Question about Karcher 2500 PSI Pressure Washer
No pressure MyHonda pressure washer statrs fine but does not develop pressure. I have changed the spray rod with a new rod but still does not solve the problem Any thoughts!!
  • cphantom Aug 08, 2008
    honda motor, 24 psi, bought at costco. If I take spray tip off and put it back on and fool with trigger some it works. If I stop I need to take spray tip off again to get pressure. 3 years old but only has 30 minutes on it at the most. Karcher repair service long way away,
  • 14 Answers
The machine has a worn bypass valve. Replace the valve assembly.
Posted on Mar 06, 2009
    New Friend:
  • 161 Answers
Sounds like either the pump or the valve that releases the water outta the rod.
Posted on Feb 27, 2009
I bought a new 2600 psi pressure washer. It starts great. The pressure starts out fine. However, when I disengage the spray nozzle lever and then push it again there is along delay before I get any...
Hi. I think the problem may be called either vapor lock or cavitation, or it could be called something else, but the solution is to take the wand apart in the center and let the trapped water escape, then putting it back together before re-engaging the lever.
Sep 14, 2011 | Craftsman 2600 PSI Honda Powered Pressure...
Dewalt Pressure washer keeps shutting off for no reason. plenty of gas and oil, water running to it. starts fine and as soon as I start spraying it shuts down.
Had a similar issue with my dewalt 4200 pw. Unit starting shutting off after spraying for about 5 min. Then difficult to restart, but would start again eventually only to shut down a few min later. Had new engine oil, new pump oil, good gas. I changed the spark plug and unit runs great again!
Aug 08, 2010 | Dewalt 3800 PSI Pressure Washer
I my pressure is cranking fine but there no pressure in the spray gun i have tried everthing plse help
the excess pressure release valve might be leaking so no pressure can develope
Jul 05, 2010 | Honda 8 HP Engine
Hausfield Campbell pressure washer 2300 psi .Water not flowing through hose to gun
hi try statring the machine with no hose on, if ok add the hose to the machine without the gun and lance. then try the gun on its own WITHOUT THE NOZZEL in the lance. just elimate things regards
Jan 23, 2010 | Campbell Hausfeld PW2575 Pressure Washer
1800 power washer will not run - power is getting to on/off switch
Maybe just the pressure switch is stuck or you have trapped pressure in the lance. Try without the high pressure hose and then activate the pressure switch on the side of the pump as this may not be letting the machine to statr if its stuck.
Nov 12, 2009 | Campbell Hausfeld 1800 PSI Electric...
Kracher pressure washer with Honda engine 2500
Take the spark plug out and then try to turn it over. If it still won't pull, it's probably locked up. If it got tipped forward or towards the spark plug oil may have went into the valves. If it pulls you may see some oil spray out. Clean off plug and try to wait for the smoke to clear. Hope this helps. Please rate me
Jun 18, 2009 | Karcher 2500 PSI Pressure Washer
No pressure on certain settings
Dear Osville,
It is not clear what type of lance or nozzel you have. You said that the machine works fine with the circulating water jet(the turbo). So it seems the machine is fine. I do sometimes service variable nozzels and variable lances. But the best solution is to replace nozzels and variable nozzles and lances with new ones. Regarding the fan spray setting it could have no pressure because it might be in the chemical setting. The chemical setting lets out a fan shape flow of water, but with less pressure. The chemical system only works on low pressure in domestic washers, that is why it needs a low pressure flat spray. The pencil jet has 2 jets comming out because if it is a lance or nozzel with ball bearings, these ball bearings must have stuck in a wrong position. Also 2 jets can come out, due to a damaged nozzel hole.
Altogether, the best advice is to buy a new nozzel or lance...which ever your machine uses. All Karcher machines have their own specific nozzels, lances and high pressure hoses. You cannot change these from one model to another.
Apr 29, 2009 | Alfred Karcher K 5.93 M Electric Pressure...
Karcher 2500 PSI Pressure Washer Logo
137 people viewed this question
Top Karcher Garden Experts
John Trevino
Harold Baxter
Level 1 Expert
Are you a Karcher Garden Expert? Answer questions, earn points and help others
