Question about Dryers
I have a WhiteKnight CL43 tumble dryer. The drum will not turn without first being turned by hand before quickly closing the door. It will then continue until its time for the drum to reverse and it stops again. The timer still ticks round but the dryer does not work. What do you think could be the problem?
  • 706 Answers
Not all that familiar with the Whiteknight dryer series but a dryer is a dryer and your problem sounds like it could be narrowed down to a few things. Based on your description of the problem and without knowing how much use that dryer has been subjected to, it sounds like you have a belt slipping ..or if it is configured like many other dryers..there may be a belt tensioner that came loose. In either case, the drive motor pulley spins andthe belt doesn't have enough tension or friction on the drum to rotate it. You might try cycling it without clothes to see if it spins up... if it does spin ( without assisting it) then once you add the weight of the clothes it doesn't have enough friction to spin the drum. Hope that helps !
Posted on Aug 07, 2008
My white knight tumble dryer wont start
Nothing works or drum fails to turn (tumble dryers)
Ensure that the power supply to the dryer is switched on, the timer is set to the desired drying time and the door is correctly closed. If you have a condenser model, also check that the bottle is empty and is fully pushed into the machine.
http://www.whiteknightrange.co.uk/whiteknight/faq.html
The first thing to establish when troubleshooting the clothes dryer is whether the dryer will start or not. If it won't, start by checking the outlet and the circuit breaker. Is the dryer plugged in or has it tripped the circuit breaker? If the breaker has been tripped, flip it back on and try the dryer again. The drum should turn without a problem.
If both plug and breaker are fine, you'll need to inspect the door switch as you continue to troubleshoot the tumble dryer. When you close the door on the dryer, a plastic peg should click and operate the switch which allows the dryer to work. The peg might be bent or broken, in which case it won't connect with the switch. You can try to straighten the peg, but if it's broken, you'll need to replace it. If the peg is fine, the switch has probably failed and will need to be replaced.
http://www.doityourself.com/stry/troubleshooting-a-clothes-dryer-drum-doesnt-tumble#b#ixzz3FOOQgtAT
Oct 06, 2014 | White Knight Press Genuine Tumble Dryer...
Tumble dryerdrum not turning when on but motor continues to run when door open
Does the drum turn by hand? I would check the motor belt first
Nov 26, 2011 | Hotpoint Dryers
My servis M2002 tumble dryer will only turn after being manually started off then shutting the door quickly. It will then stop and hum when it trys to go in reverse. Any ideas what it could be?
I would say motor but here is a website to help:
drum roller/glides, idler assembly:http://www.partselect.com/dryer+dryer-wont-tumble+repair.htm
Dec 11, 2010 | Dryers
My dryer-gas whirlpool the drum dors not tumble, the heat goes on
try and have the door open hold the door switch and have soem one push or turn the knob on at the same time spin the dryer drum clockwise by hand if it starts. you may need to clean the inside o fhte machine and the motor from any lint build up.or if the drum turns freely and easy you may have a broken belt or it might have slipt of the motor pulley.
Nov 03, 2010 | Dryers
Anyone know where I can obtain a copy of a service/troubleshooting manual for Sensordry WhiteKnight tumble dryer? Dryer will not tumble.
You can trace this out without any service manual , to only keep the logic of tracing the voltage to the circuits. Now if the tumble is not working it is the motor not working, so check if the door switch is working and then the program controller.
If there is power to motor is humming check if this has a capacitor. If so check if faulty as the motor will not start.
www.appliancerepair.net/dryer.htm
www.devicemanuals.com/guide/???dryer-manuals.html
Sep 30, 2010 | Dryers
Dryer doesnt turn on it just buzzes
try quickly rotating the drum by hand and closing the door while machine is turned on if this works it is the run capacitor which is cheap and easy to replace
Mar 15, 2010 | SNK Knight 43AW Electric Dryer
The dryer does not turn, but will turn by hand, how do you unlock heller cd55 dryer?
It won't tumble If your dryer doesn't tumble, check these: Belt Motor Door switch Belt Dryers have a drive belt that turns the clothes drum. If the belt breaks, the drum stops rotating. Then you need to replace the belt, and often the idler pulley, because the pulley tends to wear out at the same time. Click here for a belt installation diagram Motor If the dryer motor only hums when you press the Start button, the motor may be burned out. Here's how to test the dryer motor: Remove the belt. Check for obstructions in the blower fan housing. Manually rotate the shaft of the motor. If the motor is very stiff, or impossible to rotate manually, and the blower fan housing is clear, you need to replace the motor. If the motor rotates freely, run the motor momentarily with the belt removed and the blower in place. If the motor runs fine with the belt removed, there may be a problem with the idler pulley or the clothes drum. Try to rotate the drum by hand. If it is very difficult to move, correct any problem with the rollers or pulley, and then reassemble the dryer and try it again. If the motor hums but doesn't rotate on its own even with the belt removed--yet you can turn it freely by hand--you usually need to replace the motor or the motor start capacitor. Door switch Your dryer can't operate at all if the door switch is defective. It's inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch. If it's defective, you need to replace it.
Dec 31, 2009 | Dryers
The dryer makes a strange buzzing sound when u try to start it
1) First thing to check, can you move the drum by hand? if not the motor or drum bearings may have seized or collapsed.
2)Have you looked to see if te drive belts still on?
3) If you can turn the drum by hand- start the dryer, open the door then turn the drum as fast as you can by hand and quickly colse the door if it now tumbles you need a new motor start capacitor.
if you have no lucjk get back to me ASAP cheers
Mar 24, 2009 | Kenmore 64992 Electric Dryer
Motor is fine but drum won't turn. What could it be?
is there a belt to turn the drum - if so it may need to be changed.
Jan 04, 2009 | Kenmore 73952 Gas Dryer
Insalling a tumble dryer belt
The top of dryer hindged, snap clips in front, pop clips with scewdriver, front panel should slide up and out or tec scews along inside edge, motor should be on your right side facing drum, motor bolted to botom plate, need to check belt tennsoiner for any type of wear and damage,the rest should be simple,re-assemble dryer.
Jan 03, 2008 | Dryers
Dryers Logo
114 people viewed this question
Top Dryers Experts
