Question about Whirlpool 24 in. DU1055XTP Built-in Dishwasher
Apparently you didn't read the info I included with my question.
There is power to the washer. There is power to the door latch switch. And power does leave the door latch switch when door is closed.
If there is a timer switch, it must be integrated into the control panel. There is no turnable switch such as used to be common in older dishwasher.
If there is an integrated timer switch, what part number is it for this model dishwasher?
  • 8 more comments
  • greberting Aug 07, 2008
    I think I just wasted ten bucks!! The "expert" apparently didn't even read my complete question. Sheesh. No help there!!!!
    That's no help at all!!!!
    I paid ten dollars with the full expectation you would tell me WHICH part to replace. It seems fairly obvious even to a dummy like me that it has to be either the electronic control board or the push button control panel.
  • greberting Aug 08, 2008
    The exact model number is DU1055XTPS0. Can you tell from the diagram which part might be defective? I certainly can't. I had looked at them BEFORE I began asking questions here. The diagrams are not adequately labeled. They don't give the names of most of the parts shown on the diagrams. They don't make it clear which parts have to be purchased as a complete assembly and which can be purchased as individual pieces.
    OK, I'll grant you that the model number wasn't complete. It should have been: DU1055STPSO.
    I had looked at the Sears' site before I began posting here. The blowups there are not much help. Some parts are not identified at all. And in some cases you can't tell if you have to buy the whole assembly or if individual pieces may be purchased.
    Anyway, I still have no clue which part I need........ By the way, the Whirlpool people are no help. The dishwasher is, absolutely no doubt, a lemon. Whirlpool couldn't care less about customer satisfaction in the matter.
    Sorry, but I already said that I had verified that the door switch is working properly. (I tested power in, and power out with a meter.) There actually TWO switches in the door latch assembly. They are both operating like they should.
    I swear. You did not read a single thing I wrote before.
    THERE IS POWER TO THE DISHWASHER. THERE IS POWER TO THE DOOR LATCH SWITCH. AND POWER DOES GO OUT FROM THE DOOR LATCH SWITCH!!! SHEESH!!
  • greberting Aug 09, 2008
    So, I DID waste my ten dollars. In my very first post I told you that there was power to the door latch switch. And I said there was power going out of the switch. Then you tell me I need to replace the switch. You guys are either totally incompetent, too lazy to read, or you don't mind ripping people off. In any case, just to prove you wrong, I went ahead and replaced the switches (there are two, by the way. I knew that, but you never bothered to tell me.) It didn't solve the problem........
    Do I need more help? Of course I do. The problem has not even been addressed properly yet, much less solved.
  • greberting Aug 10, 2008
    Just give me my money back. This is a total waste of my time.
  • Anonymous Apr 10, 2009
    power to the dishwasher, but nothing will light up or come on.
    Genius:
  • 3,422 Answers
Ok,If you need any info regarding the parts for your model just click on the below link,select your model and you can browse the sub components and the components including the diagram.
http://www.searspartsdirect.com/partsdirect/retrieveModelActionHome!retrieve.action;jsessionid=QQl3xkV8qbK7Dv-GyNIKtQ**.shcapp3305?modelNumber=DU1055XTP+&pop=flush
Posted on Aug 07, 2008
  • 6 more comments
  • Priya darshan Aug 08, 2008
    you can go for other experts advice.You have not wasted your 10 bucks at all.In the premium solution which i posted first just give me a thanks for trying rating and other experts will then be able to see your problem and provide the solution to you.
    And one more thing you have not mentioned your model no. correctly.You just said it is a Whirlpool 24 in. DU1055XTP
    That's the reason i gave you the link and told you to first check your exact model from that.
    Ok,Now there are three types of switches..you can chaeck them out.Click on the below link.You can alsoe click on the pics to view them.
    http://www.repairclinic.com/SmartSearch/...
    ohk..looks like that link isn't working.Anyways just click on the above link and on the top left just enter this model no.DU1055STPSO in the search box and click on search.You will get the parts.Next under the part type select switch.You will get 3 types of switches.Check the pics out.And i believe the one you are looking for is the door switch.
