My JBL speakers ZYSPT-0104009 ZY7530 do not work. I've only had them a few weeks and were working fine. Now no sound or static comes through. Sound is playing fine through the internal speakers on my laptop. I haven't changed the settings for sound either. Please advise
SOURCE:
techman
  • 3130 Answers
SOURCE: static and crackling sounds
Sorry to burst your bubble my freind but things do wear out as you had plenty of life out of this unit.. Your problem is a transistor or a driver IC is breaking down under a load and heat and will get worse to where you wont be able to use the unit.. It will probable cost you in a range of 200 bucks or .more!as there is no quick fix for a solid state unit that has no user serviceable parts inside. Its just not replacing the bad part , its the hooking up to the load resistors then seeing that several other parts are not up par and having to start rebuilding the amp statges of your reciver.. If its more then 8 years old Time to landfill it and get a new one .. Put it to rest. It dosent owe you anything as its been loyal to you all these years!! Good Luck
Posted on Jul 27, 2006
SOURCE: Sound not coming from left side surround sound speaker or my right side front speaker
it is highly likely that you're TV is outputting mono sound, hence the left channel only. check your physical connections to the TV and the balance / channel volume on the television as well.
Posted on Aug 28, 2007
SOURCE: MacBook Sound Driver Issues
Omigod, that worked!!!!
Posted on Mar 22, 2008
  • 47 Answers
SOURCE: Nakamichi TA-4A receiver no sound
HAI,AMP WORKS FINE , CONNACT ANY OTHER TO AMP(CD,DVD,COMPUTER,MOBILE,TV) IN BACKSIDE INAUDIO OR PRE_AMP .THEN SELECT  PLAYER TO IN MODE YOU HAVE INSAERTED.THE SOUND IS OK
Posted on Jun 26, 2008
  • 726 Answers
SOURCE: Rotel Receiver RSX-1067
the rotal reciver is on the way out to the bin ,,,i chucked mine out and got a new one and was all good again i had same problems thats all i have to say and i dont think there is a fix to that
Posted on Jul 29, 2008
How do I get speaker to work with Samsung S5 with good sound quality
Be sure JBL is charged, press the power button on JBL, press the Bluetooth button on JBL. Turn on your phones bluetooth,make it visible to all devices, make it search for aplliances. When it finds JBL - pair it (you may have to make up a pairin number). The "sun" button controls different sound qualities. And turn the volume up! You should download the JBL MUSIC FLOW APP from the APP STORE to make the most of it.
Feb 19, 2015 | JBL Pulse Portable Bluetooth Speaker
Disturbance while increasing bass in JBL SPYRO
I have a similar problem. You need to open your subwoofer and check if the subwoofers cone cloth is torn. If it's torn you can recone the subwoofer and it will work fine. There are solutions online to fix the cloth using regular synthetic mix cloth but i don't know if it works. Try removing the cloth to see if it sounds better.
Jun 03, 2013 | JBL Spyro Computer Speakers
Muffled Sound From Speakers.
Please illuminate me explaining the word "Muffled" means and i will be glad to help you out...
Feb 10, 2013 | JBL *new* Jbl Jrx115 15" 2-way Speaker...
LEFT SPEAKER NOT WORKING. pLUGS IN GOOD, BUT NO SOUND OUT OF SPEAKER. cAN ADJUST VOLUME BUT NO SOUND COMING OUT OF THAT SPEAKER
try swapping the speakers around if the problem still persists either the speaker is faulty or
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
or you might have to clean the dust from your computer dust causes static which causes your computer to overheat and all sorts of problems
be sure to wear an anti static earth strap before touching anything inside your computer try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the CPU central processing unit and your SOUND CARD dust causes static to build up in a computer causing it to overheat any many other problems
hope this helps
Aug 06, 2011 | JBL Spyro Computer Speakers
I've had my my Logitech speakers for a few months now and they've worked fine up until a few weeks ago. Now if I turn the volume up more than a quarter of the way the sound goes scratchy and...
hope this helps
Jun 04, 2011 | Logitech X-540 Computer Speakers
Driver jbl pro speakers
I use these speakers since 2000. It will be 9 years this October!!! They work very good. I never used any drivers for them. I changed three computers with different mother boards / sound cards and they worked fine with any Sound Manager I tried.
Jun 27, 2009 | HP Compaq JBL Pro (401508-001) Computer...
No sound
It's because when you cleared your computer you deleted your sound drivers. You need to reinstall them in order to hear anything. I suggest you try searching for sound drivers on Google. They usually come with an 'installation wizard' so they're quick and easy to install. I'm not sure which ones are "the best" but I use Realtek and it gives me good quality sound.
I hope this helped,
Owen
Sep 22, 2008 | Audio Players & Recorders
No sound
What do you mean that you had the computer's memory cleared? Was it reformated?
Aug 04, 2008 | HP Compaq JBL Pro (401508-001) Computer...
Sound problem with JBL Creature II
I had a problem with the speakers not working properly. The green lights lit, but the amount of sound coming from the speakers compared to that of the sub was much lower.
I decided to take it the speakers apart.
I found that the magnets on the speakers had moved forward slightly in the plastic cage they sat in. I pushed them back as far as they would go, and Hey Presto! working again!
I hope this helps someone!
Feb 23, 2007 | JBL CREATURE II Computer Speakers
TV has a good picture but the sound coming out is nothing but static.
I have the same problem that just develop last week 0 ggod picture but audio is just static Did you find a solution yet?
Dec 26, 2006 | GE 46GW947 46" Rear Projection Television
238 people viewed this question
 Grubhead
Grubhead
Marvin
Marvin
