Question about Konica Minolta Maxxum 7D / Dynax 7D Digital Camera
Won't take pictures
My Konica Minolta 7D stopped taking pictures. It will still auto-focus, but nothing happens when you press the shutter button all the way down.
  • 5 more comments
  • cbroas Aug 12, 2008
    It is a problem with the antishake and Sony will not take responsibilty for this defect. They will tell you to try all kinds of things and then they will quote you a $281 minimum charge to fix the camera. Bear in mind this is a minimum charge. I'm very unhappy and encourage you lodge your complaint with them at the Sony support center online.
  • okccadman Sep 19, 2008
    Mine does the exact same thing.
  • daveyjane Sep 28, 2008
    mine, too. All 5 antishake lights light (with antishake on) and a reboot (off and on again) does not help (the manual's idea). Turning off Antishake turns off the lights, but the shutter still does not release. Even under point and shoot conditions with a nice fast shutter speed and reasonable f/ stop in normal light conditions. Newly charged battery and newly formatted CF card. What to do? Any other setting ideas?
  • ddollahan Oct 20, 2008
    Same issue-turns on, but shutter won't fire.
  • jm-dfb Jan 23, 2009
    I guess I have the same problem, and the solution is a good thought, but it won't work with my camera :(
  • Anonymous Mar 19, 2009
    I had the same problem. I sent it to Sonny for repairs three times. The problem was random. Some times the shutter worked for 50 shots and then quit. Some times it quit working after 4 shots. Sonny charged me for the second time, but never worked. The third time they charged me again stating that the guaranteed time had lapsed. I just got it back yesterday with "no charge". This time they claimed that this is a problem with the 7D and they will pay for the repairs. Will see.........
  • buster1011 May 11, 2010
    tried it but it didn't work camera still appears to power off and freeze any other suggestions
  • 6 Answers
Symptom 1: referred to as FFB (Firts Frame Black). this is when you do not use the camera for a while and when you attempt to take the first snap shot, the Shutter is either stuck, or takes a blank/black picture (some cases the picture came out bluish). Sometimes the camera would freeze and you would need to remove the battery and re-insert it in order to reset the camera. Usually the camera comes back to life and and is usuable for a while until you store it. Sony will fix this free as they identified it as a design flaw in which the remedied (incorrect gear size for the Shutter charge assembly). Contact Sony support as they own all Minolta camera assets and tell them you have the FFB or First Frame Black problem and they will set up a ticket and instructions on where and how to send it.
symptom 2: Camera does not respond at all to the shutter release. Focus is fine, menu works, every function works no problem except for the most important - taking a picture (releasing the shutter). When you first turn on the camera, you hear the Antishift module attempt to center the CCD with a series of clicking noise for 5 or so seconds (not a good sign, also called the death rattle). All 5 AS bars in the view finder are blinking. In this case, the Tebure Assembly (AS Module) has failed and will need replacing. This is not cheap - sending it in to Precision Camera will run you around $250-$280. You can do it yourself if you order the assembly from Sony: Item - ( TEBURE ASSY ), U3008233U, $118.22 ea. via 1-800-488-7669 (will take 3-4 weeks). And follow the service manual to install and calibrate it (via the service manual download at http://www.dyxum.com/dforum/topic36109_post396839.html#396839).
Posted on Jun 19, 2009
  • TSYA Jun 23, 2009
    An update from some friends on other forums - if you have experienced the FFB in the past but your Camera has suddenly began to experience the permanent AS failure (5 AS blinking lights no matter what you do). Sony will have this repaired for free of charge. They are still honouring the advisory that Konica Minolta issued on the incorrect gear used in the Shutter Charge assembly (The FFB - First Frame Black issue). The quoted charge of $281 is a one time charge for all the repairs needed to bring your camera back to factory specs. However, if it is determined that you had the FFB logged in the camera (its logged as error 58 and the repair shops have the tools to read the error logs that are safely stored in the camera) - Sony will pay for the repairs - included the AS failure as its one price for all repairs and Sony will cover it. Call up Sony ASAP to set up ticket as rumour has it sony will not do this forever and it may end very soon. Contact information is here: http://ca.konicaminolta.com/support/cont...
  • TSYA Jun 23, 2009
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Same thing happened for me after I did not use the camera for a while with the dead battery left in the camera for a long time. After a while of reloading camera firmware and resetting defaults, I came to this conclusion. You need to do a mock CCD cleaning on the camera which a built-in feature of the 7D, in which the camera locks up the mirror momentarily so you can clean the CCD. But of course you do not need to clean the ccd at this point. Below are procedures to help get your camera back in operation.
1.Try turning the camera off, then take out the battery.
2.Then replace the fully charged battery back in and turn the camera on but do not take any pictures.
3.Go to the menu of your camera and activate the CCD cleaning, which will activate mirror lockup.
4.You will hear a mirror lock up/half exposure cycle sound.
5.One you hear this, take the lens off and make sure you can see the CCD but do not touch the CCD or allow dust to get on it.
6.Now place the lens back over the camera and turn the camera off.
7.You will hear the mirror unlock itself, then the camera will shut down.
8.Now turn the camera back on and start taking pictures.
