Question about OKI C3400n Laser Printer
Can i reset the drum life on an oki c3400? - OKI C3400n Laser Printer
    Master:
  • 412 Answers
On Oki C3200, there are only 2 terminals on the RH end of the drum -- those are the two you need.
I had trouble getting the wire tucked under the terminals on the drum. What I did that worked was just hook the wires to the spring contacts on the printer frame. Put a piece of black tape over the metal frame just to make sure no short between the frame and the wire. I also found a piece of black tape to retain and keep some tension on the wires worked well.
Analog VOM worked just as advertised -- thanks so much for a quick, easy, no-cost drum reset solution.
Photo attached.
can i reset the drum life on an oki c3400? - e5e98aa4-e915-446a-9de5-b439a26aab96.jpg
Posted on Feb 27, 2014
SOURCE:
SOURCE: How do you reset the OKI c5800 drum?
You don't need to go through all that mess of replacing the fuse. The tone gets everywhere and getting the Drum unit back together with all the gears and shafts lining up is a real pain.
The Drum reset system is very simple. When the printer powers up and runs through its system check, one of the tests energizes the erase LED array built into the Drum unit. The reset fuse routes a small amount of low voltage current off this LED array. There is a contact on the end of the Drum unit that the printer senses. It there is voltage there (ie the fuse is good), the printer resets that Drums counter to 100%. If there is no voltage (ie the fuse is blown), the printer continues on its way.
All you have to do it act like fuse at the instant the printer sends power to the LED array.
There's no soldering, no screws to undo, and no toner all over the place.
The best thing is it takes about 3 minutes start to finish and cost $0.00!
Here's what you need:
• A simple volt/amp meter (an analog one works best, but digital is fine also) • Two pieces of thin wire about 300mm long. I used old telco wire. With insulation, its about 1mm wide. • A pair of scissors to strip the wire ends • X-acto or thin razor knife
1) Strip about 4-5mm off the one end of each wire and 25mm off the other end. Bend the 5mm end at a 90 degree angle right at the base of the stripped part. 2) Pull out the Drum unit (leave the toner cartridge attached to the Drum unit) 3) On the right end of the Drum unit (DU) there are three square brass contacts about 3mm wide. The right end is the end with the blue handle. Looking at the end of the DU, you are interested in the 1st and 2nd contacts from the left (they are the two closest to the screws on a c5800 cartridge) 4) Use the X-acto knife to lift the contact metal and slide the 90 bent end of the wire under the contact. Do this with the other wire on contact #2. 5) Put a little vertical tension on the wires and route them around the blue toner release handle. 6) Gently insert the DU/toner cartridge into the printer. Keep slight tension on the wires until the unit is seated. 7) Wrap the 25mm stripped end of the wires around the volt meter leads. Wrap one so it makes electrical contact, but you could pull it apart instantly at the right time. 8) Set your voltmeter to the lowest amp setting. I put mine on 200micro amps. Also make sure your voltmeter leads are in the correct holes of the voltmeter. You want the amperage or milliAmp holes not the voltage holes. Don't forget to turn the meter on. 9) Get prepared to pull one of the leads off of the one of the thin wires and turn on the printer. Don't be afraid to touch the metal of the wire; the voltage/amperage supplied to the LED array is very low and will not hurt you. A 9 volt flashlight battery is more dangerous. 10) About 10 seconds into the startup routine, you will see you voltmeter display a reading. Instantly pull the leads apart.
Congratulations, you are now officially a 1/16amp fuse.
Your printer will reset the Drum Unit counter and you have another 20K impressions (if the image quality is acceptable to you)
If you have any question, just respond to this post. I'll get the email and answer you.
Good Luck.
Paul
Posted on May 22, 2010
  • 1126 Answers
SOURCE: OKI c5100 flashing "K drum life" across screen. what does this mean?
"K" drum refers to Black drum Apparently the black drum has reached its life expectancy and needs to be replaced.
Posted on Jun 07, 2009
SOURCE: oki c3400 toner sensor error
I found the solution here.
http://www.c3400.co.uk/index.asp?menumode=0&content=sensorerror
A plastic thing was closing the sensor window. Open the window and you will solve the problem.
Gouval.
Posted on Jan 26, 2009
SOURCE: On an OKI C3400 the alarm lights blinks amber once
THIS SOLUTION IS FOR AN OKI C3400N ONLY
As I'm sure you know, that blinking amber light indicates that:
  1. A toner lock is not fully "locked", or
  2. A toner is empty, or
  3. A drum is empty or near empty
The first question should be what does your C3400 monitor software tell you is wrong? I am assuming it said the black toner and/or drum needed to be changed - so you are fairly certain it is the black that is where the problem is? You may also have run the report from the printer that you get by pressing the "On-line" button and seen what is failing.
Assuming that is the case, and one or both of these signals an empty black toner, the problem may be in the new black toner cartridge. You can try this:
  1. Make sure the toner "lock" on all toners is fully engaged - assuming they are
  1. Open the top
  2. Lift out the entire black assemble including the toner and drum components.
  3. Keeping the assembly in the same orientation as you lifted it out, look on the RIGHT end.
  4. You should see two metal contact points, near the top at about the same level as the top of the toner.
  5. Just below these contact, you should see a small, rectangular hole - about 1/4" square.
  6. If you look in there you may see what looks like a small piece of black plastic that covers the hole from inside.
  7. If so, take a small pointed object (like a bent paper-clip) and gently reach in the hole and touch the small plastic piece on the inside that is covering the hole.
