Question about Gateway Pentium III , 933 MHz Processor Upgrade
No power. After being in storage for 2 months it is not coming on at all. Is there a reset button or something else i can check before calling for repair. The power cord is good as well as the power strip. Thanks!
  • 31 Answers
Hello
some times when pc is sremain off for long time then it does not display anything and also not started
try again and again
sometimes this technique works
when you on the pc wait for some time then again repeat
Posted on Nov 28, 2008
I recently ask a question how how to do a reset as i am stuck with android on the screen, i tried ur suggestion on power button and sound down button, nothing changed , do u have another suggestion to get...
I had this similar tablet...it quit on me after 2 months. I called the company and they replaced it with a M9200 which would not turn on after 1 month. I found the factory reset button on the back under a small sticker. Plug it into the charger and gently push a sharp toothpick or other sharp non metallic object inthe the small hole until you get resistance. Then gently push 'till you feel a tiny click...this should reset the tablet. Mine crapped out because it is a junk company. There are more complaints on this company than any other I have ever seen. I wised up and bought Google Nexus 7...best 7" tablet made.
Nov 09, 2014 | Kocaso M752 Black WiFi 7" Android Tablet...
No Power.
Yes, It is highly possible that the unit had a leak and did loose it';s charge while in storage.
Jun 30, 2014 | Amcor ALD12000E Portable Air Conditioner
How do i reset my samsung galaxy 3 if it wont come on?
1. If your Samsung Galaxy S II is frozen, Shut the POWER OFF, take the battery out and put it back again.
2. Hold the Volume Down button
3. Briefly Press and release the Power button
4. A menu will then appears that let you allows for Fastbook, Recovery, Clear Storage, and Simlock
5. Select Clear Storage by pressing the Volume Down button
6. Quickly Press and release the Power button
7. Select Volume Up for YES and Volume Down for NO
If the above procedures doesn't work. try this another method:
1. Turn the POWER OFF, pull the battery out and put it back again.
2. Simultaneously press the Volume Up, Home and Power button
3. If the Samsung Symbol appears, release the Power button
4. A Boot Menu will then show, Use the volume up/down to choose and home to select.
May 30, 2014 | Samsung Galaxy S GTI9000 Smartphone
Samsung galaxy ace duos S6802 incoming call always busy. I try to hard reset nothing happens. Call forwarding are disabled. Please help me to fix.it
When a Samsung cell phone becomes unresponsive or when the device slows to a crawl, a reset may be in order. There are two primary methods used to reset the phone. Users should always start with the soft reset when the phone locks up or programs slow down due to memory or software response issues. A soft reset is akin to a reboot of the machine and usually solves most problems without any loss of user data. A hard, or master, reset is required when the phone completely locks up and becomes unresponsive to any cellular signals. This second and more drastic reset deletes all personal data, preferences and settings so that the device is restored to the original factory configuration.
Perform a Soft Reset
Step 1 Press and hold the power button for 10 to 20 seconds.
Step 2 Release the power button and tap the "Power Off" option under the "Device Options" menu that appears. Tap "OK" to initiate the shutdown.
Step 3 Press the power button again to restart the device.
Perform a Hard (Master) Reset
Step 1 Tap the "Menu" key from the home screen and then tap "Settings."
Step 2 Go to "Privacy" and tap "Factory Data Reset" to review the Factory Data Reset information.
Step 3 Review the Factory Reset options. Place a check next to "Format USB Storage" to clear your device of user data, such as music, pictures and other account settings.
Step 4 Review the disclaimer and verify your changes before tapping "Reset phone."
Step 5 Tap the "Erase Everything" or "Yes" buttons to confirm the reset the phone to factory settings. The device initiates the restoration process to the original factory configuration.
Perform an Alternative Soft Reset
Step 1 Power off the phone. If the phone does not turn off, remove the back cover of the phone and take out the battery. Wait between 10 and 30 seconds and then replace both the battery and the cover to restart the device.
Step 2 Simultaneously hold down the power/lock keys.
Step 3 Release the keys when the Android screen appears.
Tips
  • The ATT Samsung SII models have an alternative hard reset that requires you to simultaneously hold down the "Volume Down" and power keys after an alternative soft reset, and then release the power button, bringing up the menu titled "Fastbook, Recovery, Clear Storage, and Simlock." Use the "Volume Down" key to navigate to "Clear Storage" and then press the power button. Press" Volume Up" for "Yes" and "Volume Down" for "No." This will reset your device to its original factory setting.
  • A soft reset on a Galaxy S phone involves pressing the "Volume Up" key simultaneously with the power button.
  • Some older Samsung models have a reset button located behind the battery cover. Press the reset button using a small, blunt object.
