Question about Acer Aspire 5100 Notebook
AC adapter does not work
The adapter when plugged in lights up then dies down, checked fuse.
    Problem Solver:
  • 10 Answers
If you fill do one last thing just go to the nearest Acer service centre
Posted on Aug 09, 2008
Tha half moon light blinks green,standby light also blinks with battery light orange light when charger is connected to my thinkpad t61p ,no booting
Step 1:
Try removing the battery from the back and then running it directly through the AC adapter. Sometimes the battery and AC adapter have conflicts and it can cause a laptop to become inoperable.
If this doesn't fix the problem in any way, I would recommend trying a new battery or AC adapter.
hope this helps Take the battery out, plug in the charger and see if the laptop works. If it works, the battery may be the problem. Check the AC Adapter
Check to make sure the adapter is plugged securely into the wall outlet, connected firmly to the adapter box and to the back of your laptop. Most AC adapters have a little light in them on that rectangular box in the middle of the cord that lights up when it's getting electricity. If that light isn't on, try a different outlet. Check your fuse or circuit breaker box and plug a different device into that outlet to make sure there is power to it. If it still does not light up, your adapter could need replacing. Also check the adapter box for signs of warmth, as it will generate heat when it's plugged in. No heat means no power.
Remove the Battery Sometimes it's as simple as a seated battery. Remove the battery entirely and clean out any dust, lint or hair that may be clogging the connectors and preventing a proper connection. Reseat the battery securely and make sure the little locking pins that hold your battery in place are securely fastened and there is no movement.
Feb 17, 2013 | Lenovo ThinkPad T61p 15 inch widescreen...
My pandigital e book has died completely,It will not come on. I have had it plugged in but the red light will not light. It is dead. What is wrong?
I would start by checking the ac adapter to make sure that it is working using a multimeter or voltmeter. You can probably take it to a computer shop and get them to test it for you. If the AC adapter is working, then you'll likely need to have the device serviced.
Sep 20, 2011 | Computers & Internet
Our Wii console will not power on and there is a disk in it.
Follow the directions below to see if this helps. If not, you may need to contact Wii technical support for repairs.
power issues with the Wii can be fixed by resetting the AC adapter. You can easily reset the AC adapter by following these steps:
  1. Unplug the Wii AC adapter at both ends (from the back of the Wii system and from the wall outlet or power strip). acunplug.png
  2. The AC adapter must remain unplugged at both ends for a full 2 minutes.
  3. We also recommend you unplug anything connected to the USB ports and the Nintendo GameCube Controller ports (such as LAN Adapters, keyboards, Nintendo GameCube controllers, etc.).
  4. While you're waiting, check the AC Adapter for the following:
    • Make sure that the word "Wii" and the model number "RVL-002 (USA)" molded into the AC adapter. Unlicensed products are not fully compatible and may not work correctly.
    • Check the AC Adapter for physical damage. Physical damage, such as frayed wiring or a cracked housing can cause the system to shut down. If your AC Adapter shows signs of physical damage and needs to be replaced, you can purchase one from Nintendo's online store.
  5. After you've waited 2 minutes, plug the AC adapter into the Wii system and directly into a wall outlet, not a surge protector or power strip. If the power light comes on and stays on, then it appears resetting the AC Adapter worked. If resetting the AC Adapter did not fix your power issues, please continue reading:
    • Avoid the use of unlicensed products such as memory cards, controllers, and cheat devices. Some of these products are poorly manufactured and may result in damage to your system. If one of these products is attached to your system, remove it and try resetting the AC Adapter (see above).
    • Check any accessories that connect to the Nintendo GameCube Controller ports or the USB ports of the Wii -- whether licensed or not -- for physical damage. Physical damage, such as frayed wiring or a cracked housing can cause the system to shut down. Remove any damaged products and try resetting the AC Adapter again (see above).
    • Make sure the Wii has good ventilation. Avoid operating the Wii while it's on carpeting or inside an enclosed space. If you have the Wii placed in a vertical position, make sure the vent on the bottom is lined up properly with the hole in the plastic stand and no foreign material is obstructing that hole.
