FixYa.com
Tags:
Mag Innovision InnoVision LT765 17 in. Flat Panel LCD Monitor
Help needed configuring monitor
By Peter1 - usenet poster
Just installed Fedora Core 3. My monitor was not listed, though several
similar monitors were. Which monitor should I choose? I have a 17# LCD
monitor: MAG Innovision Product# LT765 Model# 785  I choose generic LCD,
but the problem is the display is shifted to the right about 1/4inch, which
of course I can fix with the monitor's built in controls, but then if I
boot into that other OS run by the Borg it would be out of whack. Would
like to get the correct driver through Fedora if possible. Any help
appreciated! Graphics card was recognized which is great since it is an
nvidia GeForce (yeah, I can play Unreal Tournament!)
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Aug 11, 2005
Not Rated (0)
Putty
Putty - usenet poster
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
Research the specs (horiz and vert frequencies) of that monitor model, and
then set the frequencies manually in your xorg.conf file.
If you're not on the edge, you're taking up too much space.
Linux Registered User #327951
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
Not Rated (0)
Putty
Rating: 0%, 0 votes
man xvidtune
"They that can give up essential liberty to obtain a little temporary
 safety deserve neither liberty nor safety."     -- B. Franklin, 1759
Can you Help with these Monitors problems?
Monitors
Faulty backlights
What can I do to repair my... Answer This...
Mag Innovision InnoVision LT765 17 in. Flat...
bhg
Mag Innovision LT773s turns on...
I've had this monitor about 3... Answer This...
speakers on monitor does not...
Hi I need help trying to get my... Answer This...
Monitor keeps flickering
My monitor keeps... Answer This...
Repair Service
Find Monitor Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