Warnings
  • A factory data reset removes all user data and settings associated with the current account. Make a backup of all data on your device before starting a hard reset.
May 12, 2014 | Cell Phones
"Tire Pressure Sensor Fault" keeps coming on on my message center, each time I start the car
You need to put a scanner on the computer and read the codes, then repair the codes called for and using the scanner clear the codes and you will be ok. The button on the message center doesn't reset the computer it just clears the code from the screen.
May 27, 2017 | 2003 Ford Expedition
I recently bought a Samsung Epic off the internet, come to find out, the screen is still locked. I tried figuring out the code and tried performing a hard reset, but no luck yet. Please help! :(
There's 2 options available.
1: Perform a hard reset.
1. Switch the phone off. 2. With the phone off, hold the Volume Down button, and while still holding the Volume Down button, firmly press and release the Power button. 3. You'll boot into a menu with a white background, small text and the little skateboarding Android guys. 4. Press the Volume Down button until you reach the Clear Storage option. 5. Press the Power button to select Clear Storage. 6. Press Volume Up to confirm the selection.Sit back while your phone reboots in its virgin state.
Or, you can contact the reseller and they should provide you with the code.
Mar 18, 2011 | Samsung Cell Phones
My HTC tatto phone has become very erratic. After every 1 second of making a call the power end menu options come up on the screen. The phone wont hang up after having pressed the "End Call" button. If I...
First, try a factory reset and see if that resolves your problem. I'm afraid that will wipe all the data on the phone, but you will have to do that anyway if you want to solve this problem.
Here are the instructions for the factory reset:
Performing a factory reset via settings
The most convenient way to do a factory reset is via the phone settings.
  1. Press HOME > MENU, and then tap Settings > SD card & phone storage > Factory data reset.
  2. On the Factory data reset screen, tap Reset phone, and then tap Erase everything. Your phone will erase all personal data and restart. It may take a few minutes for the process to complete.
Performing a factory reset using phone buttons
If you cannot turn on your phone or access the phone settings, you can still perform a factory reset by using the phone buttons.
  1. With the phone turned off, press and hold the HOME and BACK buttons, and then briefly press the END CALL/POWER button.
  2. Press the ENTER button to begin the reset process. (Otherwise, press the END CALL/POWER button to cancel.)
Aug 06, 2010 | HTC Tattoo Cell Phone
Error.6500
If the device is not functioning properly or to clear memory, reset it.
1. On the operator panel, press and hold the ON/OFF button for one second. (The display will go blank.)
Note: It may be necessary to unplug the power cord if pressing the ON/OFF button does not shut off the printer.
2. Wait approximately ten seconds and then press the ON/OFF button again.
3. Wait until the device has completed its cycling process before submitting another job request.
or
To clear error messages displayed on the LCD or if the printer is not functioning as expected, it may be necessary to simultaneously press Stop/Reset and ON/OFF buttons.
1. With the printer powered on, press and hold down the Stop/Reset button then press the ON/OFF button.
2. Once the printer is powered off, hold down Stop/Reset and then press ON/OFF.
or
The 6500 error can be something that needs repair or complete replacement as well. If your printer is less then 12 months then you can contact Canon Tech support for repair or replacement under warranty.
For toll-free technical support*, please call 1 (800) 828-4040 during regular business hours (currently Monday-Friday 10:00 a.m. - 10:00 p.m. EST, excluding holidays).
Nov 22, 2009 | Canon PIXMA MP170 All-In-One InkJet...
Hardreset samsung omnia i900
How to Hard Reset the Samsung Omnia Many people do not know how to hard reset the Omnia phone. The manual does not teach you the trick of doing this. You may follow the steps below to reset it to default factory settings.
1. Poke the soft reset hole beside your power button(Poke and Release)
2. Press and hold the Call and Cancel Button together(Do it immediately after Step 1)
3. Do not release Call and Cancel button, the Samsung Omnia Screen Appear
4. The Reset Screen will appear as below
This is a snapshot of the Samsung Omina Reset screen.
(Image from mobilesilence.blogspot.com)
Press Call to Format or End Call to Cancel.
This hard reset does not erase the 16GB memory. To reset everything, you could use the software hard reset by going to Settings > Hard Reset. There is also option to format the storage card.
If you decided not to format and press cancel, that will soft reset the phone.
Another Method to Hard Reset
There is another method to Hard Reset, just key in the following code on your Dial Pad
*2767*3855#
After keying in the code, the Phone will restart itself. Phone will be reset to defaulf factory settings straight away. For DZIA5 Firmware, it will format the My Storage Card also.
Reference : taken from " pspmyspace "
Best Regards
Jul 08, 2009 | Samsung SGH-i900 Omnia Unlocked Cellular...
Gateway Pentium III , 933 MHz Processor Upgrade Logo
65 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
