Question about Canon PIXMA MP830 All-In-One InkJet Printer
Need help U130
I refilled one of my ink cartridges and now it is sayin the remaining level of ink cannoit be correctly detected and wont let me print anything now. what and how can i fix this problem
  • roostercomed Aug 20, 2008
    I purchased replacement ink cartridges from Printcountry.com. I had to carefully remove the chip from the Canon cartridge and glue it to the Printcountry cartridge. Done. Their manual gave steps to aleviate the problem of "ink out" on the screen. Printcountry said to click the okay button 5 times and then hold down the paper feed button. THERE IS NO PAPER FEED BUTTON on a Canon MP830. How do I tell the printer to print anyway. This pain in the **** is more of a hassle than the savings was worth.
Just press the "Stop/Reset" button for about 10 seconds and the cartridge will be accepted. Do so for every cartridge sequentially. Good luck
Posted on Aug 12, 2008
Pixma 2200 series all in one
Don't use refill kits, they are no good in quality printers. Also the cartridges in the newer models have a chip in them that knows when the cartridge is empty. When it becomes empty, the chip has to be reset, and this is what those mall cartridge fillers do.
E, 1, 3 The ink may have run out. The function for detecting the remaining ink level will be disabled since the ink level cannot be correctly detected. If you want to continue printing without this function, press the machine's Stop (Reset) button for at least 5 seconds. Canon recommends to use new genuine Canon cartridges in order to obtain optimum qualities. Please be advised that Canon shall not be liable for any malfunction or trouble caused by continuation of printing under the ink out condition. Checking the Ink Status Checking the Ink Status with the Ink Lamps on the Operation Panel The ink level detector is mounted on the machine to detect the remaining ink level. The machine considers as ink is full when a new FINE cartridge is installed, and then starts to detect a remaining ink level. If you install a used FINE cartridge, the indicated ink level of it may not be correct. In such case, refer to the ink level information only as a guide. When remaining ink cautions or errors occur, the error code will be displayed on the LED (Light Emitting Diode) to inform you of the error. Check the error code and take appropriate action. -> [ An Error Code Is Displayed on the LED ] See[Checking the Ink Status ]
Oct 27, 2015 | Canon PIXMA Office Equipment & Supplies
Canon PIXMA MP 500 ink refills stop working
you have to reset the ink cartridge.. you have to use a ink refill reseter which come along when you buy a refill kit..
thank you.
May 03, 2008 | Canon Pixma MP500 All-In-One InkJet...
Hi, I refilled cartridge CLI-526M fromCanon Prixma MG5250 and I have the error U130. How can I resolve the error to reprint? Thanks.
FAQ: An Error Message Is Displayed on the LCD
Issue
If an error message is displayed on the LCD, take the corresponding action described below.
Cause
The following ink may have run out. Replacing the ink tank is recommended. U041 Print head is not installed.Install the print head.U051 / The type of print head is incorrect.Install the correct print head.U052 Some ink tanks are not installed in place. U072 / More than one ink tank of the following color is installed. U071 The remaining level of the following ink cannot be correctly detected. Replace the ink tank. U130 The following ink tank cannot be recognized. U043 U140 U150 The following ink has run out. Replace the ink tank. U163 There are no photos in memory card Contact the support center or service center for ink absorber replacement. Press OK to continue printing Ink absorber full. Service required Timeout error has occurred The device may be incompatible. Remove the device and check the manual supplied with the connected device An unsupported USB hub is connected. Remove the hub. B200Printer error has occurred. See the manual **** Printer error has occurred. Turn off power then back on again. If problem persists, see the manual
Jul 06, 2011 | Canon MG5250 Printer
I changed theblack ink cartridge twice and it still won't print in black, colours are printing but no black
Ink level data is stored in a chip of the cartridge. Once the cartridge is empty, ink low message will appear eventhough you refill the cartridge. You need to deactivate ink level detection function to continue printing in case of usage of refill ink .
Search google on how to change ink level detection
Chris Thrash
B52Computers
Jan 10, 2011 | Epson Office Equipment & Supplies
I'm trying to use refilled ink cartridges in my Canon MP530, but I get a V (or U) 130 error message. Any thoughts?
CHECK INK
A.
U130
An ink tank that was once empty is installed.
Printing under the situation may damage the Print Head.
Canon shall not be liable for any machine malfunction or damage caused
by refilled ink tanks.
