Question about JVC RX-517V Receiver
Power surges I had pretty serious power surge at my house and now my receiver will not turn on.  I checked the small fuse at the power supply, but it is ok.  What else can i do?
  • johnmichalik Aug 07, 2008
    can i buy the entire PCB someplace?  Where would i go for a new transformer?
  • 4,234 Answers
Does it attempt to startup at all? Do you get any lights or any indication that the unit is trying to start? If not, there should be a small transformer inside that is the standby transformer. It generates the 5V standby voltage. I have seen these go open in the primary since there is a fuse built into the transformer. You may need to replace this transformer. You should be able to get to the primary winding. With the unit unplugged, measure across the primary side with an ohmmeter. You should read a low value. If it reads infinity, the primary is open and you need to replace the transformer.
Dan
Posted on Aug 07, 2008
  • ABRsvcs Aug 08, 2008
    Lets check to be sure that is the problem first. The entire board is not likely available anymore. Let me knopw what you find.
    Dan
6ya staff
SOURCE:
Replaced entire power supply board on our lg tv because the capacitors had gone bad. Now the tv comes on for a few seconds then turns itself off. Any ideas?
You always want to put a surge protector on all the small and big electronics for if you do not if lighting come in it would burn everything up. You might have had lighting come in and that is why some of your stuff is having problems now. If you own the home get a whole house surge protector. It will save you in the long run because if there is surge from the power company or from lighting then all your stuff will be protected.
It might be too late for it seems lighting has already got to it. We have had some pretty bad storms and if you do not have surge protection then that is what is wrong it is fried.
Jul 29, 2018 | LG Televison & Video
Titan Troubleshooting
Check for small fuse on circuit board:
http://waterheatertimer.org/Troubleshoot-Rheem-Tankless-water-heater.html
Water heater circuit boards are NOT protected from surge. And reset button does not protect from surge. Nearby lightning can put out any household appliance, especially since more of these things are electronic instead of mechanical.
Install single-use whole house surge protector and replace it after each surge event instead of replacing appliances.
http://waterheatertimer.org/How-to-wire-Whole-house-surge-protector.html
The quickest solution for tankless is to replace whole thing with more reliable tank-type electric heater for $275 from local box store.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Jun 18, 2013 | Water Heaters
Following a power cut my tv has no power, have changed the fuse, checked and used another proven working plug and still no power .. Is this tv repairable ?
Sounds like the power supply has copped a mains-borne surge. Replacing the fuse doesn't always fix it unfortunately. The cost to repair the switchmode PSU depends on how many components have been affected within it and the extent of the damage as a result of the surge. If the damage is serious, for example burn marks/large cracks on the board, and the optocoupler is destroyed, the whole set would be uneconomical to repair.
You can never predict when or where a power surge is likely to strike.
Feb 04, 2011 | Panasonic CT-36HL43 36" TV
Tv does not turn on after a thunderstorm and several attempts at power returning to the home. The power went on briefly then shut off several times, now the television will not turn on. We had the tv...
Check the main fuse in the power supply, the TV also has small surge protection devices (MOVs) installed after the fuse, any surges the come along and big enough will cause the main AC fuse to blow. When you surge protector, EVERY connections must go through the surge protector, for example, the AC cord of the TV is connected to the surge protector, the cable connection did not go through the surge protection, the surge then can get to the TV through the cables.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Please post back what you find.
Jul 21, 2010 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
I believe my tv was involved in a power surge. red/green blinks
Hello:
U just may of blown fuses on the power supply of the television if you are sure it was a surge. If u can open the unit check all fuses on the power supply for open coniditions. If the future is a good Ideal to use a surge proctector as this will protect your equipment. Make sure power is off and remove AC power to check fuses. Sometimes just removing AC power for a least 2mins will reset the unit.
Jul 02, 2010 | Panasonic PT-50LCX64 50" Rear Projection...
Computer won't turn on won't do anything , i had it connected and someone at my house was using electric drills and the fuse tripped and everything was shut down including my computer and since then it...
Try unplugging the computer completely from the wall for 15 minutes. Plug it back in, and see if it will power on.
If it doesn't it's most likely a blown power supply, when the breaker tripped, everything on the circuit basically fed back into everything plugged in. This is something most computer power supplies do NOT like.
The good news is, a power supply is generally pretty cheap, you can get new power supplies atarting around 20 bucks, although decent quality ones are closer to 50 bucks. Bad news is, there is about a 1 in 20 chance the power supply took other parts with it.
Once you do get it running, or get another computer, make sure to get a surge protector strip and plug everything connected to the computer into the surge protector. A 15 dollar surge protector can save you 150 dollars in parts and labor. (or more)
Sep 27, 2009 | Computers & Internet
Sony Bravia LCD TV is tripping the fuse in the house
These things draw a huge surge current when turned on. What size fuse are you blowing? These things can surge 10-12 amps on turn-on. What about a fuse with a reset button. They will take alittle more surge before they go. Don't matter about the insignia working before because the cheaper sets tend to stay powered up more when off....thus not surging on from a dead start. Could you try a different plug on a different circuit/fuse? and see if that makes a difference. If you have a 15 amp fuse, then your pretty close with other stuff plugged in. What size is your service? Do you still have an original 60 amp box with screw in fuses? Is it an old house?
Sep 08, 2008 | Sony Bravia KDL-40S4100 40 in. LCD TV
NPS-180EB A POWER SUPPLY SYSTEM DAMAGE DUE TO OVER VOLTAGE
well first is there a fuse you state fuse available not that one is there -----the surge didnt blow the breaker or fuses either if currant made its way to your components --as to why fuse didnt blow --- no fuse ---surge came through ground --surge blew something before fuse blew your case blew power supply
Jul 21, 2017 | Gateway 180Wt Power Supply NPS-180EB...
Emachine with XP home edition doesn't start
Hi hearalso, down to the basic's. Replace power cord.
No help there than, remove the case's side panel to expose the motherboard. (Normally it is the left side panel while facing the front of the PC.)
Look closely for a small (green in color) led light. The power cord must be connected to the PC & connected to you're power strip but do not press the power on button on the PC.
The green led tell's you the board is receiving 5volts. Check all connections. Un-plug & reconnect every data & power connector in your PC. (Double check). There is a fuse inside your power supply that may have blown. Check you're manual page, Approva Statements B-1. Fuse Warning Instruction Caution.
Check fuse in power supply. (Unplug power cord before opening).
If you can not power up the PC after all of the above than if possible, swap out the power supply.
Replacing the power supply is the last step.
If you have more questions, feel free to ask.
Good Luck!
Mike
Apr 09, 2008 | E-Machines eMachines Desktop PC
RCA g36788LV TV
check fuse n power supply section
Oct 27, 2007 | RCA G36788LV 36" TV
303 people viewed this question
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
stynger007
Level 1 Expert
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
