Question about ASUS P5S800-VM Motherboard
Cannot install winxp
When i installed sata raid controller i got error it says...file\raid\sis raid-sys caused unexpected error(18) at line 2113 what is that pls help thanks
  • fmvenezuela Aug 11, 2008
    hi styme, i tried to flash my bios it solved my problem thank you very much, now i can use my pc again
  • 84 Answers
I am aware your motherboard has just two sets of sata pins ( only two hard drives can be used )
Have you flashed your bios to latest one ?
Sure your cables for sata are not damaged ?
Are you sure the sata drives are in working order ?
Posted on Aug 08, 2008
Lamers.. :S
you need driver for raid.
try on asus.com
Posted on Sep 27, 2008
I have problem in asus A8V-vm motherboard in that hard disk is not detected in BIOS but Win-XP is working properly and when I tries to install new windows XP it shows an error that hard disk cannot be...
Asus A8V-VM Motherboard coming with SATA RAID option, thats why you could not see the detected HDD in system BIOS. But you can see the the detected HDD in RAID BIOS. You can enter to RAID BIOS that will pop up after system BIOS. If you are using old version of WinXP it will not detect the RAID controller of you motherboard. Thats why you cannot able to install WinXP. While you booting from WinXP CD press F6 key when the WinXP installer prompted for third party driver. Copy the RAID driver provider in driver CD to a Floppy Disk (INF file) and insert it, hit enter to continue the installation. If you are using WinXP Service pack 2 or higher you do not need this step it will automatically detect the HDD.
Nov 25, 2010 | ASUS A8V-VM Motherboard
How to solve the problem file isapnp.sys caused an unexpected error (32768) at line 5882 in d:/ xpclient/ base/boot/setup.c.
Something is wrong with the file system on the partition in which you try to install XP. Start the install again and this time when asked where do you want XP to be installed delete the old partition and create a new one.
May 15, 2010 | Computers & Internet
I am tring to install win XP with sata drive and
Make sure it is listed in your system CMOS before starting the XP install. Make sure cables are correct, and the drives are not turned off in CMOS. Some setup will allow you to set the drive types to AUTO, so you can also try that.
Jun 30, 2009 | MSI 661FM3-V Motherboard
While i was formatting a TC2120 server, i used low level formatting with Ctrl+A option after that the server is not detecting the SCSI hard disk although i've tried to install the third party driver with...
This error message usually relates to the wrong third party scsi drivers being use.
Check what SCSI card you have installed and make sure you have the correct drivers and that you select the correct driver from the list at the appropriate time.
It is also possible that the SCSI card itself has a problem, but it is far more likely to be the wrong driver.
Jun 29, 2009 | HP Server Tc2120 (335874-001)
XP is Not Recognizing Sata H.D. and I Need a RAID Controller Driver
This one should be right for you, remember to put it on a floppy, since XP needs a floppy for a 3rd party driver during install.. good luck!
http://download1.msi.com/files/downloads/dvr_exe/sis_sataraid_floppy_mb.zip
Jun 02, 2009 | MSI 661FM3-V Motherboard
Asus K8V-8 Deluxe and SATA F6 installation issue
You might have a bad version of the text mode driver for it.You can make your own slipstreamed XP install CD with my brief instructions to include SATA drivers so that there is no need for F6. http://rapidshare.com/files/211421782/nLite_Instructions_XP.pdf
May 02, 2009 | Computers & Internet
Error code
Apparently the XP Pro CD you are using is pre-SP2, thus causing the error. With XP RTM and SP1, you need to supply the proper SATA drivers for the chipset on the motherboard since there is no built-in support for SATA drives. You can download the drivers from http://www.ecs.com.tw/ECSWebSite/Downloads/DownloadFile.aspx?catid=1&driverid=2214&areaid=2&LanID=0
During the XP setup you will need to press F6 to install these driver before attempting to copy the XP files to the drive. Or you could make a custom XP CD using the directions at http://maxeasyguide.blogspot.com/2008/04/preparations-for-winxp-installation-cd.html that has these SATA drivers already slipstreamed into the installation procedure.
Or if you know someone who has the WinXP Pro SP2 CD, you could borrow that for the install.
Apr 07, 2009 | Foxconn (945G7MA-8KS2) Motherboard
Can't install Hard Drive MS Server 2003
HI.. please specify the ASRock motherboard model, check whether it is using which chipset as SATA Controller... ICH6 or ICH7 or ICH8 or ICH9
ICH5/6 Sata Raid drivers
http://down3.driversdown.com/Bios/ich5r_6300esb_ich6r_msft_raid.exe
ICH6/7/8 Sata Raid drivers
http://down3.driversdown.com/Mainboard/iata621_cd.exe
ICH9
http://downloadmirror.intel.com/14849/eng/f6flpy32.zip
Please tell me if u need anything else.....
Regards,
Siddesh Prabhu
Aug 30, 2008 | Intel Motherboard
SATA hdd is not recognized by winXP intallation
First u have to update ur bios and then USE HIREN BOOT CD to repair  HDD
Oct 11, 2007 | DFI KM400MLV KM400...
ASUS P5RD1-VM raid controller
1. put Motherboard Cd (come with p5rd1vm) in cd/dvd rom.
2. BIOS configur as boot from cdrom.
3. restart machin Motherboard CD boot with press enter
4. command line shows 4 option
5. Select 1st option for exact and proper copy ULi sata driver for winxp.
6. Insert floppy press enter
7.you see d copy procedure.
8.then this floopy insert when winxp setup asking F6 for additional driver.
Thank you.
YOGESH JADHAV
Sep 29, 2007 | ASUS P5RD1-VM Motherboard
ASUS P5S800-VM Motherboard Logo
166 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