If you want to continue printing with the refilled ink tank installed, press
and hold the [Stop/Reset] for at least 5 seconds, and then release it. Using
refilled ink tanks are memorized.
* This operation will release the function for detecting the remaining ink
level
B.
i am not sure but is working on 520
1. print mono or print color for color
2.stop
3.ok
4.on/off
  1. Switch the printer OFF
  2. Press buttons 1 + 2 + 3 and 4 (simultaneously using four fingers)
  3. Keep pressing this four buttons for 10 seconds
  4. Release the On/Off button (number 4) (Keeping pressing the others)
  5. After a few seconds (when the printer go ON) you can release buttons 1, 2, 3
  1. Maybe step "c)" is not needed
  2. This procedure was used when I refilled the Black cartridge - try using the ColorCopy button instead of BlackCopy button (number 1) if you refill Color cartridge.
  3. Maybe there is no need for all the four buttons - you can try 1 + 4, 2 + 4 or 3 + 4. (or 1+2+4, 1+3+4, 2+3+4)
Dec 02, 2010 | Canon PIXMA MP530 All-In-One InkJet...
Non-recognised ink cartridge
I haven't tried the Colour/B&W/Stop button combination suggested above, but on a Canon MG5250, switching off, then on, and immediately holding down the 'stop' button for 20-30 secs does seem to disable the block. After that the colour concerned has no indicator. It seems that refilled cartridges will woork for a few refills (showing low ink on the indicator) before requiring the permanent fix.
Jun 12, 2010 | Canon Pixma MP500 All-In-One InkJet...
My cannon printer pixma ip1800 cannot detect ink pls help me...
If after you install the cartridge you get a yellow light and error message:
“The following may have run out of color. The function for
continue printing with out this function, press the printer’s
start button. Canon recommends using new genuine Canon
cartridges in order to obtain optimum quality.”
Do not click “cancel printing”. Press printer start button
to start printing. This action will bypass the ink level
detection from the recycled cartridge. It will not damage the
printer! With a recycled cartridge this action needs to be
done one time.
A full recycled cartridge ink level may not display correctly.
It may show empty.
If you want to check the ink level, you can do a “Nozzle
check” by follow the directions below:
Go to menu File select print click on “Property” click
on “Maintenance”
Click on “Nozzle check” to print out the color check.
Click on “Cartridge Alignment” to align the cartridge.
See pictures for above process at Inktelligent ip 1800 topic
Also the refills refered to above are at the IP 1800 inkfilling page
Sep 23, 2008 | Canon PIXMA iP1800 InkJet Photo Printer
ERROR U130
The remaining ink level cannot be correctly detected. Replace the ink tank and close the Scanning Unit (Printer Cover). Printing with an ink tank that was once empty may damage the machine. If you want to continue printing in this condition, you need to release the function for detecting the remaining ink level. Press and hold the Stop/Reset button for at least 5 seconds, and then release it. * With this operation, releasing the function for detecting the remaining ink level is memorized. Please be advised that Canon shall not be liable for any machine malfunction or damage caused by refilled ink tanks. See “Replacing an Ink Tank” on page 46.
Apr 10, 2008 | Canon PIXMA MP600 all-In-One InkJet...
"ink cannot be correctly detected" error U130
Hold down the "Stop/Reset" button for 5 seconds and it dismissed the first message, but then there was another for a different cartridge, etc. Eventually I got it to work.
Jul 26, 2007 | Canon Pixma MP800 All-In-One InkJet...
Refilling Ink in Canon Pixma MP830
Hello, I found this in a repair manual for the MP830. summery is to press and hold the stop/reset button for 5 or more seconds. I copied the info from the manual too. The remaining ink amount unknown. [1683] (Applicable ink tank icon) The remaining level of the following ink cannot be correctly detected. An ink tank which has once been empty is installed. Replace the applicable ink tank with a new one. Printing with a once-empty or refilled ink tank can damage the print head. If printing is continued without replacing the refilled ink tank, press the Stop/Reset button for 5 sec. or longer to record the use of a refilled ink tank. Note: After the above operation, the function to detect the remaining ink amount is disabled.
Jul 17, 2007 | Canon PIXMA MP780 All-In-One InkJet...
Canon PIXMA MP830 All-In-One InkJet Printer Logo
269 people viewed this question
old marine
old marine