  8. You should be able to gently lift that piece of plastic UP.
  9. You may have to try lifting it a time or two, but it should stay UP if you have a new black toner installed.
  10. Once you have it UP carefully reinstall the assembly.
  11. Close the top and let the printer recycle.
  12. You may need to try this a couple of times to get the plastic to stay up on your new toner.
So you understand, here is what may be happening. That little piece of black plastic actually sits in line with a sensor in the printer that monitors toner / drum levels. When a new toner is placed in, that piece of plastic should be UP, so the sensor can monitor the level. As the toner gets used, the plastic liece gradually falls down until it completely blocks the sensor - indicating the toner is empty. That is how the monitoring software knows how to signal you.
This has worked for me several times - most especially when I tried using non-OKI OEM 'compatible" toners - but no guarantees this will help you
Posted on Jan 23, 2010
pineworks
  • 4345 Answers
SOURCE: OKI C8600 Replace Image Drum - 563: K Drum Life
Solution:
  • Power on printer while holding both the + & - buttons simultaneously; release when “OKIUSER” is displayed.
  • Press either the + or – button until “ENGINE DIAG MODE” is displayed; press the Enter button and “DIAGNOSTIC MODE xx.xx.xx” will be displayed.
  • Press and hold both the - & On-line buttons simultaneously until “ENG DIAG LEVEL2” is displayed.
  • Press either the + or – button until “CONSUMABLE COUNTER SET” is displayed, press the Enter button; you are now in the menu to set various consumables.
  • Press either the + or – buttons to scroll through the various consumables, at the desired consumable press the Enter button and the last digit of the count will start flashing.
  • Press the Cancel button to decrease the digit amount or press the On-line button to increase the digit amount; press the + or – buttons to move along individual digits in the count.
  • Once the count is at the level you desire, press and hold the On-line, Cancel, & Back buttons simultaneously until the “*” reappears next to the count; consumable’s count are reseted to the number you specified.
  • Press the + or – buttons to move to the next consumable and repeat at step 5.
  • Once all consumable counts have been set to desired amounts that are below their end-of-life thresholds, you can use the Back, +, & - buttons to exit through the menus
  • until “INITIALIZING” is displayed.
Posted on Jan 30, 2010
Can I reset the belt
How to reset your OKI C3300 C3400 C3600 laser printers ...
? 2:40
https://www.youtube.com/watch?v=czyqKMpy2-E
Oct 6, 2014 - Uploaded by Toner Man
How to reset your OKI C3300 C3400 C3600 laser printers drum unit ... drum message you can install the chip on your drum unit and continue printing. ... Replacing the Transfer Belt on an OkiC3000 Series Printer - Duration: ...
Nov 26, 2015 | OKI C3400n Laser Printer
Oki c3400 fuser?
The C3400 Fuser part is available for $181.32. Just call 800-414-8745 and reference part number 43377001.
Jul 11, 2014 | Oki Electric Industry Oki C9650hdn 512mb...
I have just put new toner cartridges in my Oki C3400 and I am getting the message of "toner sensor error"
look this solution http://my.okidata.com/oki-faq.nsf/FAQCentral/C384D8F74A91CF6E8525765E0065F636?OpenDocument
here the solution for your problem
i hope that it's helpful .... bye
Mar 05, 2010 | OKI C3400n Laser Printer
I have an OKI C3400 color laser printer. Can the
The counters reset when you install the new drums. Did you purchase Oki drums or were they after market drums..that could be the problem.
Feb 11, 2010 | OKI C3400n Laser Printer
Toner Error
Check to make sure that the sensors are clean and play around with the lock arms. Reset the machine and also download the utility from the oki service website to get exact error message. http://www.okic3400.co.uk/library/downloads/utilities/c3300c3400smv1115.exe
Jan 27, 2009 | OKI C3400n Laser Printer
I have an Oki C3400 that wont print
Could very well be the sensor window. I suggest looking at the side of the drum on the right side and pushing a q tip into the opening. heres an older model thats sort of similar instructions. http://www.c3400.co.uk/index.asp?menumode=0&content=sensorerror
Also you can check the exact error code here. http://www.okic3400.co.uk/library/downloads/utilities/c3300c3400smv1115.exe
Dec 10, 2008 | OKI C3400n Laser Printer
Oki c3400, Have replaced cyan toner 3 times now but still saying toner empty cyan
Check the window on the side of the drum where the sensor sits. It is on the right side of the drum and can be pushed open with a Q tip it is a small black window.
Nov 20, 2008 | OKI Office Equipment & Supplies
HOW TO RESET BLACK DRUM AND COUNTER
conseguí el programa de matenimiento , y coloco la impresora en modo de fabrica para envío, y la impresora continúa imprimiendo
Nov 01, 2008 | OKI C3400n Laser Printer
Oki c3400 paper jam
Run Status Monitor and make sure it is really a paper jum that prevents printer from printing. It is very likely that another reason is in place. For instance - toner empty of change drum request. All of this causes the "Attention" LED to blink: it's not only paper jam that causes it.
Oct 07, 2008 | OKI C3400n Laser Printer
OKI C3400n Laser Printer Logo
2,089 people viewed this question
Top OKI Office Equipment & Supplies Experts
Steve Allison
Steve Allison
WTF Chuck.....
WTF Chuck.....
Clive
Clive
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