This worked for me and my camera started taking better pictures; however, the same problem came up again when I let the camera sit too long with a dead battery. So I repeated the procedures and my camera is back.
My advice is never leave a completely dead battery in the camera. Always store fully charged batteries in the camera.
-Jay
Posted on Oct 29, 2008
Need Konica Minolta Maxxum 7D service cerntre
Posted on Aug 14, 2010
2 Suggested Answers
  • 6 Answers
SOURCE: anti-shake problem
symptom 1: referred to as FFB (Firts Frame Black). this is when you do not use the camera for a while and when you attempt to take the first snap shot, the Shutter is either stuck, or takes a blank/black picture (some cases the picture came out bluish). Sometimes the camera would freeze and you would need to remove the battery and re-insert it in order to reset the camera. Usually the camera comes back to life and and is usuable for a while until you store it. Sony will fix this free as they identified it as a design flaw in which the remedied (incorrect gear size for the Shutter charge assembly). Contact Sony support as they own all Minolta camera assets and tell them you have the FFB or First Frame Black problem and they will set up a ticket and instructions on where and how to send it.
However, if your camera experienced the FFB and then siezed (symptom 2) you can probably still get Sony to repair it free as its one charge for a complete camera repair. Call them up and tell them your situation.
Camera won't take pictures.
Go into the settings and select Clean CCD. It should be under the blue menu. The shutter curtain has a tendency to stick on this model. There was a recall on them way back when they first came out. 1a53cc1b-6da0-4b38-942c-78caadf51633.gif 1bcf9dee-9615-448f-a170-16ef0e446320.gif
Aug 18, 2014 | Konica Minolta Maxxum 7D / Dynax 7D...
Shutter release is slow, I press the shutter release and the camera doesn't take the photograph for a second or second and a half. I'm in auto or sports settings
To get it to instantly take the picture, you must press the button half-way and allow the camera to lock in the focus (it will beep)...then when the moment is right, press the rest of the way.
Oct 29, 2010 | Konica Minolta DiMAGE Z20 Digital Camera
M42 adaptor
Quite right too. When the M42 adaptor is fitted there is absolutely no exchange of information between the lens and the body: M42 lenses pre-date all of those later developments. Your camera will also be unable to stop down the lens automatically when taking the picture, most M42 lenses don't even stop down automatically when connected to an M42 body.
You need to do things the old-fashioned way. Your camera needs to be set to meter manually, shutter priority mode may also be used. In manual mode you focus the lens as normal with the aperture ring set to the lowest aperture number (i.e.aperture is wide open).
You then make sure that the lens in in manual mode as well and stop down to whatever you want, if the image remains bright enough then you can adjust the precise focus using the hyperfocal principle if you like which takes advantage of the increased depth of field of a stopped down lens.
In manual mode, you then tell the camera what aperture you have set (read it from the lens barrel) and set the shutter speed using the camera's light meter to guide you. If using shutter priority mode then the camera will choose the shutter speed for you.
Check everything is set as you intend and press the shutter.
It all sounds long winded but is exactly how many of the world's greatest photos were taken and soon becomes second nature. You also learn far more about the relationship between aperture, shutter speed and ISO settings and will be able to talk about reciprocity like you know about it!
Jun 26, 2009 | Konica Minolta Maxxum 7D / Dynax 7D...
Anti-shake problem
Jun 02, 2009 | Konica Minolta Maxxum 7D / Dynax 7D...
BLANK (BLACK) PICTURES
Yes this is a common problem. Set the camera to take a long exposure shot (5 seconds) and with the lens off take a photo. Can you see the ccd or just the shutter (black)? If its just the shutter the shutter is jammed. It's basically a question of persisting with rebooting the camera and taking shots until the shutter frees itself.
Jul 23, 2008 | Konica Minolta Maxxum 7D / Dynax 7D...
7d camera stutter..........
vibrating sounds, flashing shake indicator, shutter won't release...
It's a fault in the camera and has to be repaired at the shop, Sorry, I know it's not the answer you were hoping for, but it's a depressingly common problem on the 5d/7d forums.
Jun 04, 2008 | Konica Minolta Maxxum 7D / Dynax 7D...
My 7d is stuttering?!
Maxxum 7D Not Taking Pictures
your having a problem with the antishake
Apr 19, 2008 | Konica Minolta Maxxum 7D / Dynax 7D...
Shoots blank (dark) pictures after switching on.
This is a known design defect in the cameras and Sony is repairing them, even if your warranty is expired.
see this for Konica Minolta's official statement:
http://ca.konicaminolta.com/information/20070202/01_en.html
it'll direct you to a sony page where you can sign up to get your camera repaired!
more info can be seen here:
http://www.dyxum.com/columns/other/First_Black_Frame/First_Black_Frame.asp
Nov 12, 2007 | Konica Minolta Maxxum 7D / Dynax 7D...
Konica Minolta Maxxum 7D / Dynax 7D Digital Camera Logo
1,906 people viewed this question
Top Konica Minolta Cameras Experts
Greg Cann
Greg Cann
Willem.
Willem.
Are you a Konica Minolta Camera Expert? Answer questions, earn points and help others
