Question about Acer AL1715 17" LCD Monitor
Dismantaling the monitor base
I want to dismantle the acer monoitor Al1715 from its base but I forget how I assemble it.
  • nemer95 Aug 09, 2008
    It is solved.
Is it possible to rotate the screen (acer al1715sm) from its base? (to srew on the wall) cause mine moves up and done, but gets stuck after a small bit..
find audio multimedia base like VG3P31 (Philips) std. 4 screw mount pedestal like photo below..move up/down, CW, right/left.659ae0f8-3ebc-40d3-ad3a-1dd9b380bafc.jpg
Oct 17, 2013 | Acer AL1715 Monitor
Where can I obtain a power cable for an Acer AL 1722 flat monitor?
just try it out in Ebay or Amazon online shopping surly you will able to find your cable.
Good luck ! if you think your problem solved don't forget to rate
Jan 03, 2011 | Acer AL1715 17" LCD Monitor
Where can I buy an Acer AL1715 monitor from, I have checked ebay and many price comparison sites but no luck =(
Hello frebib, I found one on on EBay from a top rated seller. Here is the link: Hope this helps! Edward
Aug 24, 2010 | Acer AL1715 (Black, Silver) 17" LCD...
Hello i have a acer lcd model AL 1715 SM it doesn t have a vga input and cable is damaged how do i chenge it
Apr 07, 2010 | Acer AL1715 17" LCD Monitor
My acer al1715 has a pink tint. It started
This is a low-end monitor and the image processor is failing. You will require a replacement but since the monitor is low-cost, it is cheaper to simply by a new one.
Jan 20, 2010 | Acer AL1715 (Black, Silver) 17" LCD...
How do I dismantle the monitor from the keyboard
The monitor does not hook up to keyboard most of the time, it is plug into the cpu you can follow the cord that connects to the monitor and follow it to where it hooks up and there will be 2 round pins that turn with your fingers and then you can disconnect.
Nov 28, 2009 | Acer AL1715 17" LCD Monitor
Monitor resolution problem
set your dispaly resoluiton to 1024*768
Mar 24, 2009 | Acer AL1715 17" LCD Monitor
Acer AL1715 Monitor - screen distortion, discoloration, several times each day
Certain versions of the Acer AL1715 monitor had a problem with the VGA socket. Specifically, the plastic case around the socket was not wide enough. The plastic lip interfered with the plug and so the plug does not seat properly. This causes all sorts of intermittent problems. The version of the AL1715 with the problem with had the UPC code of 0 99802 19889 3. I fixed several of these monitors by shaving off the excess plastic with a Dremel Mototool. A hand file would probably work as well. You have to remove the plastic back to get the clearance to do the job.
e82875f5-b8a2-4548-9fdb-e60e2a37e9f1.jpg 14e1c79c-dd10-4643-b23c-053cfb0678e4.jpg fcd3ba29-2571-453c-838f-32c7fa61078d.jpg 038eb9e5-53a2-4fa0-88b9-56eb63be9378.jpg 19ef87e5-fc9a-423a-af2e-b0d949b0e884.jpg 092e022f-c3ac-4aa4-86ff-99eaa0075f07.jpg fe6adb60-288d-425f-9d35-156c724a2285.jpg
Oct 30, 2008 | Acer AL1715 17" LCD Monitor
Dismantaling monitor from base
acer monitors are usually put together with 5 screws on the back of the monitor, 4 where you can see them and 1 under the pivot mount, this can be accessed by removing the pivot cover and then unscrewing the pedestal then you can get the last screw, after that you need to pry the half shells apart and then you can get at the cover for the power board the VGA screws and the power socket screws must also be removed.
Oct 25, 2008 | Acer AL1715 17" LCD Monitor
Acer AL1715 17" LCD Monitor Logo
174 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
