Question about Nikon Cameras
I have a nikon FG, the old fashion kind not a digital, that has a frozen shutter. It clicked once and went to black and now won't release. I'd love to take this camera out of town wiht me....HELP!!!!
  • 667 Answers
Turn the speed dial to the M90 or B setting. That will complete the release cycle for the camera. Neither of those settings require battery power. You probably need new ones. Clean the cap surface and the contact in the camera with a pencil eraser to make sure you get good contact. Install the batteries so the positive side faces up in the cap. Use two 1.5 volt S76 or A76 cells. The single cell 3 volt lithium is not recommended.
Posted on Aug 08, 2008
SOURCE:
Camera won't take pictures
On page 256 of the D-90 users manual it says that ERR indicates a camera malfunction that can be cleared by releasing the shutter. On my D-90 when this occurs, I have to turn the camera off to make the shutter release. Sometimes, but rarely, I have to remove and reinstall the battery to get the shutter to release.
The manual also says that if this error occurs frequently or persists to contact n authorized Nikon service center. I suggest that you contact Nikon tech support at www.nikon,com before you contact a service center to see what tech support advises. I have heard of people resolving this problem by upgrading the firmware (camera software). Nikon tech support can tell you if this will help.
This information works for my D-90 and could work for your D-40
Jan 30, 2013 | Nikon D40X Digital SLR Camera Digital...
Nikon FG. Replaced 3V battery. On the M90 setting the film advances OK. On 'program' or other settings it will only advance once and after shutter fires it will not advance until put on...
M90 is a battery independent setting - it requires no battery power to function. If it won't advance until put on M90 from other settings, then either you're not allowing for proper exposure, have the settings incorrectly set (film speed, etc), or you have shutter issues. The shutter is electronically controlled on all settings except M90. In the auto setting, your lense MUST be set to the smallest aperture (biggest number). On any other setting, you can use it however you'd like. I'd suggest unloading any film, setting the shutter speed dial to 1/125 or so, opening the back and looking thru and firing the shutter. If it's not snapping open and immediately closed, theres an issue and you need to consult a repair technician either locally, through Nikon, or through KEH Camera online.
Jun 29, 2011 | Nikon FG 35mm SLR Camera
This is an old nikon camera FG. I have put a new battery into the camera and set to what the manual tells me to do. But looking through the viewfinder when I depress the shutter release button non of the...
Hi, see if the batteries or the battery are installed correctly (positive side as the bat. cover shows + sign).
Mesure the voltage = 3 volts.
Look at the battery cover and body contact, and see if there is contact battery leakage;clean if necessary.
Also the counter should be in 1, nothing happens, the counter SW dirty or defective contact.
Other Main PCB bad.
Best reggards
Feb 23, 2011 | Nikon Cameras
Is ther a remote for the nikon s3000
No. Nikon does not make a remote for the S3000. Its shutter release button is not threaded for an old-fashioned cable release, and there is no provision for remote operation via the USB connection.
Sorry if that wasn't the answer you wanted to see, but there it is.
Jan 30, 2011 | Nikon S3000 Digital Camera
Nikon D70 (new 2004) Shutter release will not take picture
I've got a D70 and never had this issue. I bought mine around the same time frame. Thanks for the info!
Aug 16, 2009 | Nikon D70s Digital Camera
Nikon FG 35mm
If its black when you look thru the viewfinder its likely because the mirror is stuck in the up position. It will often do that if the batteries are exhausted. Try replacing the batteries.
The mirror might release back down if you turn the shutter speed dial to M90. This is a manual release of 1/90 second for when you need the shot but don't have any power.
When you look in the lens opening and adjust the aperture dial, you are seeing the aperture open and close. Not the shutter. You need to open the back of the camera (without film) and take a photo to see the shutter curtains open and close.
You should have a read thru the manual to become familiar with the camera and its operation:
http://www.cameramanuals.org/nikon_pdf/nikon_fg.pdf
Jan 03, 2009 | Nikon FG 35mm SLR Camera
Nikon FG shutter
By "stayed up", do you mean that the mirror remained in the up position so that you could not see anything in the viewfinder or do you mean that the shutter actually remained open? I do not remember the exact features on your camera, but in general, this is what I would do.
1) Remove the film from the camera and take a picture. Note if you see anything in the viewfinder. If you see nothing, the mirror is in the up position. Verify this by removing the lens and opening the door on the camera back. Look through the lens hole. If you can see through the rectangular hole at the film plane, the shutter is open. If instead you something is obstructing the hole, the shutter is closed. In any case DO NOT TOUCH THE SHUTTER! The shutter is what is covering the hole.
2) If the mirror is in the up position, check to see if your camera has a feature that allows locking the mirror in the up position. Some cameras have this feature to allow use of lenses with very short focal lengths. If this is the case, simply unlock the mirror.
3) If the shutter is the problem, your shutter speed may be set to "T", which stands for time. In the time exposure mode, you press the shutter release once to open the shutter and a second time to close the shutter. Cameras with a "T" setting also have a "B" setting, which stands for bulb. This is a throwback to the old days when it was common to use air-powered shutter releases rather then cable releases. The bulb was a rubber bulb that you squeezed to force air through a tube and push a pin to activate the shutter. The "B" setting keeps the shutter open as long as you hold the shutter release in, but as soon as you take your finger off the shutter release, the shutter closes. Both of these settings are used to make timed exposures. If you find that the problem was that the shutter was set to "T", set the shutter speed to 1/25th second or so and try again. The following sequence should occur; the mirror will flip up and the viewfinder image will disappear, the shutter will open for the prescribed time and close, the mirror will return to the down position and you will again see through the viewfinder.
If this does not work, you may need to take it in for repair.
Nov 18, 2008 | Nikon FG 35mm SLR Camera
Nikon FG suddenly stopped working--not battery problem--help!
you should invest in a digital camera they have nice cameras for like 40 dollars on overstock.com
Mar 18, 2008 | Cameras
Cleaning out dirt and dust inside nikon fg camera
FG's are pretty tough old cameras. You can use a cloth and a lenspen brush, but be very careful of the shutter curtain...its delicate and if you damage it you might as well get another FG ($30 or so on Ebay). My first Nikon was an FG-20...still works like new.
Oct 25, 2007 | Cameras
Cameras Logo
Top Nikon Cameras Experts
Ric Donato
Ekse
pictureman4u
Are you a Nikon Camera Expert? Answer questions, earn points and help others
