The air is flowing, but it is not cold. How big of problem it this to fix?
  • 182 Answers
No way of knowing that.could be as simple as a fuse or as major as a compressor.Much more info needed.
Posted on Aug 08, 2008
Symptoms of faulty air flow sensor
  • How to Detect and Clean a Faulty Mass Airflow Sensor ... www.carsdirect.com > Car Repair > Engine Repair 2012-02-24 · Symptoms of a Faulty Mass Air Flow Sensor ... Here are some of the most common symptoms of a faulty mass airflow sensor: ... CARSDIRECT IS AN ...
  • Mass Airflow Sensor: An Easy Fix for Big Problems from a ... www.airtexproducts.com/news-blog-mass-airflow-sensor-an-easy-fix... news,blog,mass,airflow,sensor,an,easy,fix,for,big,problems,from,a,little,instrument. ... Mass Airflow Sensor: ... What Are the Symptoms of a Faulty Mass Air Flow Sensor?
  • Signs & Symptoms of a Faulty Mass Air Flow Sensor www.geeksofcars.com/list_5794328_signs-mass-air-flow-sensor.html Signs & Symptoms of a Faulty Mass Air Flow Sensor. The Mass Air Flow Sensor is a device used on many fuel injected automobile engines to measure the density of air ...
  • See Bad Mass Airflow Sensor Symptoms on YouFixCars.com www.youfixcars.com/mass-airflow-sensor.html Video embedded · Mass airflow sensor problems can turn on the check engine light. They can also cause a variety of other symptoms before the ... How to clean mass air flow sensor ...
  • How to ' Tell If You Really Need a Mass Air Flow Sensor ... www.youtube.com/watch?v=aDlHCjgYf8s
    • BY AUTO REPAIR QUESTIONS ANSWERED BY WESLEY HARRISON
    • 4 MIN
    2011-08-22 · Video embedded · ... How To Clean a Mass Air Flow Meter and Tell if you really need ... Mass Air Flow Sensor ' Auto Repair ' Wesley Harrison ... Sensor Symptoms ...
  • Videos too.,
  • Go to Bing homepage
    Jul 09, 2016 | Cars & Trucks
    How do fix a/c on 2003 yukon it blow cold then hot than back to cold
    A few possibilities:
    Stuck or inoperable Air-flow Diverter:
    There are tow types of air-flow diverters: Vacuum Actuated and Slide-Cable Actuated (some will have an electric solenoid that controls a vacuum actuated type). In either case the default position of the diverter is "cold air" or closed - blocking air flow over the heater core. Sounds like it may have a vacuum actuated control - when it looses vacuum it will let the air-flow diverter swing shut blocking off air blow through the heater core resulting in "cold air" Could be a bad control/slider, bad or loose hose, or bad actuator. If you remove the blower motor assembly you will be able to see the diverter and might be able to tell the issue is.
    Stuck or inoperable heater valve:
    This valve controls the flow of engine coolant to/through the heater core. It is normally closed - blocking flow. This can be vacuum operated or cable controlled just like the air-flow diverter. Simple to check - in the engine compartment, to the left of the engine locate the cooling (heating) lines that go into the fire wall - locate the valve and check its operation.
    Another possibility is low coolant level in your engine/radiator which may be too low to allow flow of the coolant through the heating coil, although you would likely notice that the engine was over heating/running hot.
    Sep 13, 2014 | Flex A Lite 2003 GMC Yukon XL - 6.0L V8 -...
    Car willl start when its warm out but not when its cold outside
    should be able with obd-2 tester to retrieve the code-- best guess mass air flow--big unit in front of air filter box
    May 18, 2014 | 1996 Pontiac Firebird
    I have an American Sandard 15 Sheer 4 ton unit in the attic in South Louisiana. The a/c drain line from the unit is sweating all the way to the riser vent and down the riser into my wall. It appears that...
    First, air should not be blowing through the trap. The trap is there to isolate the air and to make sure condensate flow is proper. Start by increasing the depth of the trap. The condensate is going to be relatively cold, in the range of 58 degerees F to the Attic's OH MY GOSH hot. Pick up some foam insulation at your favorite hardware or Big Box lumber yard and insulate the pipe.
    Jul 19, 2010 | American Standard Heating & Cooling
    Problem: the cold water just dribbles out when filling the tank and it takes forever to fill the tub.no problem with the hot water flow.
    If you have water pressure to the cold inlet valve and the valve's filter is clear, you probably have a failed inlet valve...Replacing the cold valve should fix the problem..Not a big or expensive job..Good luck....Nomess
    May 20, 2010 | Washing Machines
    Air flow meter
    air flow meters are expensive i would first replace the coolant temperature sensor
    May 28, 2009 | 1996 BMW 318
    Air flow prob
    the linkage that runs the blend door isn't working, these are the doors that control hot and cold and air flow to dash floor ect...they are located in the air box behind the dash ................ you may be able to pull the heater controls out of the dash and spot the problem but it's likely that the problem is in the air box itself and removal of the entire dash is required (big job!!!!!!!!!).........if your vehicle uses vacuum to control this (some gms use vaccum and some a cable)you might have a hose disconnected under the hood by the heater fan.........if it's a cable it may be knocked off at the dash controls or at the other end on the heater box..........sometimes removal of the glove box will give you acess to this connection.
    hope this helps..........thanks fro choosing FIX YA!
    Dec 29, 2008 | 1997 Buick LeSabre
    Heating & Cooling Logo
    55 people viewed this question
    Top Heating & Cooling Experts
    Paul Carew
    Dan Webster
    Dan Webster
    Tim Whalen
