Hi, I am trying to download windows powershell and am getting a message that the update does not apply to my system. I dont know If I am trying to install the wrong version or not, I have a Windows Vista Turion 64 operating system and I am trying to download: Windows PowerShell 1.0 Installation Package for Windows Vista x64 Edition (KB928439) with Windows Update standalone installer. could you possibly help? Thanks
  • 69 Answers
You can download a latest 2.0 version here http://support.microsoft.com/kb/968929. Vista 64-version http://www.microsoft.com/downloads/details.aspx?FamilyId=0f73efa2-f8d6-45f3-a8f8-5cdc205b119a
Posted on Dec 30, 2009
    Sergeant:
  • 395 Answers
Have you installed SP1 and all hotfixes?
Are you logged in as Administrator?
Posted on Aug 07, 2008
How to get Windows update to work after doing re install of Vista?
Try updating your hard disk drive driver see:
Vista Windows Update Error 8024A000
Here's the solution. I had to replace a failed hard drive in a Vista laptop. The original drive was a 200GB and I replaced it with a 500GB. I used my original Toshiba restoration CDs. I've spent HOURS troubleshooting this problem and I never would have guessed the solution -- it's the Intel Rapid Storage Technology Driver. It has to be updated because of the larger drive.
Here's a link to an HP support site for the updated driver. You can also find the update on Intel's site.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c02219204&cc=nl&lc=en&dlc=en&product
Sep 22, 2014 | Toshiba Satellite A305-S6872 Notebook PC
I got a mesage that say: Problem loading C:\progra~MYWEBS~1\bar\8.bin\M3PLUGIN.DLL cant find module
Please click on Start, Click on Run and type the following in the open box and click OK
msconfig
Vista: In the Start Search field, type msconfig , and press Enter . The System Configuration window opens.
Or
Press and hold Windows logo key on keyboard and press R. It will open Run Window. Type the following in the open box and click OK
MSconfig
Please click on Startup tab
Remove the check mark from entries related to Mywebsearch OR M3PLUGIN.DLL
Then click on Apply, Close and Please click on Exit without restart.
When the system restarts, you will see a message about System Configuration Utility. Click in the box for "Do not Show this message" and then click on OK
Jun 13, 2011 | Computers & Internet
I have downloaded a file WINDOWS POWERSHELL that has an .msu extension how do i install this package in my winxp professional sp2 os.
.MSU is a Microsoft UPDATE file....designed to be downloaded and installed as part of Windows Update.
I suggest you run the Windows update and choose which items you want to install from the list (assuming it includes Powershell) otherwise, locate a standalone installer for the powershell, which should have a .MSI or .EXE extension.
Good Luck
Apr 28, 2011 | Microsoft Windows XP Professional SP2
I cannot download the new windows updates-I get an error message 646 and cannot find out what that means
Try the following steps to install the update successfully.
Stop the services pertaining to Windows Update.
1. Click Start, click All Programs, click Accessories, right-click Command Prompt, and select Run as Administrator.
2. If you receive a notification from User Account Control simply click Continue.
3. At the command prompt, type the following commands and then press ENTER after each command.
net stop wuauserv
net stop bits
net stop cryptsvc
4. Please do not close the Command Prompt window.
Rename folders pertaining to Windows Update
At the command prompt, type the following commands and then press Enter after each command:
ren %systemroot%\System32\Catroot2 Catroot2.old
ren %systemroot%\SoftwareDistribution SoftwareDistribution.old
Start services pertaining to Windows Update.
net start wuauserv
net start bits
net start cryptsvc
Close the Command Prompt window.
Download the standalone package file of the update “KB967043”
and install it.
Visit the following link to download the update:
http://www.microsoft.com/downloads/details.aspx?familyid=628280fe-e035-4274-85f2-393d9bad543c&displaylang=en
Restart the computer once the update is installed.
Let me know if this worked.
Oct 15, 2009 | Microsoft Windows Vista Home Premium with...
I can't apply vista themes which i have download from internat as i have window vista home premium
hi there,
update your vista to microsoft it can help a lot like SP2 and SP3 updates. Direct X, and others, and also it will smooth your PC operations. but some update need to specify if it is a 32 bit or 64 bit OS.
God Bless
Nov 29, 2008 | Microsoft Windows Vista Home Premium with...
Did you try uninstalling the last batch of updates?
To see the updates under "Add or Remove Programs", you'll need to check the appropriate box at the top.
If uninstalling does not help, you may have to start over.
Possible approaches to avoid the same issue when starting over:
  • Don't use SP3, unless you know that you *need* it. Check Wikipedia to decide whether you need it.
  • Install OS with SP2 and all updates, only then apply SP3.
  • Don't install all updates at once. Install them in batches of, say, 10 a batch. If the same thing happens, you know which batch was responsible.
Aug 04, 2008 | Microsoft Windows XP Professional for PC
I dont know whether its possible or not yo can try by contacting them.
But this is the best way to download the drivers of all your devices which are connected to the system for free.
But you have to be patient.
First, i want you to download a ree program called "Orbit download manager" from the link below,
http://dl.orbitdownloader.com/dl/OrbitDownloaderSetup.exe
And then you can download a program called "Driver genius" from link
http://www.qwerks.com/download/6776/drvgenpro.exe
it is a trial program for 15 days
dont worry we only need it for 5 minutes
Install & run the program & in the windows click on the update the drivers
It will check & it will give the window with the drives that needs to be updated & it will not update a it is a trial one.
So you just right click on the driver name, you will get a message called 'copy url address 1' copy that & open the orbit downloader & click on the create new download & paste the link the drivers will be downloaded for free.
Some sites give these drivers only for the money & we cannot be able to find them from the free sites, so i think this would be a nice trick.
Good Luck.
Live, Love, Laugh.
May 12, 2008 | Computers & Internet
How can i download a4tech webcam coz i dont have installer?
hi!how can i install my a4tech webcam.model pk-635m.i lost my driver and i dont know how to download.what can i do first?.i will wait your answer thank you..
May 12, 2008 | A4tech PK5
Getting error message in trying to run TurboTax 2007
Try re-installing the software.. it is possible that something messed up when installing/updating.. Also make sure that any updates you apply are for windows XP and not windows Vista
Apr 06, 2008 | Microsoft Windows XP Home Edition
Computers & Internet Logo
119 people viewed this question
David Payne
David Payne
