Having problems installing lexmark printer on new laptop installation showed completed however it will not print have checked cables and installed and reinstalled a couple of times nothing works.
  • kmarshall769 Aug 12, 2008
    printer installs, but gives a USB error....try to reinstall, new USB, etc.....do I need a high-speed port? I have WIndows XP
  • spans Oct 10, 2008
    After installing, it could not communicate with my laptop.
Its a Lexmark Z640
Posted on Oct 10, 2008
I have installed a lexmark z22 printer but it
Try the following check-lists
1.Initially ensure correct drivers are installed in the operating system you are using .This can be checked by seeing in the device manager or in the control panel-->printers and drivers option.
If drivers are correctly installed you will the printer symbol in printer options with the name of the printer.
Right click the printer and give test page as print
If the print is not working check whether the power cables and connecting cables are good.
Check the indicators in the printer does it shows any warning.if you have manual of printer you can verify from it
Mar 10, 2010 | Lexmark C533DN InkJet Printer
I installed a new lexmark Z645 in my HP Compaqnc6120 llaptop. While printing its giving message 'Communication Not Available- the printer cannot communicate with the printer'. i have disconnected and...
I have seen that in most of the cases (with lexmark and dell printers) it is fixed by reinstalling the printer software. Be sure that you completely remove the older drivers using the cd or using add/remove programs
Jul 01, 2009 | Lexmark Z640 InkJet Printer
Can't get printer to print
I am hoping that you have you original install disk or that the windows has a driver installed alread as I believe that the Lexmark website no longer supports your printer. If you still have the install disk;
 Disconnect the printer from the computer.  Remove (Delete) the printer(software)from the computer . Reinstall the printer and software , if not a part of windows already.
Feb 16, 2009 | Lexmark C533DN InkJet Printer
My printer is not printing Lexmark 5400 series
DO NOT use the Windows 7 Lexmark Driver for the 5400 series on the model X5470 all-in-one! I just assembled a new Win 7 computer and could not get the obvious Win7 64 bit driver to work. I called Lexmark tech support several times, and the third time they conceded that you can't use it. You have to use THIS ONE!
CJS5400en.exe (just for the X5400). Make sure you UNINSTALL COMPLETELY any previous Lexmark printer driver and check the hard drive for any vestiges of previous installations BEFORE installing the new driver...and do NOT use the 'cleaning utility' file that is on the Lexmark site for Win 7 - to clean all bits of former installations first...According to tech support, it doesn't work on Win 7!! I told the tech person that the driver site needs to be more specific on which models use which drivers...he agreed.
Feb 03, 2009 | Lexmark X5470 All-In-One InkJet Printer
Wireless Printer communication problem with laptop
Please check IP, use manual IP for laptop and Printer. may AUTO IP cause this issue.
Apr 12, 2017 | Lexmark Office Equipment & Supplies
Printer installed & ready but wont print
found solution: driver software had an error while installing & only installed half the proper software. i had to uninstall the lexmark 5200 serious software completely & download it again from the lexmark website.
i talked to the lexmark customer service live chat line on their website & found out what the problem was. they are very helpful, i highly recommend using it if you have a problem with your lexmark product!
pretty simple solution, its just a little time consuming.
Nov 22, 2008 | Lexmark X5250 All-In-One InkJet Printer
Lexmark 1290 on Vista Printing Blank Pages
Fond this on the Lexmark Website. Hope it helps.
Attention Windows Vista Users
If you have installed your printer on your PC using an original Lexmark Driver CD that came with your product and you are experiencing problems when printing, you may have installed the Windows XP driver.
Follow these steps to resolve:
· 1) Disconnect your USB cable from your printer.
· 2) Uninstall all Lexmark printer drivers on your PC.
· 3) Download the correct Vista driver for your model.
· 4) While leaving the USB unconnected, Install the driver on your PC.
Important - Do not reconnect the USB cable until the install software prompts the question of how the printer is connected.
Oct 31, 2008 | Lexmark X1290 All-In-One InkJet Printer
Lexmark Printer Install - No Communication Error
With the Lexmark printers communication subsystem you MUST let the driver ask for you to plug in the printer. DO NOT plug the printer into the USB port until told to do so.
To fix a fouled install:
(1) Uninstall the Lexmark drivers in Add Remove Programs
(2) Shutdown the computer
(3) Disconnect the printer from the USB port
(4) Restart the computer
(5) Run the Driver Installation software
(6) Cancel ALL attempts by windows to auto install the printer
(7) When the software asks for the printer connect it and continue
Jul 19, 2008 | Lexmark X1150 All-In-One InkJet Printer
Lexmark z11 Vista Compatible?
Looks like I've cracked it [Touches wooden desk]. Need a USB to IEEE 1284 36-pin Parallel Printer Cable, like the one I received today (ordered yesterday from www.cables2u.co.uk). First, connect it to Z11. Turn on Z11 and boot up Vista PC/laptop. (I run Vista Business on my laptop.) Connect cable to computer. Message appears "Installing device driver software". Click it for status. 'Found New Hardware' box appears. Click 'Locate and install driver software'. A message appears "Error loading LXADSUI.DLL. Specified module could not be found". Click 'OK'. Message appears saying driver software installed successfully. ["Yeah, right ..."] (Have faith, folks!) Now, click Start, then Control Panel and double-click Printers. Right click on Z11 and click on Set As Default Printer. Right click on Z11 again and click on Properties. Check on Ports tab that Port USB is ticked for Z11. On Cartridge Maintenance tab, check right cartridge is showing. If not, click 'Install/Change Cartridge' and follow instructions. Then 'Clean Print Nozzles' and 'Align Cartridges'. Check settings on the other tabs in Properties look OK and try printing a test page! It looks good to me!
Jan 15, 2008 | Lexmark JetPrinter Z11 InkJet Color...
46 people viewed this question
jasbo
jasbo
