Question about Bosch Dryers
Bosch exxcel tumble dryer WTE84307. Terrible smell coming from dryer like a fishy smell. Please help
4 Suggested Answers
  • 67 Answers
SOURCE: dryer does not tumble, but heats up
Dryers have a drive belt that turns the clothes drum. If the belt breaks, the drum stops rotating. Then you need to replace the belt, and often the idler pulley, because the pulley tends to wear out at the same time.
Click here for a belt installation diagram.
Motor If the dryer motor only hums when you press the Start button, the motor may be burned out. Here's how to test the dryer motor:
  • Remove the belt.
  • Check for obstructions in the blower fan housing.
  • Manually rotate the shaft of the motor.
If the motor is very stiff, or impossible to rotate manually, and the blower fan housing is clear, you need to replace the motor.
If the motor rotates freely, run the motor momentarily with the belt removed and the blower in place. If the motor runs fine with the belt removed, there may be a problem with the idler pulley or the clothes drum. Try to rotate the drum by hand. If it is very difficult to move, correct any problem with the rollers or pulley, and then reassemble the dryer and try it again.
If the motor hums but doesn't rotate on its own even with the belt removed--yet you can turn it freely by hand--you usually need to replace the motor or the motor start capacitor.
Door switch Your dryer can't operate at all if the door switch is defective. It's inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch. If it's defective, you need to replace it.
if this helps please vote me a fix ya
Posted on Jul 15, 2008
  • 7482 Answers
SOURCE: My tumble dryer (Bosch Exxcel) is showing an error
F09 error is no heating.
You can fix that by opening up the back and pressing the red cutout button which will restored hot air.
Good Luck,
I hope this helps
Posted on Nov 12, 2009
SOURCE: Bosch classixx tumble dryer container full light
This is happening me too. Have you had any suggestions how to solve this problem???
Posted on Oct 11, 2010
Communications error.
  • Troubleshooting and Repairing the F11 Error Code in a ...
    • 6 MIN
    • ADDED 2013-10-22
    Video embedded · Troubleshooting and Repairing the F11 Error Code in a ... Troubleshooting the F35 Sud Error Code in the Whirlpool Duet Steam ... Washer Dryer ...
  • Kenmore Elite He3 F11 Error Code - · PDF file Kenmore Elite He3 F11 Error Code How to troubleshoot the ... Kenmore F1 Error Code He2 Dryer Problems Amp Solutions
  • Kenmore Washing Machine Error Code F11 - · PDF file Kenmore Washing Machine Error Code F11 what does f11 mean - Kenmore Elite HE3 Washing Machine. The F11 code is from a communication break in the serial link from ...
  • Related searches for ERROR CODE DRYER F11
  • Whirlpool Duet F11 Error Repair ' Circuit Board Medics Whirlpool F11 Error. This is a repair service for the Whirlpool Duet F11 error code on a Whirlpool Duet washer.
  • Bosch Tumble Dryer Fault Code F11 - prapmumbmihe · PDF file Bosch Tumble Dryer Fault Code F11 Bosch Exxcel tumble dryer error code F:09 · Bosch Exxcel WVT. Asciugatrice Bosch Wts86511It: Errore F11 Hello, My dryer ...
  • Whirlpool F11 error code - Appliance Repair Forum > ... > Washer Repair
    • LAST UPDATED: 2014-02-18
    • 6 POSTS
    • FIRST POST: 2012-02-18
    I got an F11 error code on the washer and tried some of the things discussed on the site for simiilar duet washers and found a link to this site ...
  • Jan 30, 2016 | Dryers
    Bosch Exxcel Condenser
    replace the broken drive belt
    May 13, 2013 | Dryers
    Fishy smell coming from breaker box and dryer tripping breaker
    The problem is probably the breaker box. The fishy smell can be caused by the plastic housing melting so this needs looking at.
    Dec 21, 2012 | Frigidaire Electric Dryer
    Bosch Exxcel Drier WTA4107GB/01 not heating up. Is there a reset button
    yes and here is the thread on it:
    Jan 11, 2011 | Bosch Dryers
    My Bosch Exxcel tumble dryer will only blow cold air
    the heater element is toasted,but it's not hard to change and not $$$
    Mar 28, 2010 | Dryers
    My tumble dryer (Bosch Exxcel) is showing an error message F09?
    Good Luck,
    I hope this helps
    Nov 12, 2009 | Bosch Dryers
    Hi,there is no heat coming from my Bosch Tumble Dryer
    Apr 09, 2009 | Bosch Dryers
    Bosch exxcel tumble dryer blowing cold air only
    Remove smallish cover in center of back, 2 self tappers. Press RED reset button till it clicks, located just left of center at the back.
    Oct 05, 2008 | Bosch Dryers
    Dryers Logo
    133 people viewed this question
    Top Bosch Dryers Experts
    Lawrence Oravetz
    Are you a Bosch Dryer Expert? Answer questions, earn points and help others
