Question about Brother IntelliFAX 1270E Plain Paper Fax
Poor Line Condition
Dr Nick,
I was wonder if you could elaborate on you last sentence? (2 line satin is required for most fax mach's when connecting on a digital sys) Presently have problems with some faxes on cable system phone product.
Thanks.
T
    Genius:
  • 2,120 Answers
All fax machines are ANALOG.
Posted on Aug 31, 2008
6ya staff
SOURCE:
Tried to fax a 2 page letter getting on the mach did it in blk /colorand still disconnect get a print out report NG: POOR LINE CONDITION/OUT OF MEMORY how do i fix this
Have a look at these solutions maybe 1 of em will help
This problem could be Phone line problem, or hardware failure or receiver's (the machine of the person whom you are sending the fax) machine problem and so on. First, let's check the line, if you have another Phone line, please dial from the number to your number, also, connect the currently connected line to a receiver and call a Land-line number, if the outgoing or incoming is ok, the proceed forward, otherwise, you telephone operator should check the line.
Sometimes, sending fax to a particular number doesn't work, to make sure, try sending a fax to another number.
If the line which is connected to the machine is extended from another machine such as Receiver, Switch, etc... unplug them and connect the fax machine directly to the Line.
It's also important to adjust the compatibility mode, to do this, follow the steps below:
Press Menu. Press the up or down arrow key to select Fax. Press OK. Press the up or down arrow key to select Miscellaneous. Press OK. Press the up or down arrow key to select Compatibility. Press the left or right arrow key to select Basic (for VoIP). Press OK. Press Stop/Exit.
Or here http://www.fixya.com/support/t413839-ng_poor_line_condition_out_memory
hope one of em helps,
Regards,
Jul 28, 2011 | Brother MFC-5840CN All-In-One InkJet...
Can't send fax. Getting transmission verification report stating NG: poor line condition/ out of memory. HELP!!
There are two possible reasons why your printer display the error message.
1. Poor Line Condition
- electrical interference on the line -Make sure electrical or electronic appliances do not interfere with the printer's phone line
- poor line connection - If you have a phone try connecting it directly to line outlet. Listen to the dial tone, if you hear noisy and static, then you will need to call your local telephone company cause there is a problem in your phone line. If dial tone is clear and stable then try checking the telephone line cord that you use to connect your printer from the line outlet, replace if broken.
- alarm system or another device on same line, these interferes with transmission / reception of the fax machine. Try connecting the printer all alone and then try sending a fax.
2. Memory Full
- There is no space to store incoming fax messages. Delete all stored fax messages.
Apr 09, 2011 | Brother MFC 6490CW InkJet Printer
Our MFC 7840 printer when faxing keeps saying
Depending on your location the line coulod well be poor quality for a sensitive fax. Any spurious sounds on a fax line will cause it to fault.
May I suggest you try the fax on the mainline first before assuming the unit is at fault.
Length of line from point a to b can also reduce the efficiency of signal. It may sound ok to the ear, but resistance may be the factor in reducing the level of the tone that the fax requires to hear and then activate send or receive.It reports poor line condition and even poor memory because it keeps loading to send.
If it does it on the mainline as well then I would be considering a technical call for help. There may be a fault in the unit.
please rwte my help++++Thanks for using FIXYA
Nov 24, 2009 | Brother MFC 7840W Printer
Poor Line Condition message
If your fax has a handset listen to the dial tone and make a call if the connection is poor call the phone Co.
DickyO
Nov 09, 2009 | Brother IntelliFAX 1170 Plain Paper...
Why do we sometimes get a message from our fax maching that reads "Poor line Conditions".
You may have a loose connection in the phone cord or wall jack, or possibly you are trying to fax on a DIGITAL phone line.
Oct 12, 2009 | Brother IntelliFAX 1270E Plain Paper Fax
NG Poor line condition whenfaxing
If this is truely an issue involving poor line conditions you can try using a Line Noise Filter which you can get at most Radio Shack locations. Should cost about 14.99 or so. This could be caused by a loose connection in your home/office wiring or a loose connection at the switch box or anywhere along your line all the way to the tandum. If you actually hear static on the line have the telephone company do the work. Call in a bad connection issue and ask for a line test. If there is a grounded line somewhere that will detect the fault and they can better isolate where the problem actually is located.
Sep 08, 2009 | Brother IntelliFAX 1270E Plain Paper Fax
Error 20 01 NG: poor line condition on outgoing fax's
My fax shows poor line condition. I have checked all of the connections and everything is ok. Perhaps my settings are wrong
Jan 23, 2009 | Brother IntelliFAX 4100 Laser Fax
"poor line condition'
Very often this is caused by either the sender or receiver having VOIP phone service. Check this and if this is the case you need to set the baud rate to 9600.
Hope this helps!
Jun 09, 2008 | Brother MFC-8840D All-In-One Laser Printer
Compatability with efax
Try Brother customer service 1-800-284-4329 (usa voice #), but be prepared to answer a few questions 1st. The manual mentions nothing about eFax.
Jan 28, 2008 | Brother IntelliFAX 4100 Laser Fax
This is a problem with your voice over ip service. You have to change the setting on your fax machine for example the Baud speed down to 9600, the ECM= off, and the Oversea settings on. Make sure your VoiP ATA is the first thing after your modem or whatever connection you are using for the internet. If you using and old model fax 95% of the time it will not work with VoIP service.
Jun 12, 2007 | Brother IntelliFAX 1270E Plain Paper Fax
Brother IntelliFAX 1270E Plain Paper Fax Logo
115 people viewed this question
James Cagle
James Cagle
Jim Keysor
ctnozil
