Question about Singer 8280 Mechanical Sewing Machine
I got a singer model 6038 the reverse push and buttonhole balance knob has cracked and i would like to get a replacement
  • 139 Answers
You can order parts through the Singer parts centers listed on this page:
http://www.singerco.com/support/replacement_parts_ssc_list.html
Posted on Apr 08, 2010
Singer Simple 3116 only sews backward.Looking for answer I saw earlier that involved several steps including buttonholer
You are stuck in buttonhole. The selector knob does not spin round and around. It is moved from Stitch 1 to stitch 14 and back. Try selecting buttonhole and then running the knob in the other direction to straight stitch. If that does not work, (1) drop the lever that senses the button hole attachment, (2) sew a few stitches backward, (3) push the button hole lever rearward, once, hard, (4) rotate the stitch selector to straight stitch.
Jan 09, 2015 | Singer Sewing Machines
Singer 6038 tension dial not working
there should be small washers ( discs with a tapered flange to direct the thread between the plates ) if they are not under the spring behind the tension adjuster knob then that will be your problem
if they are there then check that the tread is between the plates and not behind them
missing plates are available from a sewing machine mechanic sgop
May 07, 2017 | Singer 6038 Mechanical Sewing Machine
My Singer 2950 buttonhol-er stitches only one side of the buttonhole. It does not reverse and finish the buttonhole. What to do??
Have you pulled down the buttonhole trigger lever at the back of the sewing area? most modern machines have one of these - when you use it with the button hole foot, you'll see the foot has a little piece that sticks out and triggers the lever to begin stitching the reverse bead and bar tack of the buttonhole.
Nov 01, 2011 | Singer 2950 Mechanical Sewing Machine
I have a Singer model 9910 and am not able to make a buttonhole on the setting for #61. The buttonhole seems to be inserted properly and the foot is lowered but the machine just beeps and will not sew.
Re your buttonhole foot - please note the following:
- This foot comes with a metal underplate.
- Place the fabric between the foot and the underplate.
- I am assuming that you have the buttonhole lever pulled down.
-Note: The silver coloured buttonhole lever is directly behind the needle threader. Pull it all the way down.
-When u have all the above in place, start the buttonhole. When it finishes the first side, gently push the foot back, so it reverses. I know this sounds strange, but if you have slightly bent the underplate you will need to do this.
- The directions are in the manual on page 60.
May 15, 2010 | Singer Quantum 9910 Computerized Sewing...
How do I reverse stitch on a singer 362 fashion mate model
The large knob in the center of the stitch length dial is a button, push it in to reverse stitch. Hold in as long as you need to reverse stitch, then release to resume regular stitching.
Jan 09, 2010 | Singer Sewing Machines
No power after reverse stitching
if the machine will not turn on or run it sounds like an electrical problem within the machine which i recommend you leave to a technician due to high voltage.
scott.
Jul 28, 2009 | Singer 6038 Mechanical Sewing Machine
Beeping Sewing Machine
Your problem is most certainly with the buttonhole switch. Firstly: Look if the buttonhole lever, left back of machine, is push up in position. The beeping sound is a warning message. Secondly Remove the light cover, left of the machine, loosen back screw and remove left hand screw completely. Check for a small black electric switch, follow the brown and green elecrtic wire, just back of the light. If you push the BH lever up and down the switch finger should also move up and down. If it stays down, the machine will not work and give a beeping sound. If the switch finger is stuck, push it up with the BH in top position. Hope this will help you
Oct 31, 2008 | Singer 7422
Reverse sewing button stuck HELP!!
MOdel 6430 has the stitch length and buttonhole selector on the same knob. It is the one on the bottom right side of the machine. I believe you may have selected the buttonhole by pulling out on the large round knob. You need to turn the knob back to 0 zero and push in. This should return the machine to normal mode.Adjust your stitch length to 3 and try it. The reverse knob in the center should also stick out so that it becomes operational again.
sewman7
Jun 03, 2008 | Husqvarna Viking 1
Singer 8280 Mechanical Sewing Machine Logo
65 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