    • Check the vents on the back and side of the Wii for dust build up. The system will shut down if it cannot vent properly to prevent overheating. If there is a build-up, remove it using a vacuum cleaner with a soft brush attachment.
    • Make sure that your wall outlet works. To check it, try plugging a lamp into the same outlet where your system was plugged in. Turn the lamp on the verify the outlet works. Also, make sure you are not using an outlet that is operated from a wall switch. If you do, make sure the wall switch is in the ON position.
    • Make sure the AC adapter is attached properly. Firmly plug your AC adapter into the back of the Wii (the port is labeled 12V IN) and into a working wall outlet (not a power strip or surge protector). Click here for detailed instructions.
    • Once plugged in, check the power light on the Power button to see if the system is receiving power.
Click here to contact Wii support
Regards,
G33k
May 05, 2011 | Nintendo Wii Console
I have no power to my wii what could be wrong
    Most power issues with the Wii can be fixed by resetting the AC adapter. You can easily reset the AC adapter by following these steps:
    Unplug anything connected to the USB ports and the Nintendo GameCube Controller ports.
    If resetting the AC Adapter did not fix your power issues:
    Check the vents on the back and side of the Wii for dust build up. If there is a build-up, remove it using a vacuum cleaner with a soft brush attachment.
    If the power is still continually shutting off regularly, contact Wii support.
Apr 08, 2011 | Nintendo Wii Console
Suddenly died with blue screen of death. will not turn on again. when I press power button, it lights up and battery light lights up also. as soon as I take finger off the button, nothing. tried...
No guarantee but you can try this. Remove the battery and unplug the AC adapter. Hold down power button for 30 seconds. Plug in AC adapter but leave battery out. Try to restart computer. If it starts, reinstall battery. It worked on a Gateway I was working on last week. Worth a try.
Aug 27, 2010 | Dell Vostro 1500 Notebook
Wellf irst it would not load certain games and not
1. Try plugging something else into the socket to ensure the socket itself is working.
2. Changing the fuse in your Wii power adapter, blown fuses are very common and this could be it.
3. If number 2 doesn't work try and get a hold of a replacement power adapter as the problem could be a break in the wire. If you need a new adapter you can go here NDSL games console, ds games console, NDSL games console_Video games Console_www.goldenbridge.hk
Mar 23, 2010 | Nintendo Wii Console
Laptop died suddenly and is not charging
Take the battery out and discharge the capacitors by holding down the power button for 15 seconds. plug in the charger without the battery in to see if you get a charge light. If you do, replace battery and plug in charger and power on laptop. If this does not work, you may have to pull the cmos battery for 15 minutes and try it again.
Oct 03, 2009 | Computers & Internet
Beeping AC Power Adapter
I've had problems with Dell AC adapters before. The usual cause that I've seen is that connection of the output cable from the adapter to the PC becomes intermittent. The units I had developed problems where the cable enters the adapter though it could happen at the connector itself too. If it is causing it to squeal and die then the cable is probably shorting out. You can test this theory by moving the cable around at those points and seeing if it dies or comes back on.
With my adapters, there was a strap that could be used to clamp the cable around the adapter. On my replacement unit adapter I quit using the strap and it worked okay after that.
-jodair
Apr 06, 2009 | Dell Studio 1737 Laptop
No power. Adapter light flashes when connected to laptop
thanks for using fixya!!
Please do and observe the following:
1. Uninstall the battery pack.
2. Then, connect the AC adapter, we will try to use the power coming from the AC, then turn on your laptop.
3. Observe what will happen.
4. If still doesn't work, install again the battery, then connect the AC adapter, check if its going to work.
5. If not, perhaps you have a problem neither with the battery or the AC adapter.
I suggest that you bring your laptop to a service center. Good luck!
pls rate me positively! thanks!
Mar 30, 2009 | Acer Aspire 3680 Laptop
Karen died
If the unit works on battery but not the AC adapter or cigarette lighter adapter, obviously the problem is in the adapter.
1. Have you verified that you have +12VDC at your accessory jack?
2. Have you checked the fuse in the cigarette adapter?
What are you powering it with when not on the battery?
- Jim
Feb 15, 2008 | Garmin StreetPilot c340 GPS Receiver
Acer Aspire 5100 Notebook Logo
20 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
