Question about IBM Wheelwriter 30 Typewriter
Wheelwriter 30 paper advance
This wheelwriter just started advancing the paper with each keystroke. I cannot type ina straight line now.
Very frustrating!
  • 1 more comment
  • jollyjp Aug 11, 2008
    There are no knobs on the ends of the platen, & I still have the problem. Please suggest something else.
    Shirley Jolly
    e-mail address cannot be found according to my computer & the web-site is no help at all.
    I tried to turn platen on left side, again. Something clicked, & it started working right.
    Thanks guys!
    Shirley Jolly
    Genius:
  • 1,665 Answers
If you havent a manual you can get it from link below but unfortunately is not for free.
http://www.typewriters.com/ibm-typewriter-manuals.html
Posted on Aug 11, 2008
  • 10,594 Answers
IBM guys will guide you better in this case, contact detaisl are as follows...
IBM North America
590 Madison Avenue
New York, NY 10022
United States
Tel:
Toll Free: 1-800-IBM-4YOU
(1-800-426-4968)
E-mail:
askibm@vnet.ibm.com
Web site:
www.ibm.com/us/
Hope above info might help you out.
  • Shahid Electronics
    Shahid Electronics Aug 11, 2008
    IBM hardware, software, and systems support
    1-800-IBM-SERV
    (1-800-426-7378
    Guru:
  • 1,894 Answers
The paper release lever may be in the release mode. try holding the left platen knob and pulling lightly on the paper is should not allow the paper to move freely, if it is ok try holding the left knob and turning the right knob in the direction you would to turn the paper in it may have come loose if so turn it all the way back in do not over tighten it your machine does not click when the platen is turned it uses electronics to hold the platen on line.
credits : JUSTOLDJIM
thank you
Posted on Aug 08, 2008
Paper Bail Load lever advances paper all the way out of machine. How do I change this? dianna
With the machine on pull the paper bail forward, let it run until it quits, then use the paper down button and run the paper back 20 lines or so, hold the code button and pull the paper insert forward. That re-sets the stopping place, keep doing this until you get the paper insert to stop where you want it.
Jul 14, 2010 | Lexmark Wheelwriter 3500 Typewriter
How do I cancel the RePrt option?
The reprint stores info. as you type to clear it pull the R. Upper roll arm to engage paper feed, the first keystroke will start the reprint over. You can also turn it off and on.
DickyO
Dec 23, 2009 | Lexmark Wheelwriter 1500 Typewriter
How to delete memory on RePrt
If you pull the R. upper bail arm to activate the auto paper insertion will clear the reprint, turning it off will also do it. There is no way to stop it from storing data as that memory is also used for correction.
DickO
Dec 10, 2009 | Lexmark Wheelwriter 1000 Typewriter
IBM Wheelwriter 15 beeps on the sixth keystroke
It sounds like the R. margin is set at that place. Space to the r. as far asd you can and press the R. margin key on the left side of the keyboard.
DickyO
Jul 30, 2009 | IBM Office Equipment & Supplies
Typewriter is working fine but won't type anything on the paper - new ribbon / new printwheel - no impression. Appears to be stuck on a
Try typing on a mulipart form. If it types on the copies and not the orinonal the ribbon is the problem. If it dosen't type on the copies then the plastic cap on the print solenoid is broken.
We sell the cap with installation instructions for 20.00 includes shipping.
DickyO
216-241-0027
Jun 02, 2009 | IBM Wheelwriter 30 Typewriter
The platen does not turn to advance the paper to the next line when typing so each line is just typing over the next.
Remove the platen by squeexing the black plastic retainers at both ends of the platen and lifting it out. Look for debris under the platen, press paper up key and see if the gear on the left end is moving, if it is the gear on the platen may be broken (new platen) or if someone has been in here check to be sure the paper tray is properly installed (rounded edge to the rear).
DickyO
Apr 08, 2009 | Lexmark Wheelwriter 3 Typewriter
IBM Wheelwriter 3 not printing letters ( keystrokes)
The print solenoid cap is probably broken,they are available but a little yricky to install.
DickyO
Jan 26, 2009 | IBM Wheelwriter 30 Typewriter
Writer beeps w/keystroke and does not type.
You are probably in a format mode that was set up for 12 piych printwheel. Install a 12 pitch pwintwheel or exit the format mode.
DickyO
Dec 31, 2008 | IBM Wheelwriter 30 Typewriter
PAPER FEED
You probably have a keyboard problem. With the T/W turned on tap the space up key and the micro up & down keys if they space without pressing them you may need a keyboard. If you find the offending key try popping off the key top this may get you by for a while.
DickyO
Aug 07, 2008 | IBM Wheelwriter 30 Typewriter
IBM Wheelwriter 5--Carriage advance problem
Try code (lang) key either the X or L depending on when it was made
DickyO
Dec 31, 2007 | Lexmark Wheelwriter 5 Series II Typewriter
IBM Wheelwriter 30 Typewriter Logo
78 people viewed this question
Top IBM Office Equipment & Supplies Experts
James Cagle
James Cagle
Don  Farrell
Don Farrell
jasbo
jasbo
Are you an IBM Office Equipment and Supply Expert? Answer questions, earn points and help others