    See there are only 4 things which can cause no power to the dishwasher.
    1. No power to the dishwasher
    Make sure there's power getting to the dishwasher. Check for a
    tripped circuit breaker or a blown fuse. Check the wall socket for
    power. Sometimes the power cord disconnects at the dishwasher
    (inside the junction box, behind the bottom kick panel), if this is
    the case, the wiring must be repaired or replaced.
    2. Door switch
    Replace if defective.
    3. Timer
    Replace if defective (note: uncommon problem).
    4. Selector switch
  • Priya darshan Aug 09, 2008
    Again.You have not wasted your 10 dollars at all.
    We do not rip people.You want more assistance you will get it.You want a refund you will get that.
    I already told you to rate me as thanks for trying in the premium solution you paid for and then other experts will look into the issue and give you a solution for it.
    If you need anymore help please let me know.
  • Priya darshan Aug 10, 2008
    Please email premium.support@fixya.com
    regarding the refund issue.
Why do no panel lights turn on when my Kenmore Model 587.1625 is latched and ready
The door latch in Kenmore and Kitchenaid isn't of the best design.The spring steel latching tab is needs to push down the black plastic slide mechanism when the door in closed. That slide pushes down on a micro switch which interrupts the cycle when you open the door when the dish washer is running. Take the latch assembly back out. You can insert two compression springs inside the slide on each side of the latch. They are approx 3/16 Dia x 3/4 to 1 inch long. In the hardware dept at Home Depot or Lowe's..The springs will push the slide down hard enough to activate the switch. Right now your dish washer thinks the door is open.
May 17, 2014 | Dishwashers
Asko dishwasher model 1585
hi Servicing the Door Switch
On many dishwashers, the latch engages a switch to activate the timer and other control components. If the latch is not completely engaged or if the switch is faulty, the machine will not operate. Here's how to test and repair a door switch:
Step 1: Latch the door and hold the latch tightly in the closed position. This works best on a unit with a lever-type latch. Then turn the control to the ON position. If the unit works, the problem is probably a misaligned lock unit. Adjust the lock unit with a screwdriver. If this doesn't solve the problem, the switch may be faulty.
Step 2: Test the switch with a volt-ohm-milliammeter (VOM) set to the RX1 scale. Remove the panel covering the door switch and remove one of the electrical lead wires of the switch from its terminals. Clip one probe of the VOM to each switch terminal and shut the dishwasher's door. If the meter reads zero, the switch is working. If the meter reads higher than zero, the switch is faulty and should be replaced.
Step 3: Replace the switch with a new one of the same type. Connect the new switch the same way the old one was connected.
©2006 Publications International, Ltd.
For repairs to the timer, door latch, or switches, remove the control panel. To take it
off, remove a series of retaining screws and the control knobs, and lift off the panel.
Sep 14, 2008 | Asko 24 in. 1585 Built-in Dishwasher
Model w10311121b no power
Hi Scott. It appears you have the same dishwasher as mine bought in 2010- it worked sporadically for several years. I bought one year warranty ($289) in Feb2014 . Over 2 months, service technicians replaced 3 parts (user control board, motor control board and water sensor) hoping that each would fix it. They told me to run hot water before starting a wash cycle. Dish washing cycle failures were still sporadic and it finally lost all power in May2014. Service techs would not come out so I confirmed house power supply with a multimeter and then took the door apart to access the latch. I determined the latch kill circuit was not assembled properly and it had carbon buildup which I scraped off.
If your warranty has ended and you attempt this, do not use a power screw driver with these Torx screws as you can easily strip the threads or damage the plastic user control housing by screwing in too far on the top screws. (especially if you forget to reinstall the internal handle which acts as a spacer).
