Question about Dell A940 All-In-One InkJet Printer
Dell A940 Leaving smudges on edge of paper and also on end of envelopes.
  • Anonymous Mar 23, 2014
    smudges on edges of paper after printed
Thanks for all the follow-up. I saved the suggestion from Kayumangi Beloria; but am going to try Cleaning Sheets first. I did not know these were available. Thanks again,
Posted on Jan 18, 2013
  • 3 Answers
Go to www.support.dell.com
Posted on Aug 08, 2008
  • Kayumangi Beloria Aug 08, 2008
    1. Remove ink cartridges.
    2. Clean ink cartridge contacts with a clean, dry cloth.
    3. With a damp cloth clean the nozzles.
    4. Pull cartridge carrier to one side of printer while printer is off. Clean the encoder strip, careful very sensitive. Pinch with a clean damp cloth and wipe from the carrier to the side of the printer. Do both sides.
    5. Do a nozzle clean page. Go to >start>programs>dell printers>dell aio a940>dell printer solution center>maintenance>clean to fix horizontal streaks>print: If prints a blank page, and testing with another cartridge or a good cartridge have the same issue, your print head may already be damaged.
    ***damage may be due to refilling ink cartridges, some ink solutions may have damaged the printer head.***
Where do i put envelopes in a lexmark X6570
Loading envelopesYou can load up to 10 envelopes at a time.
Warning: Do not use envelopes that have metal clasps, string ties, or metal folding bars.
1 Load envelopes in the center of the paper support with the stamp location in the upper left corner.
2 Make sure:
• The print side of the envelopes faces you.
• The envelopes are designed for use with inkjet printers.
• The paper guides rest against the edges of the envelopes.
Notes:
• Do not load envelopes with holes, perforations, cutouts, or deep embossing.
• Do not use envelopes that have exposed flap adhesive.
• Envelopes require more drying time. Remove each envelope as it exits, and allow it to dry to avoid ink smudging.
Apr 11, 2012 | Lexmark X6570 InkJet Printer
When I send envelopes to the printer, the printer is leaving ink marks on the edges of the envelopes
There is a possibllity that your ink cartridge at the printing nozzle has excessive ink.
Remove the ink cartridge and clean the face and edges around the ink nozzle
with a swab or paper towel.
Mar 10, 2011 | Office Equipment & Supplies
I'm trying to print wedding invitations on my Canon MP460. I'm using a cardstock thickness of paper and have set the ink levels for "Other Photo Paper" on my Mac. The paper has been going through...
Sounds like the ink isn't having time to dry and is rubbing along paper.
Paper may be too thick. If it prints OK on normal paper (test first) but not on thick card, then it doesn't support thick paper settings.
Jan 31, 2011 | Canon PIXMA MP460 All-In-One InkJet...
Whenever I print in envelope size there is always smudges. But when on plain letter size there are'nt any smudges. Pls. help me.
Check and change the paper type .May be the envelope you are using has different kind of paper so you need to select the particular paper type to fix this problem
Jan 10, 2011 | Office Equipment & Supplies
We have a Dell A940 Printer. When printing a
check!, what colour is the xter you were hoping to print on the envelope, that you need to confirm from the printer settings, also on the envelope setting
Mar 16, 2010 | Dell A940 All-In-One InkJet Printer
Dell A940 smeared printing
Our Dell AIO A940 stopped printing black ink (it went throught the motions but he paper came out blank). Finally got it to print by selecting:
PRINT, PROPERTIES, PAPER SETUP, SPECIALTY PAPER, PHOTO/GLOSSY
Maybe it will work for you! Good luck!
Dec 11, 2007 | Dell A940 All-In-One InkJet Printer
PIXMA 830 Smudges when printing envelopes
On my MP780, be careful to select the appropriate paper type; I was getting black smudges on the left side of my envelopes until I explicitly set that my paper type was "envelope" from "plain paper".
Another idea is to adjust the "ink drying wait time" to a higher level.
Dec 09, 2007 | Canon PIXMA MP830 All-In-One InkJet...
Ink smudging
Run a cleaning sheet through the printer- absorbant papaer- blotting paper. If this machine has had a lot of service it may be your waste tank is filling up and leaking out - have you had a service warning yet?
Sep 16, 2007 | Epson Stylus RX500 All-In-One InkJet...
Dell A940 All-In-One InkJet Printer Logo
140 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
