Question about Zenith IQB50M90W 50" Rear Projection Television
When I turn on the TV, the picture is fuzzy. After five minutes, the picture is clear but any words are out of focus even the menu for adjustments is out of focus. The convergence for red is clear but the convergence for blue is blurry. I have adjusted the sharpness and brightness and nothing happens.
  • Zenith Master
  • 6,993 Answers
Below are some troubleshooting tips for a TV that has a fuzzy or blurry picture;
If your Plasma or LCD TV picture is blurry or fuzzy there are several things that may be causing the problem. It's worth running through the following list before seeking service. You may find yourself saving the full cost of a TV repair.
Make sure you are using the appropriate cable box for your TV. If you have a high-definition TV you should also be using a high-def channel box from your cable provider. Watching standard definition channels on a high-def TV can make the picture look distorted and fuzzy.
Not all cable channels are broadcast in high-definition. When you stretch a standard definition picture to fill the full frame of your wide-screen TV it may look distorted. You can try changing your TV display settings to show standard-def channels at their native resolution. This will create black or gray bands on either side of your picture.
Ideally all of your video components will be connected to your TV with HDMI cables. Your next best option will be component video cables. If your cable box does not have HDMI capabilities, contact your cable company about upgrading your box to one that does include HDMI.
Make sure there is no glare on your TV from a window or other strong light source. This can significantly degrade the quality of the image you are watching.
If your TV has digital noise reduction, try turning that feature on.
You can adjust your TV's sharpness and picture modes to see if that improves picture quality.
Try plugging the power cord into a different electrical outlet and/or surge protector. You may be receiving electrical interference through your power cord.
Trying moving any nearby electrical devices away from the TV. They may be creating interference that can degrade the picture quality.
Let me know if the above helps or not, so that I can direct you further on what do next.....
Best regards.
Posted on Apr 14, 2011
SOURCE:
My tv overall is blurry, but when I click menu to mess with the settings, only the picture of what I'm watching, and the highlighted word is blurry, but everything else is clear, video games and movies n...
Some of your electronics parts were worn out. Like capacitors may have leaks that need to be replace
as use stated that the word focus were very clear it means that your tube is still okay. or you adjust the focus knob on the compartment. To tune in the 3 colors.
Jan 01, 2011 | Toshiba 57H82 57" Rear Projection...
When I take a picture, the camera focuses just fine. But when I'm looking in the viewfinder it looks fuzzy, even if it comes out clear. What's wrong and how do I fix it?
There's a diopter adjustment knob just above and right of the viewfinder. Turn it while looking through the viewfinder until it comes into focus.
Dec 06, 2010 | Canon EOS Digital Rebel XS / 1000D IS...
Picture out of focus. type or subtitles are fuzzy Have tried all picture adjustments in "menu"
As the CRT (picture tube) weakens the electron beam will loose some of its intensity. This will cause the beam to become a little wider, and thus the scanned picture will look softer or out of focus. Most of the time, the corners, top, and bottom tend to start getting worse than the center.
Sometimes the focus bias can be cheated a little. Some models of TV sets have a focus pot on the CRT circuit board, or on the high voltage multiplier. This control works in a high voltage area. I suggest you get experienced assistance for this. If you take the TV set over to a local TV shop or find an experienced tech, he could try to adjust the focus for you.
Considering the age and type of set you have, you would be better off getting a new up to date TV set.
Jerry G.
Sep 26, 2009 | Samsung TXJ2554 TV
My RCA TV guide words is blurred but the
There are 2 things you try. go into menu to picture setup scroll down to sharpness,back this setting all the off. If this doesn't do it, go to back of the set on right hand side, if you can see focus slot adjust it slightly.
Sep 06, 2009 | RCA F25654BC 25" TV
Fuzzy Webcam
the outer ring around the lens can be turned to adjust the focus
Mar 20, 2009 | Logitech QuickCam Messenger Web Camera
Fuzzy Picture
Fuzzy is a funny word. I never use it to describe a picture problem. That because fuzzy can go too many different ways. There is snowy fuzzy, blurry fuzzy, grainy fuzzy, and demodulated fuzzy. If the set goes out of focus intermittently that has something to do with the focus ciruitry. If it goes grainy that is a front end problem, usually tuner related. The other types of fuzzy are generally associated with problems in video processing some where. So, which is it?
Oh, and BTW that unit has three small picture tubes in it, one red, one blue, and one green. It doesn't have a 'bulb'.
Feb 24, 2009 | Mitsubishi WS-65869 65" Rear Projection...
Philips 34pw9818 fuzzy screen
Inside the set you should see a large part with a red wire coming out the top. That is the flyback transformer. There will be 1 or 2 controls on the back of it. One should be labeled screen and one focus. Carefully adjust the focus one until the picture is again in focus. Please note that in that area are high voltages (33,000V) that can be dangerous. Be careful where you touch. IT is best to have a mirror so you can see the picture while adjusting the focus control.
Dan
Feb 04, 2009 | Philips 34PW9818 34" TV
Fuzzy picture on my 42" akai lcd tv
Check the menu ,,it should have a option ,,called convergenge ,,that realigns the colors,, and some tvs have geomagnetic correction,, good luck
Oct 05, 2008 | Akai LCT3201AD 32 in. LCD Television
During dark images on my TV, several green lines are visible across the TV.
You may have an arc in the screen and focus circuits. Water may have gotten into these circuits causing a delayed reaction. (Circuits Corroded). These circuits at least part of them are a part of the high voltage transformer (flyback). Your picture tube socket has spark gaps inside of it too which may be arcing. You need to have it checked by a tech to find out just what is arcing. Stargazer
Mar 11, 2007 | Samsung TX-R2765 TV
Fuzzy or blurry picture
Ok with you I can skip the "do you have electronics experience?" questions. With 14 years under your belt you are a pro. So here we go. The problem you are experiencing is called blooming/loss of focus this occurs when there is an increase in CRT anode voltage and control of the electron guns (in the CRT) is lost. The result is the picture spreads and focus is affected. The problem can some times be taken care of by adjusting the focus control However if you have auto focus the auto focus circuitry might be the problem. The common parts (areas) to check are as follows: 1) Focus control (to see if the problem can be soled by adjustment) 2) IHVT anode (test to see if voltage is correct you will need a schematic and a high voltage probe) 3) CRT Socket board ( Check to see if the bias voltages and input signals are correct you will need a schematic, multimeter and oscilloscope) These would be the areas to check, I hope that you are seeing my point here. My next bit advise if not one of your experience, you have that, 14 years of it. However, you have little ones and they are your NUMBER ONE concern, So my advice would be to get the set repaired at a TV repair shop. The reason being is because even though I have named some places to start your troubleshooting, TV repair is not an easy thing and there may be other components that could have gone bad and you don't have the time to do investigative troubleshooting. I wish you well on this issue and take care of those little ones. Respectfully Submitted, Shuttle83
Dec 13, 2006 | Sharp 32C241 TV
Zenith IQB50M90W 50" Rear Projection Television Logo
389 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
