Model number T90H110A137 with the letters left to right
G F C H V and the letters on the new Hunter don't match up. I know I don't use the C wire and F & G control the fan. My furnace is a gas furnace with AC.
  • 52 Answers
SOURCE: Hunter 44630 thermostat
Here is a link that will have wiring diagram it is for a similar model hunter. Also check your dip switch on the back of the stat to ensure it is set for gas (HG) or electric heat (HE) depending on your type of unit. Good Luck. Rule of thumb for most four wire systems is RED (power to stat) Yellow (Cooling) Green (Fan) White (heat)
Posted on Jan 29, 2008
rizla
  • 1463 Answers
SOURCE: need help !!
have you tried there web site for the wireing instructions or manual to installing it.
Programmable thermostats at discount prices at
hunter-thermostats.com.
riz.
Posted on Feb 26, 2008
  • 5 Answers
SOURCE: hunter fan/light control wiring
solution depends on how many wires are in the ceiling box. was there a ceiling fan in place before? were the light and fan controlled by seperate switches or was there only one switch? if two switches, then there should be two seperate hot wires in the ceiling box. if only one switch, then only one hot wire in box. if only one, then your black and red from the fan will wire together to the single hot. green goes to the bare copper wire, if not one, then not needed
Posted on Aug 14, 2008
  • 24 Answers
SOURCE: need help with wiring on Hunter 44110
There is no real color code for wiring but the standard is red wire to r, yellow wire to y,white wire to w, green wire to g, blue wire to c. since there's no c on your t- stat its probably battery operated, but in your case im betting white wire to w, and blue wire to g.
Posted on Apr 16, 2009
kingbrizzle
  • 407 Answers
SOURCE: Switching old thermostat to Hunter thermostat model 44155c
By describing the wires from your new thermostat and your old one, it sounds like your new thermostat is not compatible with your system. If you have seven wires now, then you more than likely have a heat pump system and you have to get a thermostat that is compatible with this type of system. Then you will have the connections you need.
Posted on Jan 23, 2010
Unable to get ac compressor to start
HI,
you may get a pdf download of the manual form this site Programmable thermostats at discount prices at hunter-thermostats.com.
they may have the model you require .
Goodluck,
Please don't forget to rate the solution
Apr 23, 2008 | Hunter Fan Company 5/1/1 Programmable...
I am replacing a White-Rodgers thermostat with a Hunter 44155C and dont know where to connect the wires. I have white, red, green, blue, and yellow wires and none are labeled as to what they are.
The Yellow wire is for cooling, the white is for heating, the red is for power, the green is for blower fan, the blue is your common wire, all you should have to do is color code the wires to the thermostat. The thermostat should have the colors labeled R,W1,G,Y,B or C for common if it's wired correctly at the Air Handler or evaporator. The blue wire should go to B, or C.
May 28, 2011 | Hunter Fan Company 5/1/1 Programmable...
Jul 11, 2009 | Hunter Fan Company 5/1/1 Programmable...
Trouble Installing Hunter Brand Thermostat
on the back of the packaging for the HUNTER MODEL 44155C it states that it is not compatible with heat pumps
Mar 01, 2009 | Honeywell Programmable Thermostat Heater
3 Month baby and need help hooking up thermostat ASAP
The wire colours mean nothing. If your old one didn't have letters or you already disconnected it, you will have to go to the furnace. Under one of the panels there will be a control board to which the thermostat wires connect and this might have the letters printed on it. Trace them back and connect them appropriately.
If you have a furnace that is like mine (a single-stage natural gas one), chances are that R is +24V, C is common, W is heat call, and G is the blower. Y is generally cooling. The furnace could be turned on by connecting R, W, and G together, I suppose, if the above doesn't work... but it won't shut off automatically.
Jan 25, 2009 | Hunter Fan Company 5/1/1 Programmable...
Need help !!
riz.
Feb 17, 2008 | Hunter Fan Company 5/1/1 Programmable...
Installing a Programable Thermostat
give me the wire colors from the white rodgers and how they are connect to the white rodgers .. The white rodgers should be marked on the back where the wires connect. I can then tell you where to hook each wire to on the hunter.
Dec 20, 2007 | Hunter Fan Company 5/1/1 Programmable...
Hunter Fan Company 5/1/1 Programmable Thermostat Logo
286 people viewed this question
Top Hunter Dryers Experts
Paul Bade
Thomas Perkins
Thomas Perkins
Are you a Hunter Dryer Expert? Answer questions, earn points and help others