To disassemble: Remove the top 4 screws and top side screws, loosen the middle and lower side screws as needed. Separate the washer door face wide enough to remove the user control board, let it hang by the cord. The handle will be loose in the way, remove it. The latch has a white plastic kill circuit which is held to the latch with tabs. Unplug the circuit and carefully remove it. The circuit comprises 2 flat metal sheets that are pushed together by the latch lever when the door is shut. These plates separate when the door is open to kill washer power. The latch lever should be under both circuit plates with the shorter plate on the bottom. (long plate, short plate, lever, white housing). Reassemble, remember to include the handle My dishwasher operates properly now.
Apr 19, 2014 | KitchenAid Dishwashers
Smeg dish washer wont stop even when the door is opened,
I never heard of a smeg DW but you can bet the door interlock is hung up in some way. Ususally its micro switches on the latch assy. Then again, could be a bad relay on the control board. I would dis connect the switch first and see what happens. The way I would do that is disconnect power at your circuit box and dis connect the switch, tape off the wire, latch the door and return power. Bet it doesn't run. Most likely the switch assy. Would help to know the right brand name tho...
Oct 16, 2013 | Smeg Dishwashers
Fdb1050re won't start without cycling power off than on
Hi you didn sa how you ar cycling th epower , but i think you need the controler, did you say you repalce the door latch that has two safty switches on it , unit wont run if the latch is bad.
Dec 17, 2011 | Frigidaire 24 in. FDB1050RE Built-in...
Dishwasher won't run. Normal light and cancel light flashing cont
The door latch pulls the door tightly closed to prevent water leakage around the door. It is also designed to prevent operation while the door is open. The door latch works in concert with the door switch to ensure that the door is tightly closed and latched.The door switch is a separate part from the door latch and is found inside the cabinet. The switch is off when the door is open. Depressing the switch closes the circuit and enables dishwasher operation. Closing the door does not depress the switch all the way. Only when the door is closed and latched, does the door fully depress the switch.
If the door latch is not properly aligned it may not pull the door tightly closed and the door switch will not be fully depressed. Unless the switch is fully depressed the dishwasher will not operate. It is a simple matter to determine whether the door latch is the problem. Simply open the door, close the latch and select a cycle and depress the switch. Note that if the test is successful, with the door open, the dishwasher will operate and water may spray out. Make sure to first remove all tools from inside the dishwasher. Do not reach inside the dishwasher during the test. Now, inspect the cabinet where the door makes contact with it and locate the door switch. It may have a protruding button or spike or more likely it is a hole with a piece of metal or plastic inside it. You must fully depress that switch. If the switch is recessed, then use a non-conductive object, such as a wooden pencil, to depress the switch.
Thank you !!
Jun 18, 2010 | KitchenAid 24 in. KUDS01FLBL Built-in...
Have power but after selecting programe required light just flashes but does not start wash?
there is a switch in the latch on the door that won't let it accept a program, cause the sensor is telling it the door is open,if you can get at the switch, clean everything around latch and switch, make sure it's adjusted properly and all working smoothly, try again, if no work, replace switch, I've heard of this going the other way and people got all there dishs locked up in the dish washer because the safety latch failed,
Feb 01, 2010 | Dishwashers
I have a GE dishwasher model GSD1100G and the door will not latch now. Any ideas?
Yessir, I have a few.
1. Check the latch and strike. Usually, they're just loose.
2. Check the wiring to the switch. The lock and latch take a good bit of vibration being opened and closed.
3. Take a good look at the latch for physical damage. It happens. Your only recourse here is probably to replace the latch.
4. You didn't mention if the washer would run; the door latch is a permissive switch - if the washer will run, the switch is making contact, but the latch is defective. If it won't run, either the latch switch is bad, or the issue may be the control panel.
Best regards, --W/D--
Aug 12, 2009 | GE Dishwashers
Whirlpool gold start button flashing dishwasher won't start
press sani and heat back and fourth then after all lights light close door and hit start then wait about 3 minutes. worked for me
Oct 12, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
Whirlpool 24 in. DU1055XTP Built-in Dishwasher Logo
169 people viewed this question
Top Whirlpool Dishwashers Experts
Mike Cairns
Mike Cairns
Mike
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
